Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 11-05-2001, 12:02 AM   #1
wagonbeast
Member#: 10362
WRX 03>04Rallystylz
+ 02 F150 6 cyl 5 speeed!
Default a/f ratio o2 sensor meter tap apex tt
Where on the ecu do i tap for my turbo timer's air/fuel ratio meter. I guess it is the front o2 sensor but it reads 2+ volts and my turbo timer calculates based on 0 to 1 volt. Also where do I ground the tt
wagonbeast is offline   Reply With Quote
Old 11-05-2001, 01:38 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
May I assume that you're aware of the 2002 WRX ECM wiring description at http://www.northursalia.com/m...in/wrxpin.html? Then you'll have to splice into the rear O2 sensor's signal (B17) since, as you've observed, the US WRX's front A/F sensor is incompatible with your A/F gauge. Grounding possibilities are too numerous to mention.
Jon [in CT] is offline   Reply With Quote
Old 11-05-2001, 10:14 AM   #3
Hyperdash
Member#: 8577
2002 wRx wHiTe OnE
AsPiRiNg I-cLuB RyCeBoI
i have the exact same TT as you, tap the a/f line into b17(white) and the ground into b19(green/red)
Hyperdash is offline   Reply With Quote
Innovate Wideband Gauge Air Fuel Ratios O2 sensors BigValleyPerformance Gauges & Electronics 1 09-23-2008 03:14 PM
Which o2 sensor to tap? markeddy Electrical & Lighting 7 03-28-2007 05:46 PM
Front O2 sensor tap size jpmarotta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-03-2004 02:33 PM
Apex TT Q's....A/F, O2, etc. Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-01-2002 02:13 AM
O2 sensor location and wire to tap for AFR? camz911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-11-2002 05:22 PM
