Old 10-02-2006, 09:54 PM   #1
02subieRS
Member#: 121357
2008 impreza 2.5i
Default parking light help
well one of my sidemarker lights are out and the service manual says that i have to remove the headlight to change it and i was jus wondering if there was an easier way to change it. and another thing....i disabled my drl's and want to know if anyone is goin to say anything when i get my car inspected.
than you
02subieRS is offline   Reply With Quote
Old 10-02-2006, 10:33 PM   #2
rkramer
Member#: 118209
2002 WRX Sedan
you can pop the sidelights out very carefully with a screwdriver, but you risk scratching the paint. it is VERY easy to remove the headlight. (i cleared my '02 headlights last night, removing the headlights took maybe 10 minutes and I had no clue going into it)
pop out the grill, remove the plastic piece beside the grill, remove 3 screws, and the headlight slides forward.
Old 10-03-2006, 11:11 AM   #3
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
DRL's do not have to be on while going thru inspection, as long as all lights work there should be no problem.
If you are still a bit worried about it, turn all your lights on just as you get near the inspection site.
joecerv is offline   Reply With Quote
Help! Side markers and Parking lights not lighting up...? stevey323 Electrical & Lighting 1 03-25-2008 02:04 PM
running or parking light help! anthony_delprete84 Electrical & Lighting 5 11-12-2005 06:22 PM
Errr...Parking light help CatchME Electrical & Lighting 3 10-19-2002 05:36 PM
Need quick Help! Parking lights won't turn off Conduit Factory 2.0L Turbo Powertrain 8 10-13-2001 11:31 AM
Help! WRX Factory Alarm - Parking lights on / off?? webkris Car Audio, Video & Security 5 04-20-2001 05:31 AM
Message Board Statistics All times are GMT -4. The time now is 06:42 AM.
