Old 09-30-2006, 08:04 PM   #1
MaestroB
Member#: 101687
Question Power output of stock stereo?Direct speaker replacement options?
Just got an '06 WRX wagon. I'm considering upgrading the speakers. I really don't want to change anything else. Spoke with crutchfield. Rep said that I needed to confine my search to speakers that only required 2 watts because the factory head unit only puts out 2 or 3. The speakers I found that I would like to get require 6 front and 4 rear. Was he right about the factory unit's output? Anyone have recommendations for replacements? Thanks.
MaestroB is offline   Reply With Quote
Old 09-30-2006, 09:26 PM   #2
LastResort
Member#: 99289
He's full of ****. The stock stereo doesn't do much, but it's a lot more than 2 Watts. What speakers did you find, sensitivity is more important that most people think, and will tell you what you should expect out of speakers.
LastResort is offline   Reply With Quote
Old 10-01-2006, 11:09 AM   #3
beanders
Member#: 63351
2006 Forester LLBean
Green
In additon, speaker power rating is more of an issue in overpowering than underpowering. Yes, if you hooked up a 200watt speaker to a 10watt amplifier it may not produce sound as well as a 50watt speaker, but that ties into the first reply. Look for speakers with over 90 signal-to-noise ratio s/n.
beanders is offline   Reply With Quote
Old 10-01-2006, 12:48 PM   #4
MaestroB
Member#: 101687
The speakers I was interested in were the Polk db650 for the front and the Polk db400 for the rear.
Old 10-01-2006, 12:58 PM   #5
LastResort
Member#: 99289
I think a number of people have run those on the stock deck no problem.
Old 10-01-2006, 12:58 PM   #6
aikido
Member#: 73554
2006 WRX Wagon Stg 2
I have Blaupunkt Overdrives in mine. I think the PCx series fits also. Can't beat them for the money for a stock system. Should you decide to replace the stock system and amp everything - which you should - the Overdrives can blow if you turn up the bass setting too much. Then again that's what subs are for
aikido is offline   Reply With Quote
Old 10-01-2006, 01:03 PM   #7
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
I would say the stock radio is closer to 15w-20w. Polk DB speakers will run perfectly fine as they are a pretty effecient speaker.
4EVO2NV is offline   Reply With Quote
Old 10-01-2006, 02:05 PM   #8
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Maybe max for that wattage. Id say 10w RMS, but thats a big maybe.
cucamelsmd15 is offline   Reply With Quote
Old 10-01-2006, 02:18 PM   #9
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
+12345
02BlueSuperRoo is offline   Reply With Quote
Theoretical power output of a td04 Dubstar112 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-10-2010 04:23 PM
Reasons you kept the stock stereo and speakers chimchimm5 Car Audio, Video & Security 42 08-03-2007 12:11 PM
FS: '04 WRX or STi stock stereo & speakers jnmarshall Private 'For Sale' Classifieds 7 11-22-2003 07:41 PM
What sux: Stock Stereo or Speakers (Upgraded)? 25psi Car Audio, Video & Security 2 03-29-2001 04:33 PM
What's the power output of the new H6? MrSube2pt5 General Forum Archive 4 11-25-2000 11:06 PM
