Old 09-30-2006, 01:22 PM   #1
prototypeWRX
Member#: 78739
2015 WRX
Impreza WRX STi Custom short ram intake heat shield (clears Process West FMIC piping)
Intake manifold temperatures improved drastically:
95-99F @ 40+ mph | 109-116F @ <40 mph / img_0613
Intake Manifold Temperature: -[12-15]F cooler at speeds >=40mph | -[35-40]F cooler at speeds <40mph(including idle)
Temperatures measured w/ Greddy Informeter and are compared to short ram w/o heat shield.
Outside temperature according to STI cluster was 89F.
I'm also using the GP Moto intake snorkus delete elbow to help direct more air to the intake.
Click here for photos of the whole process
I know people say a cold air intake is best, but there's hardly any air flow in the fender because of the fog light.
Please also note that because my hood has extra vents(shown in photo below) on the sides, cool air flows directly into the custom intake heat shield box.
I'll be replacing the air filter in the photos with a foam filter and using Cobb Street Tuner to tune it once installed.
Here are mor photos of the complete car
prototypeWRX is offline   Reply With Quote
Old 09-30-2006, 01:25 PM   #2
RR02wrx
Member#: 99614
12 STi Limited
Very nice. This is one of my fav bugeyes. I should weld up one also...
RR02wrx is offline   Reply With Quote
Old 09-30-2006, 01:34 PM   #3
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
nice,i still think the aps fmic looked better,but it's a good trade off if that new fmic has less lag
vtecTHIS is offline   Reply With Quote
Old 09-30-2006, 01:40 PM   #4
prototypeWRX
Member#: 78739
2015 WRX
Impreza WRX STi
Yep, a lot less lag. And the performance means more to me than the looks.
I only wish I would have taken intake manifold temperature readings while the APS 525 FMIC was installed w/ the APS cold air intake so I could compare the readings. If anyone reading this has intake manifold temperature readings please post them or PM me. Thank you.
Old 09-30-2006, 01:50 PM   #5
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Nice heat sheild what did you use to make it and ditail please look sexy thanks
subaru222 is offline   Reply With Quote
Old 09-30-2006, 02:01 PM   #6
prototypeWRX
Member#: 78739
2015 WRX
Originally Posted by subaru222 View Post
Nice heat sheild what did you use to make it and detail please look sexy thanks
Sheet metal, weather stripping vinyl, rivets, silicone(for the cracks) and high temp(also helps block heat) ceramic coating.
Old 09-30-2006, 02:05 PM   #7
Dunkin
Member#: 113496
(V) (;,,;) (V)
Is this the '04 STi with the bugeye conversion I saw on an earlier thread? Nice work on the heat shield! I wonder though if K&N will sell their heat shields seperatly from the Typhoon intake for the guys who can't fab their own stuff.
Dunkin is offline   Reply With Quote
Old 09-30-2006, 02:20 PM   #8
prototypeWRX
Member#: 78739
2015 WRX
Yep it's the 04 STI that I converted into a bugeye. The K&N shield is too wide to fit because of the Process West FMIC piping and its hole for the intake is too low(intake sits much higher because of FMIC piping). Custom fab' is the only way to go in some cases.
Old 10-02-2006, 03:24 AM   #9
topshotta10
Member#: 70218
2005 WRX sti 20g met
i was trying to make a custon shield as well, but wanted to use a material similar to the ones used by K&N or spt, but the sheet metal should be good enough.
topshotta10 is offline   Reply With Quote
Old 10-02-2006, 11:14 AM   #10
TJ
Member#: 41735
I'm on your lawn
do something about it
you have too much times on your hands chris
good job tho!
TJ is offline   Reply With Quote
FS (MN) SPT Short Ram Intake + Heat Shield bolverk Engine/Power/Exhaust 5 07-08-2010 10:09 AM
WTB :: SPT Short Ram w/ heat shield 02-07 WRX Myth21 Private 'Wanted' Classifieds 0 05-23-2010 02:33 PM
k&n typhoon short ram w/heat shield hun23 Engine/Power/Exhaust 18 02-27-2008 11:25 PM
FS: Greddy Airinx Intake, Custom short-ram Intake GC8_SpecC Vancouver Impreza Club Forum -- VIC 9 08-27-2005 04:46 AM
FS: Omp Front Strut Bar, Greddy Airinx Intake, Custom Short-ram Intake GC8_SpecC Vancouver Impreza Club Forum -- VIC 4 08-03-2005 06:34 AM
