Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-03-2001, 11:27 PM   #1
TurboRex
Member#: 8635
04 STI, 07 FXT
Default Cat removal on 1993 Impreza 1.8l
My daughter owns a 1993 impreza (base model). It has acquired an exhaust leak just before the cat. The stock exhaust looks crazy how it snakes the air before it heads straight back to the muffler. I was wondering about putting in a different Y pipe and removing the cat to help improve exhaust flow. Since the o2 is just before the cat, I would assume this should not cause any computer problems.
Any comments?
Thanks,
Greg
TurboRex is offline   Reply With Quote
Old 11-04-2001, 12:03 AM   #2
awdwagon
Member#: 6585
1997 acura integra
champion white
you shouldnt experence any computer problems, i have an L also, and the flow on the front pipe looks a little restrictive. my thoughts were maybe trying the front pipe section from a 2.2 or a 2.5 if they'll fit.
awdwagon is offline   Reply With Quote
Old 11-04-2001, 07:03 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
oh yes....if you remove the cat and go to a free flwoing exhaust kiss ANY torque that car makes goodbye. IIRC the RS or OBS exhaust is a totally different make up.
jeremy
Old 11-04-2001, 01:58 PM   #4
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Post
I'd invest in a cat back exhaust, and if you're bent on replacing/removing the cat, I'd just get a slightly larger high flow cat... there's no sense in completely removing that cat on a small displacement N/A motor, you'd feel some pretty bad power losses, I'd think.
SoobATV is offline   Reply With Quote
Old 11-04-2001, 06:48 PM   #5
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Be carefull removing the cats,I just installed a high flow cat on my RS.Got the ole check engine light after about a 100miles.It doesnt worry me cause im sure its the O2 sensor readin weird.Yep did an ECU reset.Lost a little at the bottem end but picked it up on top.The engine just wants to go(godamn rev limiter).
Just thought id add that if your worried about CEL's.
Rudy
jagcars26 is offline   Reply With Quote
Old 11-06-2001, 08:10 PM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
How would removing the cat reduce torque??? If you say backpressure, I'll laugh. Anyone who has ever tested exhaust systems will prove that its the exhaust velocity, not backpressure that makes or breaks hp. As for the CEL, the backpressure can help the o2 sensor heat up to operating temp sooner.
I upgraded my 1.8L cat to a 2.25" cat designed for a turbo chrysler. The power gain was VERY nice, probably because the turbo went on at the same time.
Chad
93 1.8T
subachad is offline   Reply With Quote
Installing WRX Rear Brakes On 1993 Impreza (Swapping out drums) ScoobySnacksURhonda Brakes, Steering & Suspension 1 10-09-2007 06:50 PM
Quick Question on 1993 Impreza L corner markers NewGwrx New England Impreza Club Forum -- NESIC 3 03-23-2006 08:05 PM
gf6 bumper from japan on a impreza 1.8l L sedan? acetrouble8 Interior & Exterior Modification 0 11-15-2005 11:05 PM
Need Help. 1993 Impreza 1.8L 2wd GC5 StillBoostin Transmission (AT/MT) & Driveline 8 01-21-2005 01:43 PM
Forester 16" mags on 1993 Impreza L hobun2 Forester Forum 2 03-28-2002 04:45 AM
