Old 11-04-2001, 11:03 PM   #1
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
Default TURBO questions
ok i just did a search and came up with nothing that was important.. so here it is.. wat do i need to run a decent amount of boost.. around 9-10 psi of boost with a 2.5 rs? wat about if i wanted to boost higer... around a bar? dont mean to sound all newbie.. but just asking ... or can u guys give me otehr sites or "key words" to search?
scoobyimpreza is offline   Reply With Quote
Old 11-04-2001, 11:37 PM   #2
kaos200
Member#: 2692
did you search THIS site?
kaos200 is offline   Reply With Quote
Old 11-05-2001, 12:56 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
lol... try another search there is tons of good stuff. to point you in the right direction search: compression, fuel, turbo, safe, etc.
Eric
Eric SS is offline   Reply With Quote
Old 11-05-2001, 12:59 AM   #4
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
thnx thats all i needed
Old 11-05-2001, 01:11 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
np
Eric
Old 11-05-2001, 02:12 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Why are all the newbies focusing on how much boost they want instead of how much power they intend to make?
Ben
bsquare is offline   Reply With Quote
Old 11-05-2001, 02:14 AM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Good question... If they focus on boost, they will end up like me
Eric
Old 11-05-2001, 02:16 AM   #8
kaos200
Member#: 2692
Ben
dunno, maybe they like to say they are running 10psi (on a tdo4 and in actuality making the same amount of power as someone else running 5psi on a t3)...
(not actual numbers, duh).
after all doesnt it just sound cooler!
Old 11-05-2001, 02:29 AM   #9
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
actually its true... a lot of honda guys ask me how much boost i'm running.... it confuses me... you didn;t even ask what turbo i had..???
HOK is offline   Reply With Quote
Old 11-05-2001, 02:32 AM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
10psi on an EJ25 would be an awesome amount of boost but 10psi on my EJ22T would be junk. You guys are definetly right that boost is the last of the worries. However, most braging rights come from boost for some reason
Eric
Old 11-05-2001, 02:35 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yes...but someone runnin 10PSi of boost ona 8.0:1 car with a TD04 or a VF-22 wouldn't compare to someone running 7 psi on a 10.0:1 car....MUHAHAA!!!!!!!!!!!!!!!!!!!!!!!! Numbers mean nothing!!
Sorry end rant...that's cause it's bragging rights...personally i'd liket o say i run 3 psi and i still BLEW YOUR DOORS OFF!!!!!!!!!!!!!!
Jeremy
Old 11-05-2001, 02:48 AM   #12
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
sorry that is wat i mean.. i rephrase it ....wat whould i have to do to run (well just say 10psi) on a t3 turbo system... and how much power would i be expecting? am looking for something in 280-300 area someday... yea not now just someday.. am not some wanna be that thinks he can get 300hp without trying... i mean wat kind of enternal work would have to be done? and putting headers on a turbo car is impossible for these cars right(not sure used to be a honda person which couldnt) iono
also wat is teh stock dyno of a 02 2.5rs? with out making it s 2 wheel drive i hear its around teh number of 95 that is horrible that is like a 40%lost in power,o well... lets see i have about 3gs saved up from working.. i was think of getting a
-cobb intake
-cobb cams
-scooby sport exhaust with 2.25 or 2.5 inch pipping(unless u know a better one?)
-new ecu looking at tech II ecus
-some kind of pulleys (any sugestions?)
please be kind i am a newbie on subies but am learning
Old 11-05-2001, 02:57 AM   #13
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
If I recall that 95hp figure came at some fairly high altitude. Think more in the 120ish range. 300hp is a reasonable goal with what you've got listed below, but if you're shooting for 5+ psi of boost, your clutch is going to start wearing out much more quickly. If you get a clutch that will handle 300+ hp you're going to be putting your transmission on the line... it's not a guaranteed failure thing... there are people who're running that kind of power on the stock gearbox, but there are also a great number who have splintered gears. Basically, following the recipie you've got below, a well tuned 7-9 psi of boost will put you where you're looking to be.
Darshu is offline   Reply With Quote
Old 11-05-2001, 03:01 AM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
The problem with our cars is no one ever knows what the weak link is in any particular car. One person might blow a tranny while another with the exact same setup will blow a piston, and even another will run fine. it's a toss-up unfortunatly.
However, one thing is for certain. 300hp will be way to much for the stock clutch, blow up the tranny, and destroy a piston
Eric
Old 11-05-2001, 03:05 AM   #15
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
Old 11-05-2001, 03:05 AM   #16
bsquare
Member#: 1911
2000 Impreza 2.5RS
You can get 280-300 _to the wheels_ with less than 10psi on a stock EJ25.
Ben
Old 11-05-2001, 03:05 AM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
imprezinator is right....each car has it's own weak link. if you are aiming for 300 HP get ready to spend some tall cash....IIRC the 4wd seal level dyno got about 111 Horse to the wheels....remember AWD=higher driveline losses. takes more power to feed 4 wheels rather then 2.
Jeremy
Old 11-05-2001, 03:10 AM   #18
bsquare
Member#: 1911
2000 Impreza 2.5RS
Please differentiate whether you are seeking 300hp at the crank or at the wheels. Big difference.
Ben
Old 11-05-2001, 03:14 AM   #19
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
to the wheels....
Old 11-05-2001, 03:19 AM   #20
bsquare
Member#: 1911
2000 Impreza 2.5RS
Get real engine management and you can do that on your current motor.
Ben
Old 11-05-2001, 03:22 AM   #21
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
engine managnement wat do u recomand and how much? could i get a web site to..
Old 11-05-2001, 04:44 AM   #22
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
man you guys should open a chat room... hahahahah
anyways many of the answers you seek you need to specify what type of DIY tuning you can/be willing to do or learn... also the goals of the car... budget etc.... there are already people doing it in a variety of different ways... I am a budget, average DIY tuner, daily driver ~300 to the wheels... ie... i use the unichip and can tuning it myself... but i'm going to take some time before going TEC 2 or 3... I blew a piston.... and what a lesson it gave me...
Old 11-05-2001, 05:13 AM   #23
bsquare
Member#: 1911
2000 Impreza 2.5RS
I use the TEC-II kit from Vishnu .
As always, speed costs, how fast do you want to go?
Ben
Old 11-05-2001, 05:23 AM   #24
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
yea yea... i know... but just wondering if it could be done....
Old 11-05-2001, 06:22 AM   #25
bsquare
Member#: 1911
2000 Impreza 2.5RS
It can with a dyno, somebody who _really_ knows what they're doing, a lot of patience, and a little luck. The high output coils, high resolution crank angle sensor, and integrated control of the TEC-II and similar systems give them a distinct advantage over even advanced piggybacks, like the Unichip.
Ben
turbo, EWG and Turbo question silver_rocket Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-15-2007 06:47 PM
2 questions- 1) sti sb question 2) bigger turbo question legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-23-2005 05:43 PM
newbie with a question...2.5rs turbo question...which ones???? QCK HNDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-03-2001 08:10 PM
Quick turbo question IMPBOY Bay Area Impreza Club Forum -- BAIC 3 06-02-2001 10:55 AM
Turbo Question for all you turbo people out there Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-14-2001 01:30 AM
