Old 10-04-2006, 12:03 AM   #1
WRblueX_Guy
Member#: 53247
Default '05 STi Cluster swap into '05 WRX - need actual install instructions
I am trying to install an '05 STi gauge cluster into my 2005 WRX.
I took out my factory cluster, and tried to install the STi cluster.
First thing I noticed when looking at the plugs/connectors...the connectors on the STi cluster for the Speedometer and tachometer are mounted backwards compared to my WRX cluster. They still plug in fine, just backwards. The connector for the fuel/temp. is different, and won't plug in at all. I have heard you need to shave some latches off the plug to make it fit. I have not tried to make it fit, yet.
After plugging in the speedo/tach and turning the ignition on, the cluster turns on and does the sweep. Then it has that continuous beep/buzz noise.
Originally Posted by le wagon View Post
ok.. i installed an 05 sti cluster into my 05 wrx... used the sti left side wires for the gas/temp. that works fine.
i cut c28 and c30 so i didnt short out the radio..
the only problems i have now are the loud beeping noise, the ebrake, and the check engine light.
what wire do i need to cut to turn the beeping off? also for the ebrake?
ok i found out that C9 stops the buzzing.. but what about the ebrake light?
Do I have to cut any of these wires above? And a Scoobymods how-to says to cut pin B28 if you are not concerned with the outside air temp.
Can anyone please tell me which wires I need to cut in order to get the cluster working properly? And can someone confirm that the speedo/tach connectors being backwards are not a problem.
I want to get it working before I send it out to get the odometer calibrated.
Thanks,
Brian
WRblueX_Guy is offline   Reply With Quote
Old 10-04-2006, 03:58 AM   #2
Okita Souji
Member#: 41097
2005 WRX
Before you do any cutting, find the techdocs for the 05 cluster so you know whats different between the STi and WRX pinouts.
You shouldn't have to cut any wires to prevent the radio fuse from blowing on your 05 WRX.
The speedo and tach plugs are ok mounted backwards. My 04 cluster in an 05 works fine.
Okita Souji is offline   Reply With Quote
Old 10-04-2006, 10:55 AM   #3
quaam
Member#: 113615
2006 WRX Wagon
BLACK
on the 2005 and 2006 the STI cluster connector for the Fuel/temp changed. I went to a junkyard and got myself a 05 STI green connector for the gas/temp. I just cut all those cables and using the colors + the wiring diagrams I connected and taped each one of 'em. I do have a 06 wrx, I did not have any ebrake or check engine light but I did have the buzzing sound. Yes the C9 is for the buzzing sound on both 05 STI cluster and 06 STI cluster. I have both wiring diagrams for 05 WRX & STI and for 06 WRX & STI.
Send me a pm with your email and I will email it to you. I do hear the 05 STI into 05 WRX has issues with check engine light and ebrake. But I'm sure that by looking at the wiring diagrams you can figure something out. Last resort resell it and get yourself a 06 STI cluster or as Okita suggests, get yourself a 04 STI cluster which is confirmed to work on 05 wrx.
Before I installed the 06 STI cluster I had a 04 STI cluster and all the plugs are the same, no buzzing sound or check engine light or ebrake light. I did have the ABS light on. At that time I didn't have any wiring diagrams on me so I coudn't figure it out, I resold it.
I will take a look at both diagrams right now and see if I spot any discrepancies between both years.
quaam is offline   Reply With Quote
Old 10-04-2006, 03:13 PM   #4
Okita Souji
Member#: 41097
2005 WRX
As quaam says, the ABS light will be on if you use a 04 cluster, however that is the only real issue I had with my install. Apparently they changed the ABS circuitry starting with the 05 models.
It has something to do with the amount of voltage the cluster sees. They flip flopped it from 04 to 05. The following is just an example of whats going on. On the 04 model to turn off the ABS light (ABS system OK) the cluster gets 10v. However, on the 05 models 10v turns on the ABS light (ABS not OK).
The light essentially works backwards if you use the 04 cluster in the 05. When I turn the key to the ON position, the ABS light stays off for 2 sec then comes on versus Staying on for 2 sec then going off. No problem though, just tape it up.
From the research I have done, there is no way to change this as it seems they changed the wiring of the entire ABS system from 04 to 05.
Old 10-17-2006, 06:24 PM   #5
Trigun001
Member#: 107092
2005 WRX Evo3 16g
Platinum Silver Metallic
In that case what is the best STI cluster to install in an 05 wrx. Like easiest to install with most lights working if not all. Id like all my lights working but if its not possible.
Trigun001 is offline   Reply With Quote
Old 10-18-2006, 09:24 PM   #6
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
would an 04', 05', or even 06' STi cluster work in my 02' WRX? please someone tell me, everyone I ask says "they don't know".
Force is offline   Reply With Quote
Old 12-12-2006, 08:30 PM   #7
sc00ter
Member#: 117767
2015 WRX
CWP
Did you ever get the cluster working correctly?? If you did please help me as I am having the same problem.
sc00ter is offline   Reply With Quote
Old 12-27-2006, 07:22 PM   #8
Chapel
Member#: 3496
1995 Roadmaster
Beige
*bookmark*
Chapel is offline   Reply With Quote
Old 12-27-2006, 07:31 PM   #9
Chapel
Member#: 3496
1995 Roadmaster
Beige
I just did this with my 02 car and an 05 STI cluster
here's what I got:
buzzing, diff, abs, blown radio fuse.
however:
Here is my car 1 month before I bought it.
I had originally got it with the stock cluster installed and just recently purchased the SAME one that was removed from it. (so we're dealing with same car and cluster as the photo above)
I was told that all I had to do was ground pin B4 to wire C6 with a vampire tap and I'd be all set. Problem is, there's no wire or terminal inside the B4 on the harness. There's a PIN on B4 in the cluster though with no signs of solder.
The main answer lies with the original owner... so I could wait on him, but I'd like to know what you guys think
Old 12-27-2006, 11:46 PM   #10
emoracing
Member#: 65131
Hey Thanks everyone who has had imput on this thread It was excally what i was looking for, I too am trying to install a 05 cluseter into an 02 wrx and have encounter buzzing, abs, blown fuse, and rear diff.
My question is has anyone else had no turn signals while the cluster is pluged in, if i take it out the signals work if i plug it in they dont? any solutions?
emoracing is offline   Reply With Quote
Old 12-28-2006, 07:47 AM   #11
Chapel
Member#: 3496
1995 Roadmaster
Beige
still looking into it
the previous owner of my car has all the answers
I'll pass it along.
Old 12-28-2006, 08:44 AM   #12
Chapel
Member#: 3496
1995 Roadmaster
Beige
here's the 02 wiring diagrams
Old 12-28-2006, 09:47 AM   #13
Chapel
Member#: 3496
1995 Roadmaster
Beige
I don't see a C28 or C30... C only goes to 14... I assume he means B28 and B30?
*grr, this is driving me ****in nuts.
Old 03-24-2007, 01:29 AM   #14
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
So if I'm understanding right, I can use an 04 STi cluster in my 05wrx dash with no issues other than the ABS light? I got rid of the ABS during my swap so I'd expect that light anyways.
sheepdog is offline   Reply With Quote
Fix: Rear Diff Light Stays On - STI Cluster Swap Into WRX pioneer_sti Electrical & Lighting 16 04-08-2014 10:11 PM
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx STiGuy23 Transmission (AT/MT) & Driveline 4 04-09-2010 01:03 AM
'05 Wrx motor swap into '02 Wrx *Need Help Badly* ZRO Subaru Conversions 2 03-01-2010 03:22 PM
Need Info On Sti Block Swap Into 03 Wrx!!!! wrxtacy03 General Community 2 05-21-2008 10:08 AM
STI cluster swap into a WRX Gr8fulDave Warranty Issues & SOA Problems 14 08-01-2005 04:55 PM
