Old 11-04-2001, 02:36 PM   #1
Girl'sRS
Member#: 162
1999 Impreza RS
Silverthorne Metallic
Angry CEL near 36K
Does Subaru have any history of turning on the CEL <i>right</i> as the warranty is about to run out? I was driving the 225 mi trip between Philadelphia and Albany when it turned on - ODO 35,9**. I pulled over & tightened the gas cap. No luck. At the rest stop I took the gas cap on & replaced it tightly and cycled the car on and off several times. When I pulled in at my destination it was still on. I am going to try disconnecting the battery & see if it comes back - being Sunday I couldnt bring it in to get the code pulled if I wanted to.
Any thoughts? Almost sounds of a ploy to come in & purchase the extended warranty before its too late.
Girl'sRS is offline   Reply With Quote
Old 11-04-2001, 03:25 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well seeing as how you are close to your warranty they should goodwill it. Best way to find out is take it to the dealer, and if they deny you the claim for being 100 miles out of warranty then you need to contact SOA! I know we regularlly do work on Goodwill once out of warranty.
Jeremy
P.s.: Have you done anything to the car?? What are your mods?
Old 11-04-2001, 04:10 PM   #3
Girl'sRS
Member#: 162
1999 Impreza RS
no engine or exhaust mods.. just the sway bar & short shifter.
Old 11-04-2001, 04:24 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i would contact your dealer and tell them what happened. It's most likely and emissions system code if the car is still running fine. Could even be just a bad o2 sensor. Give them a buzz and see what they say.
jeremy
FS: IL - 2004 STi BBS Wheels 5x100 with Potenza RE070 only 5k total miles! Near new! RedLine55 Wheels/Tires 24 06-08-2010 01:04 AM
CEL at 36K miles? Rojorex South East Region Forum 8 05-14-2004 10:52 PM
who can pull CEL codes near north NJ and wants some $? M32WRXin3seconds Tri-State Area Forum 6 10-12-2003 05:37 PM
36k warranty jayfressh Service & Maintenance 6 04-21-2002 10:28 AM
outback sport 36k mile tuneup $400!?!?! Jejunum Service & Maintenance 13 03-12-2002 12:44 AM
Message Board Statistics All times are GMT -4. The time now is 10:27 AM.
