Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 09-30-2006, 06:33 PM   #1
TurboQueef
Member#: 86700
2005 STI
Silver/Black,11.44@123.60
Default Videos posted to my site: Launch, 4th gear pull etc...
Hi..
I got a new camcorder.. and am putting it to use. I have updated my webpages to include videos of: TurboQueefs, Hard Launch through 4th gear and a 4th gear pull. Follow this link: http://N8RWS.COM , select the "STi" icon then the "Video Recordings" link.
Let me know what you think...
Jeff
TurboQueef is offline   Reply With Quote
Old 09-30-2006, 06:55 PM   #2
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
haha the 4th gear pull looks like its goin so slow but sounds like its haulin some serious a$$
The launch was sickkk! Car sounds like a beast!
The turbo queef in succession i didn't get
sweet car!
Caplin 2.5 is offline   Reply With Quote
Old 09-30-2006, 06:57 PM   #3
TurboQueef
Member#: 86700
2005 STI
sweet car!
Do you know what a queef is? The turbo makes kind of a queef sound when it expresses the excess air that the engine can't take... I know, it is kind of sick but that is me...
</IMG></IMG>
Old 09-30-2006, 07:02 PM   #4
bastich
Member#: 57276
2004 STi
Nice quality to the vids but I just dont get any feel for the speed.
bastich is offline   Reply With Quote
Old 09-30-2006, 07:39 PM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
You seem to be running a little too rich, are you making attempt to lean it out a little? I am mainly referring to when it is riding in the low 10's.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 09-30-2006, 08:01 PM   #6
TurboQueef
Member#: 86700
2005 STI
Jeff
Hi Jeff,
Yea... the main purpose of my datalogging today was to try a lean mix from 5K to 6K but I found that the engine was pulling a lot of timing if I run too lean. The AFR values you noticed in the 10.2 range are just after spool up, 2900 to just over 3K rpm. The AFR makes a steady ramp up to 11.3 by redline... Here is a link: http://n8rws.com/9%2030%20furst%20pull.xls to the datalog of the 4th gear pull in the video, let me know what you think after viewing it. Note: I did add fuel from 5K to 6 after this log, it gave me much more timing (15 to 18 @ 10.8/1 AFR)
Old 09-30-2006, 08:07 PM   #7
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I think that your actual timing is the sum of the "dynamic Advance" and the "Ignition Timing". I am not sure but only 15-18 degrees is low, you should be seeing low to mid 20's. Good luck tuning though, see if cobb can provide some helpful info.
Jeff
Old 09-30-2006, 08:16 PM   #8
Caplin 2.5
Member#: 71203
2005 2.5rs
I'm well aware of what a queef is hahaha didn't know turbos queef till today, you tought me something.
Old 09-30-2006, 08:25 PM   #9
TurboQueef
Member#: 86700
2005 STI
Jeff
A lot of us StreetTUNER's are experiencing a strange Phenomenon... in that the total advance is not equaling the sum of the dynamic and primary values. An example of this condition can be seen if you look at the row with timestamp: 48:03.8, you will notice the dynamic advance value is 10. What you can't see in the log is the value of 8.83 in the primary ignition table. This should provide total advance of almost 19 degrees but as you see in the log, I am only getting 15.5. There is apparently some other map affecting the mix. Anyway, I was able to get closer to 18 degrees of advance from increasing fuel to 10.8/1... strange indeed
Old 09-30-2006, 09:31 PM   #10
kcook
Member#: 78074
2005 STi
i topped out my 4th gear the other day , 120+ @ 6.5k
kcook is offline   Reply With Quote
Old 09-30-2006, 09:36 PM   #11
TurboQueef
Member#: 86700
2005 STI
Hum... you have an STi ?... My STi will top out at 88mph @ 6748RPM in 4th... whats up??????????
Old 09-30-2006, 09:38 PM   #12
TurboQueef
Member#: 86700
2005 STI
That's funny.. did you catch the Queef's in the video?
Old 09-30-2006, 11:48 PM   #13
bastich
Member#: 57276
2004 STi
Maybe he is refering to his evo3?
Old 10-01-2006, 10:18 AM   #14
kcook
Member#: 78074
2005 STi
no i have a wrx / longer gearing in the wrx
Old 10-01-2006, 12:00 PM   #15
Caplin 2.5
Member#: 71203
2005 2.5rs
OHH i listened to it again and heard the BOV, but the first time i listened to it i was listenin to music so i could only hear the car not the bov. hahah that cleared up the turboqueef for me! Can't wait till my car queefs.
Old 10-01-2006, 12:36 PM   #16
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Yea a 5spd wrx will hit ~120 in 4th, almost 130 if you take it to 7200 I believe.
Jeff
Old 10-01-2006, 04:20 PM   #17
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
omg.. that thing looks like its going through a school zone through every gear. i can literally read the numbers/names on the mail box when you pass by at ~10mph...
i hope its just the camera/sound thats off.
-alan
XS_WRX is offline   Reply With Quote
Old 10-01-2006, 04:21 PM   #18
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
~v6
V6TurboTA is offline   Reply With Quote
Old 10-01-2006, 04:43 PM   #19
josh04
Member#: 89288
2002 Rex
How come on your site your ingition timing looks so jacked up? Is it just me? But when i tune I street tuner I try to get to it to gradually fall in timing until I get past the max torque area when the engine load lvls out then I add more timing.
josh04 is offline   Reply With Quote
Old 10-01-2006, 05:20 PM   #20
flwrx
Member#: 35944
'03 6MT WRX
MBP
you stole my gauge setup!
except I put the XD-1 in the middle with Greddy gauges on each side.
flwrx is offline   Reply With Quote
Old 10-01-2006, 06:26 PM   #21
mikaust
Member#: 7468
I dated many girls that queefed better than that. Is it me or does it just look slow?
mikaust is offline   Reply With Quote
Old 10-01-2006, 06:42 PM   #22
Freon
Member#: 88322
2009 BMW 135i
It seems like you're running right now to 10.2 AFR before you even hit peak torque. Perhaps in the 5-10psi range?
You should be able to get your AFR table to match what is actually happen if you calibrate your MAF scaling. On your website you posted your fuel map, but you seem to be hitting almost a full point or more richer than your table. This probably means you need to lower your MAF g/s values in your MAF table. Keep in mind this will affect the load for your timing table as well.
Freon is offline   Reply With Quote
Old 10-01-2006, 07:04 PM   #23
josh04
Member#: 89288
2002 Rex
I wouldn't mess with your intake. Because all of streettuner is like that. At least the couple of cars I ran into plus mine. And if messes with that then he has to rescale his load and make a new base map for his timing to run right. Same with his Dynamic advance.
Old 10-01-2006, 08:56 PM   #24
TurboQueef
Member#: 86700
2005 STI
I agree, no messing with the intake cal... I just deal with it being off a tad
Old 10-01-2006, 09:00 PM   #25
V6TurboTA
Member#: 9090
09 Forester Gump
Your SN is quite stupid.
~v6
Adviced Needed: 07 USDM STi Stg2 Master Map 4th Gear Pull Linkseal Open Source Reflashes 15 08-14-2009 11:55 AM
4th gear pull/Cobb vf34 93 oct dcdub23 AccessPort 4 04-28-2006 06:36 PM
Trying to explain a video game to my wife... who hates video games... Asinine Off-Topic 4 08-31-2004 06:10 PM
slight bucking 4th gear pull mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-12-2004 12:21 PM
overseas dyno differences: 3rd vs. 4th gear pulls annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-25-2002 03:53 PM
