#1 |
Vendor Sales Rating: (61)
Member#: 18920
BAIC
Vehicle:2004 WRX/STI Aspen White |
PERRIN Performance™ front mount intercooler kit
![]() The PERRIN™ front mount intercooler offers outstanding airflow and cooling performance, while resisting damage from road debris. The PERRIN™ Intercooler core stretches the entire length of the bumper skin opening with core dimensions of 28" X 9.25" X 3.5". The enhanced bar and plate design offers significantly enhanced flow and heat exchange performance. Cast aluminum end tanks assure optimal air distribution over the entire intercooler core. Making no compromises in safety or structural integrity the PERRIN™ front mount intercooler solidly mounts to the provided, new PERRIN bumper beam. The beam is construct from 1/2" steel mounting plates attached to a box sectioned steel beam and powder coated for rust protection. No cutting of structural components is required. Fits: WRX and STi MSRP: $1199.99, Nasioc SPECIAL $1079 FREE SHIPPING! PERRIN Performance™ Big MAF Intake System When used in tandem with the PERRIN™ Fuel injector modification and aftermarket electronics the "Big MAF" intake will allow the user to tune an aftermarket ECU safely and accurately. Add resolution in fuel maps and load columns, compensate air fuel ratio, idle, and wide open throttle maps. The PERRIN Performance™ Big MAF intake system is designed to prevent the Mass Air Flow output value from being pegged on heavily modified WRX engines. When using the factory MAF sensor and adding large amounts of boost the stock MAF sensor will max out and not allow additional compensation for air flow. MSRP:$219.99, Nasioc Special $196.99 FREE SHIPPING! Available color: 2 black, 1 Red Available! Perrin Short Ram Intake Manufacturing one of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then our competitors ![]() MSRP: $189.99, Nasioc Special $170 Free shipping Perrin Panel Filter Add horsepower and torque without replacing the entire air box assembly. The PERRIN Performance dual stage drop in panel filter provides maximum power gains while removing harmful particulates from the air charge. This is a direct replacement for the factory panel air filter. Comes pre oiled and ready for installation. Fits: WRX, STi, Forester XT and Baja! ![]() ![]() Regular Price was $29.99, Nasioc Special $26.99 FREE SHIPPING! PERRIN Performance™ Subaru STI Fuel Rail Kit solves all fuel distribution problems. Our fuel rails direct fuel to both banks of cylinders and to the fuel pressure regulator. Even fuel distribution is achieved through the PERRIN™ design guaranteed! PERRIN Performance™ fuel rails are specifically designed for the Subaru STI side feed injectors to retain correct fuel injector alignment. This is a critical part of our fuel rail design. THE PERRIN FUEL RAIL KIT INCLUDES: BILLET ALUMINUM RAILS FUEL PRESSURE REGULATOR MOUNT STAINLESS LINES AND FITTINGS. FREE GROUND SHIPPING!!! ![]() MSRP, $399, NOW $359 FREE SHIPPING!!!! or Local PICK UP!!! Perrin Turbo Inlet Hose Kit- (3 black, 2 red, 2 blue) Fits: IHI VF series turbo, FP Green, and etc.. ![]() MSRP $229.99, Nasioc Special$199 free shipping. Perrin 3" Turbo Inlet Hose Kit - in RED. For Large Turbo setup such as FP Red. ![]() MSRP $259.99, Nasioc Special$230 free shipping. Borla Hush System Back IN STOCK, READY TO SHIP!! ![]() [b]Every BORLA header and cat-back(tm) system is made from T-304 stainless steel (superior to 409 or aluminized steel) employing mandrel-bent tubing, all-welded construction, and is designed for accurate fit and easy installation.The Borla Hush Exhaust System offers a stealth looking dual-tip without sacrificing performance. A quiet system for those not wanting too much attention but still needing the extra power and flow from the full 3" system. Includes 3" flat-flange adapter piece which replaces the section of Borla Hush that tapers to 2.5". (Adpater piece uses full 3" piping and flat flange. Allows the Borla Hush to bolt on to aftermarket down-pipes w/ 3" flanges, thus making a true 3" turbo-back exhaust.) FREE SHIPPING Nasioc Special $553.99 Free Shipping! FREE SHIPPING only applies to lower 48 states. CA Residents please add local sales tax Please give us a call to order!! Or simply use paypal: sales@speedelement.com Thank you, Cal Speed Element/MPJ Performance 44875 Industrial Drive Unit B Fremont, CA 94538 510-226-8822 510-226-8833
| Thread Tools | |
| Display Modes | |
| Few things for sale Borla Hush, STI Limited rear wing, etc..... | slo07wrx | South East Region Private Classifieds | 8 | 01-25-2009 09:44 PM |
| FS-(VA): Perrin 816cc injectors and Borla Hush exhaust | Clark_Kent | MAIC Private Classifieds | 23 | 10-25-2008 04:55 PM |
| FS-(VA): Perrin 816cc injectors and Borla Hush | Clark_Kent | Engine/Power/Exhaust | 1 | 10-14-2008 02:06 PM |
| 04 WRX Perrin Up Pipe and Borla Hush | Rtwalker | Private 'Wanted' Classifieds | 2 | 08-20-2008 08:37 PM |
| Perrin Parts Blow Out! Borla Hush w/ 3" adaptor Sale! | SpeedElement | Engine/Power/Exhaust | 11 | 08-09-2006 07:56 AM |
