Old 10-02-2006, 03:55 PM   #1
SubyWRXSti
Member#: 79008
2006 Blitz STI
WRB INGS+1
Default Hub centric Ring needed for Volks CE28N?
Just wondering if it's necessary to get hub centric rings for Volks CE28N?
I have a set of these rims on my car right now, it didn't come with the hub centric rings.
I was reading some forum it says that some wheel without Hubcentric rings could produce vibration.
SubyWRXSti is offline   Reply With Quote
Old 10-02-2006, 08:09 PM   #2
littlewhitewagon
Member#: 103068
11 STI sedan
you should get them if the center bore isnt sized for your hub...which it most likely isn't. the other thing it helps with is to not scratch the wheels when you put them on. the hub ring will hold the wheel in the right spot so you can put on your lug nuts easier. the rings are so cheap, you can't not get them.
littlewhitewagon is offline   Reply With Quote
Old 10-02-2006, 09:47 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
yes they need them- they come w/ them new
Old 10-03-2006, 12:44 PM   #4
SSIXProject
Member#: 121146
'06 STi
you'll need a 73mm-56.1mm hub ring. Most places sell them for 5-10 bucks... one of the best things you can do to insure a quality ride.
SSIXProject is offline   Reply With Quote
Old 10-03-2006, 04:30 PM   #5
SubyWRXSti
Member#: 79008
2006 Blitz STI
WRB INGS+1
^^ Any idea what's the exact size for 06 STI Hub?
The rim is CE28N 18x8.5.
Old 10-03-2006, 04:48 PM   #6
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
I have the rings on my rims (they come with the rims new) but i'm not 100% sure of the exact size the rings are, I once measured the rings and it wasn't 73 thats for sure, it was more like 60 something and it wasn't a very common size.
subaru is 56.1 for all cars.
dan avoN7 is offline   Reply With Quote
Old 10-05-2006, 09:46 AM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
Mine are 65x56.1 these could possibly vary by wheel size- I'd call Mackin to be sure. I do know that it's not a really common size and are somewhat hard to source- Mackin may be able to source them as well.
Old 10-13-2006, 06:42 PM   #8
SSIXProject
Member#: 121146
'06 STi
sorry to chime back in so late but, Volks run two center bores, a 73mm center bore and for those who run the bolt pattern of (x)x100, the center bore is 65mm.
Old 02-20-2007, 12:06 PM   #9
prototypeWRX
Member#: 78739
2015 WRX
Question
Where can those(65x56.1) be ordered? My set of CE28N's that I just got didn't come with the rings. Mackin said they don't sell/carry the rings when I called and they were unable to direct me to anywhere that does...
prototypeWRX is offline   Reply With Quote
Old 02-20-2007, 04:21 PM   #10
tegnwrx
Member#: 8589
tegnwrx is offline   Reply With Quote
Old 02-20-2007, 08:38 PM   #11
BIGSKYWRX
Member#: 7958
09 GH B+
first check the bire of the wheel- Volk uses a couple of different sizes- one is in the 70ish something range
Here they have a long list, but not 65mm, but they do have 66mm- I've measured mine several times and come out w/ 65mm, but the 66mm may work fine
http://www.1010tires.com/hubrings.as...FQchggod0C7jlg
Old 06-20-2008, 03:53 PM   #12
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Does this mean that my 17x7.5 Volk LE37k's have a 73mm bore as well? If so then that means I need 56.1mm by 73mm hub rings for my 2002 WRX, correct?
Please Help!
-Glen
GlenCastleberry is offline   Reply With Quote
Old 06-20-2008, 04:16 PM   #13
mr_hann
Member#: 165244
2007 2.5i
try tirerack or discount tire. or even ebay. I bought a couple of set off ebay awhile back, but for a toyota.
Please Help!
-Glen
It looks like you need 65x56.1
mr_hann is offline   Reply With Quote
Old 06-20-2008, 04:43 PM   #14
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Where'd you obtain this information? I have been searching forever, both on google and on the NASIOC boards, but to no avail.
Old 06-21-2008, 02:38 AM   #15
Philip Klotz
Member#: 79317
2004 Porsche 911 GT3
2004 STI destroyed, RIP
Call Vic at Discount Tire in El Monte, Ca. He has enough hub rings for everyone on Nasioc, in both metal and plastic. He also drives a WRX with a zerosports bodykit. Sorry don't have phone #. That's where I get mine from.
You can also call Francis at A-Spec also in El Monte. They stock some from Mackin, but charge for a set, I beleive it's $50, but don't quote me. He had sti powered GC 4door so he is also familiar with what you need.
By the way, there have been threads saying hub rings are useless. you will get severe wheel wobble if you rely in centering the wheel on the studs.
hope this helps
Philip Klotz is offline   Reply With Quote
Old 06-28-2008, 08:10 PM   #16
Rodwrx23
Member#: 170948
Hey guys. I've been trying to get a hold of some hub rings for my 18x7.5 GT-P's. I can't take my rim off right now because I sliced my hand up pretty bad so I tried measuring as best as I could and I got about 62mm +/- 1 or 2 mm.
I found these
http://www.ravspeconline.com/shop/ca...nufacturers_id=
What do you guys think?
Rodwrx23 is offline   Reply With Quote
Old 06-29-2008, 09:29 AM   #17
BIGSKYWRX
Member#: 7958
09 GH B+
often the bore is stamped into the wheel or on a decal inside the wheel, I'd look and see if you can find it
Old 07-02-2008, 02:42 PM   #18
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Okay so apparently I need 65mmx56.1mm hubrings. Is there any manufacturer that has this size in stock, because I have searched and searched the web and have found none. Someone mentioned that Vic at Discount Tire in El Monte might be able to fabricate some for me, but does anyone know of any sites that carry the 65x56mm size?
Thanks!
-Glen
Old 07-03-2008, 07:44 PM   #19
BIGSKYWRX
Member#: 7958
09 GH B+
I bought two sets w/ my old Volks and still have a set left or you could call Mackin and see if they can get them
Old 07-06-2008, 03:28 PM   #20
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Thanks BIGSKYWRX, but I found a set a few days ago!
Old 07-06-2008, 04:33 PM   #21
BIGSKYWRX
Member#: 7958
09 GH B+
good deal
hub centric rings needed? haberkorn Tire & Wheel 6 03-20-2009 07:34 AM
MY04 STI Hubcentric ring size for Volk CE28N Imprezha Tire & Wheel 15 04-10-2008 08:25 PM
Hub centric ring, needed? aakrusen Tire & Wheel 2 11-18-2006 06:41 AM
Where to get hub centric rings and center caps for Volks? Got Pink? Tire & Wheel 0 11-02-2005 10:43 AM
Hub centric rings needed subywrx Tire & Wheel 9 09-01-2005 03:55 PM
