#1 |
Member#: 67216
Here's the scoop:
In April of 2005(at 59XXX miles) I took my 2003 Legacy Outback Sedan(VDC) to Jim Reed Subaru in Nashville,TN complaining the transmission was slamming itself into gear under stress. By stress I mean either with the car loaded with people/gear or at interstate speeds(with just me) and you hit the throttle to shift it down, the vehicle would shift itself out of gear, the tach would almost hit redline, then it slammed into gear. The dealership said they checked out the car but found no problems. In the mean time I found if I manually downshifted the car it would shift normally. April of 2006(at 96XXX miles) in Atlanta I hit the gas to shift down to pass someone on I-75 and the vehicle stutters. I pull the shifter back and it still won't shift down. If I pushed the gas to speed up it would try shifting and would slow down more. It was too late that day so I took the car to Royal Subaru of Decatur,GA the next morning who also couldn't find anything wrong. I even had them flush the transmission(for $140) to just to make sure. I also complained of a loud whining/whirring(like gears make when they're not being lubricated properly) and they told me it was a pinion gear making the noise and it was going to cost $1500-1800 to pull the transmission and replace it. I declined. In the mean time the transmission started shifting semi-normally again. September of 2006 I pull out of my driveway and the car is barely moving. The tach is rising but it's not gaining any speed. It barely makes it back to my garage and the CEL comes on. I tell some coworkers about what happened and they suggest climbing under the vehicle to check for leaks. I also planned on changing the AT Filter to see if that was the problem and had obtained the Subaru Technical Manual, but when I looked for where the filter should be I just found a metal cap. Also the "whine" I mentioned earlier was actually a blown CV joint. Where the left front axel goes into the case there's grease everywhere. The other side is clean. I immediately called SOA to report the issue. Here's my problem: A) I took it to two dealerships complaining of transmission troubles. Neither found a problem and I didn't happen to notice at the time but the in/out mileage at the top of the invoice is the same(which means it never was test driven) at both dealerships. It says clearly on the invoice from Jim Reed that I was reporting the vehicle not shifting properly out of passing gear. B) There is a cap where the AT filter is supposed to be. From what I can find in the technical manual the transmission only has an external spin on filter. The technician at Subaru of Cool Springs in Franklin, TN(where I had it flatbedded to) says the AT doesn't need that filter. SOA disagrees but doesn't seem very willing to help with the issue. They said there was nothing they could do and I'd have to take legal action against the dealership I thought was at fault as it was "workman error". Since then I offered to fax them the invoices from the dealerships and pictures I took and they said they'd see what they could do. The only time the transmission was opened up was when I had the parking pawl recall performed on March 2003(at Jim Reed) which SOA admitted they would have had to put the metal cap on the transmission at that point to work on it. However they are saying the transmission would have had to of been serviced sometime between then and the first complaint as there's no way the transmission would have worked that long with the cap over the AT filter spot. I could really use some advice. Am I going to have to get a lawyer? Will SOA help? Is fighting either going to help or should I just suck it up and pay the $2800(quote from Subaru of Cool Springs) to have a reman'd transmission put in? I personally feel this is gross negligence by either or both dealerships for not noticing the AT filter cap, CV joint, and not test driving the vehicle to see if they could recreate the problem. I love the car but this has seriously killed my faith in Subaru. -Daniel
#2 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
Have you spoken to the dealerships that performed the services yet?
#3 | |
Member#: 67216
-Daniel |
#4 |
Member#: 103068
SCIC
This is why I am not a fan of dealerships. Many people will say that dealerships do the best work, I disagree with this. The dealership employs people just like anyone else to do the work and they make just as many mistakes as anyone else. The lube rack guys are usually a joke, right out of school and responsible for the some of the most important things on your car... making sure the wheels are tight and the right amount of oil is in the engine...and even that is usually too much to ask.
#5 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! '95 Montego Miata |
Also, you didn't mention any past normal AT service dates/mileage/service done. |
#6 | |
Member#: 60976
SWIC
Vehicle:1969 LGT FATURBO |
#7 | |
Member#: 67216
According to SOA the only time the cap is used is when the transmission is being worked on and the only intrusive transmission maintenance was performed by Jim Reed. Not to mention the vehicle was already in bad shape by the time it made it to Royal Subaru. -Daniel |
#8 |
Member#: 60976
SWIC
JIFFY LUBE has been known to drain tranny fluid instead of oil.
#9 | |
Member#: 103068
SCIC
Sorry to the OP for babbling on your thread. |
#10 |
Member#: 60976
SWIC
i think were the only subie dealership where everyone in service owns subies...
#11 |
Member#: 85613
So, you put on almost 40k a year, and you have never changed the fluid? I don't care what your manual says, no fluid lasts forever. You say you regularly inspect it, and it was always fine? What are you basing your conclusions on? Do you have a lot of transmission repair experiance?
Im not trying to be a dick, but when you take it upon yourself (at best a "shade tree mechanic") to do all of your maintenance, then you can only blame yourself. In short, you have no leanghty service history at any dealership, and your almost 40k outside of your powertrain warranty. Why in the world would the dealership, or SOA go out of their way to help you out. FOOD FOR THOUGHT: This should be a lesson to you in reasons to go to a dealership. Your "Tinfoil hat" reasons for not servicing it with a dealer, will never negate the fact that in situations like this, your dealer may be your only friend, and the only one willing to help you out. |
#12 |
Member#: 60976
SWIC
yeah most people neglect all of the "other" fluids. they tend to only change the motor oil. part of our 30k is a tranny flush. so at 90k u shoulda had 3 of them already. some might think that it is overkill, but those arent the people that are have problems... so ive noticed. See me now or see me later... its all the same to me, Its just going to be a lot more expensive later.
go A's |
#13 |
Member#: 1714
RMIC
Vehicle:1999 RS-T COUPE Black |
your trans filter is in the left front fender panel due to the fact your vehicle is a 6 cylinder. The cap is supposed to be there.
| Thread Tools | |
| Display Modes | |
| Transmission Dead? | Sleepysub | Transmission (AT/MT) & Driveline | 1 | 03-26-2006 08:18 PM |
| Transmission Mount/Dealer Bull | siperwrx | Warranty Issues & SOA Problems | 3 | 02-04-2005 11:04 PM |
| HELP!!!!! car dead.... | geronimo66 | Mid West Subaru Owners Club Forum -- MWSOC | 8 | 08-19-2003 08:28 PM |
| ('93-'01) troubleshooters help car dead!! | philo2g | Impreza Forum | 8 | 12-20-2002 04:09 PM |
| Help installing dead cow mod | monovich | Southern California Impreza Club Forum -- SCIC | 33 | 02-10-2002 11:13 PM |
