Old 10-02-2006, 12:50 PM   #1
AspenGC8
Member#: 62280
2011 WRX Sedan
Default Problem pumping gas & CEL P1443
I have a p1443 code (vent control solenoid). When I try to pump gas, the handle clicks like the tank is full, but its not even close. It clicks as soon as I pump for a couple seconds. Im guessing something is clogged. Where should I start checking for clogs/problems. I went to the dealer once, and he said the solenoid was fine, checked the wire for voltage, which was good, then said there was no ground. I found that hard to believe... and then the started leaning towards a new ECU. Car is not under warranty, so where should I start checking?
AspenGC8 is offline   Reply With Quote
Old 10-02-2006, 05:30 PM   #2
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Why is it not under warranty? Are you already over the miles?
Mika
finnRex is offline   Reply With Quote
Old 10-02-2006, 05:55 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
In the old days, gas tanks vented directly to the outside air. Nowadays, to minimize pollution, the tank vents through a charcoal canister which absorbs and stores the gas fumes. At certain times when the engine is running, lines are opened to suck the gas fumes out of the canister into the engine and burn them. Presumably your code relates to this system of solenoids controlling the flow of fumes to/from the canister. My guess is that the system is stuck in "burn off" mode, with a valve/solenoid closed blocking the gas tank from venting into the canister. I'd try to get a hold of the shop manual emissions control section for your year.
If you've got the problem whenever you try to fill up with gas, that should be something a dealer can work with. Perhaps a visit to an independent Subaru-specialist mechanic is in your future?
Old 10-02-2006, 06:01 PM   #4
AspenGC8
Member#: 62280
2011 WRX Sedan
Good info armand1. Im checking out a 2004 STi service manual. Its a salvage title, so dealer maintenance is out of the question. From looking at the plumbing for the Evap system.. It looks like either a bad vent solenoid, which vents the pressure/fumes from the gas tank then to the charcoal box...or the gas tank pressure sensor. Whichever it is, I think the vent is caught closed, forcing me to do battle with gas tank pressure as I pump gas. I can let it drizzle in, but wont pump full blast.
Old 10-02-2006, 08:48 PM   #5
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Opie is offline   Reply With Quote
Old 10-02-2006, 10:34 PM   #6
AspenGC8
Member#: 62280
2011 WRX Sedan
Thanks Opie, I will check those tomorrow!
6262sp STi [email protected] with problems up top...420whp pump gas...Dyno vid & slips inside! JeankySti Proven Power Bragging 22 01-05-2010 07:39 PM
ICS Project '08 STI - new dyno best - 529 WHP on Pump Gas & Meth ! Dyno Flash Proven Power Bragging 52 02-29-2008 09:03 AM
Problem pumping gas with 06' STi!! AspenGC8 General Community 33 05-01-2006 05:22 PM
Can't pump gas and CEL (vent control solenoid fault) Swanny General Community 0 07-28-2005 05:46 PM
Can't pump gas and CEL (vent control solenoid fault) Swanny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-15-2005 12:00 PM
