Old 09-28-2006, 05:14 PM   #1
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
Wink 18g too small for ej207 you say?
Well thought I'd post a couple of logs from tuning yesterday. Lots of people on this board have said the 18g is too small for the ej207, I call BS. Ride5000 had fun doing some speed density tuning on my car. Everything was going great till an intercooler hose blew off at 23psi. Fixed that did some more pulls and tuning. Went to drive home and now I've got a pre turbo exhaust leak
My car hates me, but we got some good pulls and logs in before the leak reared its ugly head. The car is by no means fully tuned, still got a long way to go. You can see how rich it's running at redline, almost at 100% idc's.
Here's my mods:
JDM V7 Sti (ej207)
Deatschwerks 750cc Injectors
M2 TMIC
Coolingmist Vari-cool WI
JDM/AUS Utec
Greddy 8cm 18g(T518Z)
NGK Irridium 1 step colder
GM boost solinoid
ERZ downpipe
Blitz Touring catback
Modded stock BPV
APS turbo Inlet pipe
K&N Typhoon Intake
Sti uppipe
Walbro 255 Fuel pump
Apexi Turbo Timer
Synic EL headers
These logs were made on 93 pump w/out WI.
This 3rd gear one shows how it's still making boost to redline:
Code:
                    Load,  Knock,    ,      ,      Mod,  Map ,     , Mod
 RPM,  MAP, MAF,TPS,Site,Count, AFR, Ign#1, Inj#1, Ign,   VE ,Boost, MAF
    ,psia,    V , % ,    ,     ,    ,deg , duty , deg,   %  ,(CL) ,  V
 3494, +2.7,2.9,101, 00,   00,  12.1,+39.1,  19.5,ECU. ,100  ,WGS.  ,2.9
 3538, +4.3,3.3,102, 20,   00,  12.1,+37.4,  20.3,+20.2,100  ,WGS.  ,3.1
 3646, +5.9,3.4,101, 30,   00,  13.1,+35.6,  22.8,+19.5,100  ,WGS.  ,3.1
 3711, +8.0,3.3,101, 40,   00,  12.5,+34.1,  26.2,+18.7,100  ,WGS.  ,3.4
 3894,+10.6,3.5,101, 50,   00,  rich,+31.7,  32.9,+18.0,100  ,WGS.  ,3.3
 3958,+13.7,3.7,101, 60,   00,  rich,+29.2,  38.4,+18.0,100  ,420.00,3.6
 4050,+18.0,4.0,101, 80,   00,  rich,+24.6,  47.2,+18.0,100  ,420.00,4.0
 4251,+22.3,4.4,101, 90,   00,  rich,+21.8,  55.6,+18.0,100  ,420.00,4.0
 4357,+23.3,4.4,101,100,   00,  rich,+20.6,  61.2,+18.0,100  ,420.00,4.0
 4498,+22.1,4.3,101, 90,   00,  rich,+24.9,  60.6,+18.1,100  ,420.00,4.0
 4694,+22.5,4.4,101, 90,   00,  rich,+28.2,  62.2,+18.2,100  ,420.00,4.1
 4837,+23.1,4.4,101,100,   00,  rich,+29.1,  66.2,+18.0,100  ,420.00,4.2
 5050,+23.3,4.5,101,100,   00,  rich,+25.4,  68.4,+18.0,100  ,420.00,4.2
 5192,+21.9,4.4,101, 90,   00,  rich,+27.0,  68.6,+19.2,100  ,420.00,4.2
 5333,+22.3,4.5,101, 90,   00,  rich,+26.5,  69.0,+18.8,100  ,420.00,4.3
 5574,+22.7,4.6,101, 90,   00,  rich,+27.5,  72.5,+18.4,100  ,425.00,4.3
 5611,+22.1,4.6,101, 90,   00,  rich,+32.8,  73.0,+19.4,100  ,425.00,4.3
 5837,+20.8,4.6,101, 90,   00,  rich,+33.0,  74.1,+20.1,100  ,425.00,4.3
 5984,+22.3,4.7,101, 90,   00,  rich,+32.8,  76.9,+18.6,100  ,425.00,4.4
 6093,+21.2,4.7,101, 90,   00,  rich,+32.3,  76.9,+19.7,100  ,425.00,4.3
 6207,+20.4,4.6,101, 90,   00,  rich,+31.9,  81.7,+20.5,100  ,425.00,4.3
 6349,+21.5,4.6,101, 90,   00,  rich,+33.3,  82.3,+19.7,100  ,425.00,4.4
 6548,+21.0,4.7,101, 90,   00,  rich,+33.1,  82.2,+20.5,100  ,445.00,4.4
 6561,+21.7,4.7,101, 90,   00,  rich,+32.5,  83.6,+19.2,100  ,445.00,4.4
 6720,+21.7,4.7,101, 90,   00,  rich,+32.7,  87.2,+19.3,100  ,445.00,4.4
 6958,+21.9,4.7,101, 90,   00,  rich,+33.0,  88.4,+19.7,100  ,445.00,4.4
 7047,+21.9,4.7,101, 90,   00,  rich,+33.4,  88.8,+20.5,100  ,445.00,4.4
 7107,+21.7,4.7,101, 90,   00,  rich,+33.4,  88.4,+20.5,100  ,445.00,4.4
 7199,+22.1,4.7,101, 90,   00,  rich,+33.4,  91.5,+20.5,100  ,445.00,4.4
 7137,+22.5,4.7,100, 90,   00,  rich,+33.4,  94.8,+20.5,100  ,445.00,4.4
 7374,+22.1,4.7,101, 90,   00,  rich,+33.8,  95.2,+20.5,100  ,445.00,4.4
 7423,+22.5,4.7,101, 90,   00,  rich,+33.6,  96.8,+20.5,100  ,445.00,4.4
 7473,+22.7,4.7,101, 90,   00,  rich,+33.6,  95.7,+20.5,100  ,445.00,4.4
 7593,+22.5,4.7,101, 90,   00,  rich,+34.0,  97.5,+20.5,100  ,445.00,4.4
 7662,+22.3,4.7,101, 90,   00,  rich,+34.6,  97.0,+20.5,100  ,445.00,4.4
 7627,+22.3,4.7,100, 90,   00,  rich,+34.9,  97.9,+20.5,100  ,445.00,4.4
 7770,+22.9,4.7,100,100,   00,  rich,+34.9, ---.-,+20.5,100  ,445.00,4.4
And this 4th gear one shows the pretty 4.8 MAF V and some decent spool:
Code:
   ,     ,    ,   Load,  Knock,    ,      ,      , Mod,  Map ,     , Mod
 3183, +0.0,2.9,102, 00,   00,  rich,+41.1,  14.7,ECU. ,100  ,WGS.  ,2.8
 3183, +0.8,3.0,102, 00,   00,  rich,+40.0,  15.9,ECU. ,100  ,WGS.  ,2.8
 3223, +1.7,2.9,102, 00,   00,  rich,+39.9,  16.6,ECU. ,100  ,WGS.  ,2.7
 3252, +2.5,2.9,102, 00,   00,  rich,+39.7,  17.4,ECU. ,100  ,WGS.  ,2.9
 3264, +3.3,2.9,102, 20,   00,  rich,+39.1,  17.7,+30.5,100  ,WGS.  ,2.8
 3313, +4.1,3.0,102, 20,   00,  12.1,+37.7,  18.8,+22.3,100  ,WGS.  ,3.1
 3356, +5.1,3.3,102, 30,   00,  12.1,+35.8,  20.0,+20.8,100  ,WGS.  ,2.9
 3390, +6.2,3.1,101, 30,   00,  rich,+35.5,  22.0,+20.9,100  ,WGS.  ,3.2
 3439, +7.2,3.2,102, 30,   00,  rich,+34.4,  23.3,+20.1,100  ,WGS.  ,3.3
 3483, +8.4,3.3,101, 40,   00,  rich,+32.9,  25.3,+19.5,100  ,WGS.  ,3.2
 3512, +9.8,3.6,101, 40,   00,  rich,+31.6,  29.3,+18.6,100  ,WGS.  ,3.3
 3561,+11.5,3.5,101, 50,   00,  rich,+29.5,  32.0,+18.5,100  ,420.00,3.3
 3631,+13.5,3.6,101, 60,   00,  rich,+27.4,  36.0,+18.5,100  ,420.00,3.4
 3679,+16.1,4.0,101, 70,   00,  rich,+24.9,  40.8,+18.5,100  ,420.00,3.7
 3736,+19.0,4.1,101, 80,   00,  rich,+23.5,  45.1,+18.5,100  ,420.00,3.8
 3818,+21.9,4.1,101, 90,   00,  rich,+23.5,  50.6,+18.5,100  ,420.00,3.9
 3912,+23.1,4.2,101,100,   00,  rich,+23.9,  53.8,+18.5,100  ,420.00,3.8
 3885,+22.9,4.1,101,100,   00,  rich,+24.5,  54.1,+18.5,100  ,420.00,3.8
 4084,+22.1,4.1,101, 90,   00,  rich,+24.9,  55.0,+18.5,100  ,420.00,3.7
 4140,+22.9,4.2,101,100,   00,  rich,+23.8,  57.6,+18.5,100  ,420.00,3.9
 4192,+23.5,4.4,101,100,   00,  rich,+23.4,  59.5,+18.5,100  ,420.00,3.8
 4295,+23.1,4.2,101,100,   00,  rich,+23.1,  60.4,+18.5,100  ,420.00,4.1
 4397,+22.7,4.4,101,100,   00,  rich,+23.0,  60.8,+18.5,100  ,420.00,4.0
 4480,+22.7,4.3,101, 90,   00,  rich,+24.1,  61.4,+18.5,100  ,420.00,4.1
 4597,+22.7,4.4,101, 90,   00,  rich,+25.6,  62.5,+18.6,100  ,420.00,4.1
 4655,+22.7,4.4,101,100,   00,  rich,+26.9,  63.4,+19.0,100  ,420.00,4.0
 4803,+22.9,4.4,101,100,   00,  rich,+27.9,  64.1,+19.7,100  ,420.00,4.0
 4803,+22.5,4.3,101, 90,   00,  rich,+29.0,  67.4,+20.7,100  ,420.00,4.1
 4909,+23.5,4.5,101,100,   00,  rich,+28.4,  67.2,+20.0,100  ,420.00,4.1
 5012,+23.1,4.4,101,100,   00,  rich,+29.4,  67.3,+20.5,100  ,420.00,4.0
 5042,+22.1,4.5,101, 90,   00,  rich,+25.1,  67.5,+20.7,100  ,420.00,4.2
 5120,+23.7,4.5,101,100,   00,  rich,+24.1,  70.5,+20.5,100  ,420.00,4.2
 5232,+22.5,4.4,101, 90,   00,  rich,+25.5,  70.3,+20.7,100  ,420.00,4.2
 5385,+23.3,4.5,101,100,   00,  rich,+25.9,  72.0,+20.5,100  ,420.00,4.2
 5402,+23.1,4.5,101,100,   00,  rich,+26.4,  72.5,+20.5,100  ,420.00,4.2
 5464,+22.5,4.5,101, 90,   00,  rich,+26.3,  72.8,+20.7,100  ,425.00,4.2
 5611,+22.9,4.5,101, 90,   00,  rich,+26.3,  74.0,+20.7,100  ,425.00,4.3
 5574,+22.5,4.6,101, 90,   00,  rich,+27.3,  74.7,+20.7,100  ,425.00,4.2
 5707,+22.1,4.6,101, 90,   00,  rich,+32.7,  75.2,+20.8,100  ,425.00,4.3
 5817,+22.5,4.6,101, 90,   00,  rich,+33.0,  75.8,+20.8,100  ,425.00,4.3
 5767,+22.1,4.6,101, 90,   00,  rich,+32.9,  76.7,+20.8,100  ,425.00,4.3
 5920,+22.5,4.6,101, 90,   00,  rich,+33.0,  76.8,+20.2,100  ,425.00,4.3
 5984,+21.9,4.6,101, 90,   00,  rich,+32.6,  77.7,+20.7,100  ,425.00,4.3
 5952,+21.7,4.6,101, 90,   00,  rich,+32.9,  77.2,+20.5,100  ,425.00,4.3
 6049,+21.2,4.6,101, 90,   00,  rich,+32.6,  77.6,+20.7,100  ,425.00,4.3
 6116,+20.8,4.6,101, 90,   00,  rich,+32.5,  77.5,+20.9,100  ,425.00,4.3
 6195,+22.3,4.7,101, 90,   00,  rich,+31.7,  81.8,+20.0,100  ,425.00,4.4
 6230,+22.1,4.7,101, 90,   00,  rich,+31.8,  82.4,+20.3,100  ,425.00,4.4
 6349,+21.5,4.7,101, 90,   00,  rich,+33.7,  81.1,+20.4,100  ,425.00,4.4
 6397,+21.5,4.7,101, 90,   00,  rich,+33.9,  82.4,+20.7,100  ,425.00,4.4
 6397,+20.8,4.6,101, 90,   00,  rich,+33.4,  81.6,+21.0,100  ,425.00,4.4
 6459,+21.2,4.7,101, 90,   00,  rich,+33.2,  81.7,+20.9,100  ,425.00,4.3
 6459,+21.7,4.7,100, 90,   00,  rich,+33.1,  84.3,+20.5,100  ,445.00,4.4
 6497,+22.9,4.8,100,100,   00,  rich,+32.3,  86.2, +1.0,100  ,445.00,4.5
SonicYelloWRX is offline   Reply With Quote
Old 09-28-2006, 05:32 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by SonicYelloWRX View Post
Everything was going great till and intercooler hose blew off at 23psi.
and this is what it looks like:
Code:
 5274,+21.2,4.5,101, 90,   00,  rich,+31.5,  67.6,+19.6,100  ,420.00,4.1
 5420,+22.3,4.7,101, 90,   00,  rich,+27.0,  71.9,+18.1,100  ,420.00,4.2
 5367,+23.1,4.6,101,100,   00,  rich,+26.9,  72.6,+17.5,100  ,420.00,4.2
 5564,+22.3,4.6,101, 90,   00,  rich,+28.3,  71.2,+18.1,100  ,425.00,4.3
 5574,+22.9,4.6,101,100,   00,  rich,+27.7,  74.7,+17.9,100  ,425.00,4.3 <right here, george ****s his pants
 5241, +1.1,4.7,102, 10,   00,  rich,+25.7,  28.7,ECU. ,100  ,425.00,4.5
 5659, +0.2,4.6,101, 10,   00,  rich,+27.2,  28.7,ECU. ,100  ,420.00,4.2
 5491,-10.0,4.2,  0, 10,   00,  rich,+33.1,  10.0,ECU. ,100  ,ECU.  ,3.8
 5367,-11.8,3.6,  0, 10,   00,  12.5,+26.6,   7.2,ECU. ,100  ,ECU.  ,3.3
 5027,-11.6,3.4,  0, 10,   00,  17.8,+27.8,   7.0,ECU. ,100  ,ECU.  ,3.1
 4694,-11.2,3.2,  0, 00,   00,  21.4,+12.2,  38.8,ECU. ,100  ,ECU.  ,2.9
 4374,-10.8,3.0,  0, 00,   00,  lean,+11.6,  38.8,ECU. ,100  ,ECU.  ,2.9
Old 09-28-2006, 05:38 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 09-28-2006, 05:43 PM   #4
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Why would anyone ever say an 18g is too small? Too small for what... It depends on what you need it to do.
Damn Boost Junkies.
An 18g is great for a lot of different stuff like daily street driving and autoXing. A 20g won't be as good for those but will build more boost up top. Maybe bigger boost was their basis for comparison. There is a purpose for every turbo and there isn't one turbo that is best at everything. Enjoy your choice and move on.
chrisarella is offline   Reply With Quote
Old 09-28-2006, 06:00 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
George...awesome buddy. Definitely a great combo, looks fun.
Is that a stock sized maf tube btw? You get W/I working yet?
Good luck with it and enjoy
Soon2Bgreat is offline   Reply With Quote
Old 09-28-2006, 06:10 PM   #6
wrxzboost
Member#: 86322
i predict your bpv will go next, even though it is modded . i think the 18g is a great choice...
wrxzboost is offline   Reply With Quote
Old 09-28-2006, 06:33 PM   #7
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks like the 8cm 18g is MORE then enough for an ej205
bren wrx is offline   Reply With Quote
Old 09-28-2006, 06:35 PM   #8
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
can you and ken do a stock airbox pull with that 4.8V maf, i wanna see if its not a restriction like TMS says
Old 09-28-2006, 07:39 PM   #9
josh04
Member#: 89288
2002 Rex
It kinda looks like your ignition timing is up and down all over the place, a little bit, same with your boost. That's just me though. But if the car doesn't stutter and it pulls then I'd be happy. And the spools looks like it comes on nice.
josh04 is offline   Reply With Quote
Old 09-28-2006, 07:50 PM   #10
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
Your looking at the wrong column for my ignition timing. The one you are looking at is what the ECU wants to run. The Mod ign is what the UTEC is actually running. Boost still needs some work as we were trying to get rid of the ocillations.
Old 09-28-2006, 08:45 PM   #11
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
yeah, well this is a 207...
XS_WRX is offline   Reply With Quote
Old 09-29-2006, 09:19 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
by the way, i've got some tricks to try with the boost map to reduce the oscillations, george.
but first, fix that damned rattle and find your exhaust leak...
no ADI tune yet, louis--but when that gets fired up we're gonna boost the crap out of this little 18g.
Old 09-30-2006, 03:05 AM   #13
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
gracias amigo, looking forward to further progress with your setup. good info!
TROLL is offline   Reply With Quote
Old 09-30-2006, 06:29 AM   #14
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
...Greddy 8cm 18g (T518Z)...
Keep us up to date... that turbo rocks!
ka mano is offline   Reply With Quote
Old 10-03-2006, 08:59 PM   #15
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
Looks like I have a cracked uppipe and it's leaking bad. Should be fixed in a couple weeks and I'll throw it on the dyno.
Old 10-03-2006, 09:07 PM   #16
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
the greddy 18G is a great turbo. I believe that the 8cm makes it signifigantly better than the MHI variants that people get.
I would trade my green for a greddy 18G/ex gate/WI setup. perfect for the street and such.
do you have avcs enabled yet sonic? Have you made any progress tuning it, and is it apparent in the logs when avcs kicks in? I've had nothing but trouble getting it working in my turd.
nice work so far/
Hunter
skiblur is offline   Reply With Quote
Old 10-03-2006, 09:18 PM   #17
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
Hunter,
My AVCS is up and running, I actually used the first IA Performance AVCS kit Stephen made. Worked perfectly and was easy to hook up. I did struggle for months trying to wire it up myself to no avail until I got the kit. Haven't done any tuning with the AVCS yet, may try it later using enginuity, but that will require dyno time and the only person that seems to really know what changes AVCS tuning is Clark and I'm sure he won't share his secrets
I've thought about an external gate, but I'm not a fan of the sound. I've worked hard to make my car to be super quiet for what it is. Plus I haven't seen a need for it yet as the Greddy has a 13psi internal wastegate and has no trouble holding boost to redline.
George
'02 Forester - 6 1/2 fronts, but hole too small for normal 6 1/2 baskets? Back Road Runner Car Audio, Video & Security 4 11-14-2004 02:52 AM
"Are My Breasts Too Small For You?" Ferg Off-Topic 22 05-29-2003 07:43 PM
Are stock RS size rotors too small for 4 pot front brakes? edkwon Brakes, Steering & Suspension 2 07-03-2002 02:30 PM
2.25 in axle back too small for 5 psi ITR&RSGUY Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-28-2001 11:17 PM
Is a 205 45 17 too small for a new WRX with the Superleggras?? climb4it Brakes, Steering & Suspension 10 03-21-2001 01:10 AM
