Old 09-28-2006, 07:41 PM   #1
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
Default TD06 18g install and idle search
I installed a blouch td06 18g turbo and i used the cobb 18g map, it runs ok enough till i go get tuned but what happens one in a while it will idle seach when just idleing and when i turn on the ac it makes this weird noise . When it makes that noice i can feel it in the clutch does anybody have any idea what it could be
blue m&m is offline   Reply With Quote
Old 09-28-2006, 07:43 PM   #2
mdd1986
Member#: 83450
2000 Audi S4 Stage 3
my car has done that all the time since the day i had it. Seems normal, the idle will dip a bit anytime the fans come on or the a/c is switched on. Seems normal 2 me.
mdd1986 is offline   Reply With Quote
Old 09-28-2006, 07:46 PM   #3
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
i guees the since it aint tuned maybe it running a little off?
Old 09-28-2006, 08:00 PM   #4
mdd1986
Member#: 83450
maybe, but the turbo shouldnt really affect your idle unless you installed different sized injectors
Old 09-28-2006, 09:09 PM   #5
dillsky
Member#: 109485
06 Blue TR
FP18g'd
cobbs map is designed for an Forced Performance tdo5 18g. Thats why your running into idle problems. You are definately going to need a tune. I prob wouldn't wait too long.
dillsky is offline   Reply With Quote
Old 09-28-2006, 09:32 PM   #6
th1rd3y3
Member#: 83054
'11 SWP
STI
Mine has always made that noise too. It's probably the compressor kicking in.
If not, I'd imagine tuning should take care of it. Check for boost leaks as well.
th1rd3y3 is offline   Reply With Quote
Old 09-28-2006, 10:21 PM   #7
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
yes i did change the injectors from 560cc to 750cc
Old 09-28-2006, 10:21 PM   #8
blue m&m
Member#: 108257
2007 GmbH RS4
Imola Yellow
and the fuel pump walbro 255
td06 18g with a 7cm or td05 18g with 8cm drkramm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-05-2009 04:40 PM
TD05 18G VS. TD06 18G which one to get? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 11-20-2008 03:44 PM
WTB: TD06-18g or TD06-20g or FP Green sonic03rex Private 'Wanted' Classifieds 5 01-15-2007 04:31 PM
Turbo Specialists! IHI, TD05-TD06, 18G,20G,25G, SuperZilla, and larger custom turbos! DeadBolt Enterprises Engine/Power/Exhaust 385 01-03-2005 10:14 AM
