Notices
Old 09-28-2006, 03:22 PM   #1
Norcalrallyist
Member#: 15510
1993 MY94 WRX
Default Detailed description of my clutch problem need help
This is either a 93-94 front clip and I need som serious help.... Id like a confirmation that the 02 wrx parts will work in this drivetrain too. Some other boards say there is a differnce between 94 and 02 parts. Please help cause im out of ideas basically.
The first time I had just put the entire drivetrain in the car with the 94 wrx flywheel/02 wrx pressure plate/02 wrx TOB/02 clutch disc. When everything was bolted up the clutch fork was impossible to move by hand. I bled the clutch and after pressing the pedal a few times I heard a pop. I went to take a look at the fork and I was able to move the fork back and forth freely. I thought and was told it might be possible that the bearing came out of the pressure plate so I tried to hammer the fork in an attempt to fix this situation but was not able to. After removing the engine I found the TOB was still in the pressure plate.
I decided to try the 94 wrx pressure plate/94 wrx TOB/02 clutch disc the second time. I figured there must be some difference between the 02 and 94. I put the engine back in the car and again I could not move the clutch fork by hand. After a few pushes of the clutch the same pop noise occured and the fork once again was able to be moved freely by hand.
The third time I decided to lower the clutch pedal closer to the floor because I thought the fork might be exceeding its throw and coming out of the TOB. I also used the 94 pressure plate/94 TOB/02 clutch disc this time. Again the fork was not able to be moved by hand upon installation. I sat in the car and pushed the clutch pedal until I was satisfied the same problem would not repeat itself. I pushed the clutch in 200 times. The pedal was normal each time and I had someone else push the pedal while I watch the fork move. Everything seemed to finally be working. I worked the rest of the day on putting the car back together for the drive to texas and when i started it and pushed on the clutch it went straight to the floor. I got out and checked the fork and sure enough I was able to move the fork freely.
I found out that I was installing the bearing not according to instructions but im not sure if it would have changed my situation. I installed the TOB on the pressure plate. Then bolted the pressure plate to the flywheel. Then slid the engine towards the tranny and placed the fork in the TOB. Finally I put the pivot pin in after the tranny and engine were mated together. I dont see how putting the TOB on the tranny input shaft with the fork and pivot pin installed first then hitting the tob into the pressure plate would produce a different result but just in case, I wanted to clarify.
THanks
Norcalrallyist is offline   Reply With Quote
Old 10-04-2006, 08:59 AM   #2
Norcalrallyist
Member#: 15510
1993 MY94 WRX
MY02 Wagon: New clutch...problems...need help bwawuz Transmission (AT/MT) & Driveline 6 11-17-2006 09:32 PM
Clutch problems, need help pinter Transmission (AT/MT) & Driveline 6 07-14-2005 05:52 AM
clutch problem - need help Willis Normally Aspirated Powertrain 8 05-04-2001 06:11 PM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 06:13 AM
('93-'01) clutch problem, need help. Scooby25 Impreza Forum 3 04-14-2001 02:58 PM
