#1 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
OK, I'm about to put my rocker assembly together and I can;t figure out how to allign anything because of all the marks. On my crank timing belt pulley there is a blue dot, a triangle, and a line. all in different areas.
On my two cam sprockets there are a big arrow, a blue painted on dot, and a little line like on the crank timing pulley. What lines up with what??? Please help here. Thanks Eric
#2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
the aarow's point up on the cam pulleys....you will see white dots painted on the CAM and CRANK pulley. There will 3 white lines on your T-Belt...line that all up and you'll be set to go but MAKE sure all those white marks line up otherwise you just thru your valve timing all to hell.
jeremy |
#3 |
Sooby Guru
Member#: 1914
SWIC
I don't have any white marks on my timing belt at all. it is all black
Eric |
#4 |
Sooby Guru
Member#: 1914
SWIC
Here is the first cam sprocket. Notice the arrows and dots and lines:
![]() Here is the second cam sprocket. same stuff : ![]() Here is the crank sprocket Notice it has an arrow, a line, and even another blue dot!: ![]() What lines up with what. like I said, there are no marks on the belt Eric |
#5 |
Member#: 4423
Vehicle:'04 08 Tribeca, SVX Gold, Maroon |
Don't listen to someone who works on Hondas!
The arrows at 12:00 mean #1 TDC. To install the Cam Belt, arrange the Cam gears and the Crank gear with the "Line" at 12:00. This will put them in APPROXIMATE position to install the belt. The left Cam will be loaded and the right Cam will not. To install the belt, either go buy a new Cam Belt from Subaru or find a Subaru Service Manual so you can get the tooth-count between cam marks and crank mark. You should have marked these on the belt as well as the direction of rotation before you took it off. The position of the gears is only approximate because it doesn't really matter, the number of teeth between the marks is what is important. What are you sealing your Cam Cases with? Don't use RTV Silicone. |
#6 |
Sooby Guru
Member#: 1914
SWIC
Why shouldn;t I use RTV? That's what the Shop manual suggests and what was on it from the factory. Do you know how many teeth should be on the belt between gears?
Eric |
#7 |
Member#: 4423
Here is the tooth count instructions from the SM. It is from the Forester book but is the same for Impreza.
Nevermind. It is too much work to post a pic here. I have the SM on CD and was going to copy the page. Between the Crank mark and the R. Cam mark is 46.8 teeth Between the Crank mark and the L. Cam mark is 43.7 teeth After you set-up the belt and release the tensioner, turn the crank back and forth and check to make sure the marks still line up. Turn the crank over 2 revolutions and make sure the Crank and Cam marks still line up. Once you turn over the engine the belt marks will no longer match up to the gears. I don't know what Service Manual you are reading, but Subaru does not say to use Silicone RTV. The solvent in the RTV is destructive to O2 sensors, and it doesn't work well. For the Cam Case Subaru recommends Threebond 1280B, part #K0877YA018. This is also what came on the engine "from the factory". |
#8 |
Member#: 11913
Vehicle:2000 Forester White |
Hey tech master.... did you ever work at the dealer in walnut creek?
#9 |
Sooby Guru
Member#: 1914
SWIC
When you say right and left, you mean Left is Driver and right is Passenger correct?
Eric |
#10 |
Sooby Guru
Member#: 1914
SWIC
OK, I must be doing somethign wrong.. No matter how hard I try, I can't get the timing belt on and the Tnetioner is fully compressed! Wht's the secret
Eric |
#11 |
Member#: 4423
That is the universally accepted referance. As though you are seated in the Drivers Seat.
#12 |
Sooby Guru
Member#: 1914
SWIC
Just wanted to make sure we were on the same track. so waht the secret to getting the belt on? it is Sooooo close.
Eric |
#13 |
Member#: 1997
Vehicle:2006 Acura TL 6spd STMGM6 alumni |
SubyTechMaster, Hondatech actually has torn down ej25's quite a few times now. Dont discount it. He has practical experience inside of subary motors. Just cause he mainly works on hondas doesnt mean he doesnt know what he's talking about.
#14 |
Member#: 6551
yeah that was a rather rude comment. But thanks anyways. Just trying to help someone out...oh yeah if you went and bought a new belt you'd have 3 white lines on it....cam crank cam....but thanks.
jeremy subaru Idiot Last edited by HndaTch627; 11-04-2001 at 06:08 AM. |
#15 |
Sooby Guru
Member#: 1914
SWIC
Thanks for all the help guys. I ended up going to Cobb Tunning's site adn saw something on it that said something about takign the red pulley off and bingo! the belt went right on. I counted the number of teeth and marked it there everything lined up perfectly. Now I am goign ot be putting the engine back in the car today
![]() Eric |
#16 |
Member#: 4423
While my comment may have been snide, it does not discount the fact that WRONG info was posted.
My apologies if I impinged on anyones honor. |
#17 |
Member#: 6551
well that's how i was told to do it by 3 subaru techs and it's worked on 3 cars so far.
| Thread Tools | |
| Display Modes | |
| need timing belt help in milwaukee! | n2oiroc | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 05-24-2008 02:35 AM |
| i need timing degre help?? | happy69 | Built Motor Discussion | 0 | 05-05-2007 11:25 PM |
| Need Alignment Help Quick Like.....Hook a brother up!!!! | YourMother'sLover | Texas Impreza Club Forum -- TXIC | 13 | 06-02-2006 04:16 PM |
| I need some photoshop help quick | Disgruntled | Off-Topic | 13 | 10-22-2004 12:33 PM |
| Need lat minute help quick! | JDMSubaru | Tire & Wheel | 7 | 10-17-2003 10:48 PM |
