Old 11-05-2001, 06:36 AM   #1
initialx
Member#: 10007
02 Impreza WRX
Default removing a wire from the connector??
Hi,
is there a special device to remove a wire from the connector,ie
pulling the wire and the metal clip from the connector.
thanks,
initial
initialx is offline   Reply With Quote
Old 11-05-2001, 09:11 AM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
Try a very small flatblade screwdriver. Shove it in one one side of the metal clip, then try the other side of the clip if that doesn't work. You're trying to push a plastic tab away from the metal clip, so you can pull the metal clip out.
Rocky WRX is offline   Reply With Quote
power wire from the battery to the firewall higgins14 Car Audio, Video & Security 8 07-02-2007 11:40 AM
Remove my ex from the title/mortgage BhamRoadrunner Off-Topic 12 03-13-2007 01:28 PM
Running wire from the Engine bay to drivers side. BlackEyeII Electrical & Lighting 5 07-26-2004 06:48 PM
Vote to remove Subaru Owner from the Community. shoracer Off-Topic 8 12-10-2003 04:20 AM
Q: How to remove shaved bolt from the engine mount? 02WRX_BLUE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2002 03:24 PM
