Old 09-30-2006, 04:24 PM   #1
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Default How should I wire the trigger wire for the SafeIjnection?
I got a new Meth kit (Snow Performance) and I have a question on how to wire the SafeInjection. Its all pretty much straight forward but I was looking for a way to wire up the 12v trigger wire. It sends a 12v signal when it does detect water in the line. Can I somehow wire this to my Perrin EBC so it opens up and now allow more boost? I don't want the 12v trigger going back through the wire harness and damage my ECU/Utec. Maybe use a diode?
I know I could use the WG solenoid they sell but I'm trying to keep things simple and less clutter under teh hood.
http://www.snowperformance.net/prodd...p?prod=SI%2D10
For years, many have wanted to use water/methanol injection but have not taken advantage of the power increases do to safety concerns. Designed as an ad-on to the Boost Cooler® water/methanol injection system, Safe Injection™ provides for a safe tune in those instances where no injection is present and an aggressive tune is utilized.“ This system reduces boost or timing anytime injection quantity goes below a set point (e.g. if reservoir level goes too low) making the tune instantly conservative for the ultimate in safe water/methanol injection.
Operation
The SI-10 and SI-05 monitor the flow of Water/Methanol in the system. When flow drops below 0.10 Gallons per Minute (GPM), equal to 378 ml/min,( 0.05 GPM or175ml/min on the SI-05) the fault trigger will go to a high state of 12 volts. In addition to the supplied red LED, this trigger can be used to signal the following:
1. an ignition/timing controller such as an MSD timing computer if using an MSD ignition
2. aftermarket engine computer
3. a solenoid such that boost is reduced in a wastegated turbo set-up. ( $39.95 list. See below.)
4. a solenoid to evacuate boost on a supercharged set-up.
The trigger signal can deliver up to 1.5 amps to drive a solenoid or relay.
R0DENT is offline   Reply With Quote
Old 10-02-2006, 11:54 AM   #2
tasq
Member#: 62362
2005 wrx
CGM
Without a stand alone like autotronics, I'm pretty sure it isn't possible to change the boost map on the fly with a 12V signal... Honestly, if I were you, I would just get the solenoid, and hook it up that way... If you do it right, you can't even tell it is there. Here is a diagram of how mine works
Let me know if you have any other questions...
tasq is offline   Reply With Quote
Old 10-02-2006, 03:50 PM   #3
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
You make it look too easy! I was thinking there was going to be more tubes and clutter. I already got the solenoid so I'll get that installed per your drawing.
THANKS!
Old 10-02-2006, 04:09 PM   #4
tasq
Member#: 62362
2005 wrx
CGM
THANKS!
Glad to help
Old 10-03-2006, 04:37 PM   #5
Ultimate Collision Center
Member#: 69072
Yea the solenoid is pretty straightforward install, much easier than what you were about to try and do...
Ultimate Collision Center is offline   Reply With Quote
Old 10-03-2006, 04:38 PM   #6
Member#: 69072
Should "Pacifica Blue Pearl" be offered for the Impreza? RA29 STi Forum Archive 4 06-11-2003 12:32 AM
I think Subaru should make a shorter car again for the love of rallying Homemade WRX Motorsports 23 04-02-2003 02:09 AM
How much should a 60K mile service cost for the Forester? Jasno999 Service & Maintenance 5 09-28-2002 04:05 AM
apexi tt What wire on the ecu is for the 02 sensor REDOO2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-15-2001 12:38 AM
should i swap out the 2.5 for the turbo legacy motor? CHACHI Normally Aspirated with bolt-on Forced Induction Powertrain 27 11-12-2001 03:33 AM
