Old 10-01-2006, 09:36 PM   #1
SMUwrx34
Member#: 98299
2005 STI
White on Black
Default Over heating problem.
Well my car has 57,xxx miles and I just started to experience over heating problems. I was just driving then all of the sudden my temp went from normal to the middle of the H in about 2 seconds, and it started to smoke, fluids were everywhere. I filled it with water and all was good then I started it up and it ran fine and then when I tried to drive it, it slowly started to over heat. Fluids were still there and didn't come out again. When it idles it slowly creeps down back to normal, but once I take off it goes back up. So I pull over and let it cool down, then I drove some more. Every once in a while, it would hold for a good minute then FLY to H, thinking it is the thermostat, but not sure. Can someone help me out? First thing in the morning I am heading to SoD which is about 6 miles from where I live. Check engine light just popped on too.
SMUwrx34 is offline   Reply With Quote
Old 10-01-2006, 09:44 PM   #2
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
thermostat. I dunno why but i hear these freakin things go out a lot. my friend had one g out and so did i.
OneArmedScissor is offline   Reply With Quote
Old 10-01-2006, 09:48 PM   #3
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
First of all, I wouldn't continue to drive it, you might cause further damage, if you haven't already.
It might be a thermostat, or you might have a leak somewhere. Do you smell coolant?
RexyGirl is online now   Reply With Quote
Old 10-01-2006, 09:53 PM   #4
SMUwrx34
Member#: 98299
2005 STI
White on Black
I smell coolant, but that is from the first time it flew everywhere. Other than that, it is holding coolant and also still at the same level I put it at.
Old 10-01-2006, 10:12 PM   #5
SMUwrx34
Member#: 98299
2005 STI
White on Black
Another weird thing is my heater is blowing cold air, like blowing like the AC when the extra cooler thing is turned off.
Old 10-01-2006, 11:58 PM   #6
SMUwrx34
Member#: 98299
2005 STI
White on Black
Well I just got off the phone with my mechanic and he said it could be the thermostat or the water pump since my heater only blows cold air.
Old 10-02-2006, 12:06 PM   #7
SMUwrx34
Member#: 98299
2005 STI
White on Black
Well SoD just called, I blew a radiator hose. Thanks God it wasn't anything major.
Old 10-02-2006, 02:22 PM   #8
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
could have been worse. What you were describing almost sounded like and internal headgasket leak.
but just a rad hose is a good thing. Losing coolant means obviously the system is low. Warm coolant travels through the heater core which heats the air to the passanger compartment. Lose your coolant, lose your warm air.
Mavrik is offline   Reply With Quote
Old 10-02-2006, 02:36 PM   #9
SMUwrx34
Member#: 98299
2005 STI
White on Black
I got hooked up with a 2007 Outback with 580 miles on it as a rental!
over-heating problems alejo Normally Aspirated Powertrain 1 05-04-2009 04:23 PM
AVIC Z2 over heating problems turf812 Car Audio, Video & Security 3 05-31-2007 04:40 PM
Over heating problems. SMUwrx34 Texas Impreza Club Forum -- TXIC 9 10-02-2006 01:42 PM
I really hate over heating problems... pilfflip Legacy Forum 8 09-15-2006 03:58 AM
Over Heating Problem akuhner Normally Aspirated Powertrain 24 12-28-2000 06:45 AM
