South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-04-2006, 02:02 AM   #1
gharari
Member#: 66695
2006 STI
Obsidian Black Pearl
Default need new front inner CV boots - Phoenix, AZ
So, I offered to help a buddy of mine fix some torn inner, front CV boots on his '02 WRX. Has anyone done this before and what would you suggest?
I was thinking, either
1) get the boots (all four - inner and outer), remove the axles ourselves, then take the axles to a local shop and have them cleaned up and rebuilt with the new boots. I am thinking $40 for parts plus an hour of labor = $100-$150
2) order two new rebuilt axles and install them ourselves. About $150 for both axles. they are "rebuilt axles".
What do you think?
gharari is offline   Reply With Quote
Old 10-04-2006, 07:24 AM   #2
dust12
Member#: 13417
I had one replaced under warranty and I think they dealership wanted $175. So if you do it yourself $150 sounds about right for 2 of them
dust12 is offline   Reply With Quote
Old 10-04-2006, 11:55 AM   #3
racingfish
Member#: 60976
1969 LGT
FATURBO
if you take it to the dealership and get one side inner or outter the labor is going to be 2 hours. if you replace the inner might as well do the outter at the same time since there is no diff in labor time. i think the boots run about 30 bucks for both... then again that might be my price.. i ferget.
but an hour of labor for one side if you bring in the axle sounds about right.
racingfish is offline   Reply With Quote
Old 10-04-2006, 01:38 PM   #4
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
its a messy job if u od it urself
MrMcCrackin is offline   Reply With Quote
Old 10-04-2006, 01:40 PM   #5
racingfish
Member#: 60976
1969 LGT
FATURBO
and dont ferget ta get some of that band grease...
go A's
Old 10-04-2006, 02:18 PM   #6
gharari
Member#: 66695
2006 STI
thanks for the feedback. I think we are hoing to just buy complete axles and not mess with rebuilding the old ones. This only is about $50 more and has the potential to save a lot of headaches.
Old 10-04-2006, 02:41 PM   #7
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
If it comes down to it I have a set off of my 02 wrx. They have about 45,000 miles on them.
I havnt inspected them super close, but I am pretty sure there are no rips. I am using sti axles with my new tranny so I do not need them.
I also have an impact, jack, stands, etc. If you want to switch them out real quick I am not scared.
Smoby is offline   Reply With Quote
Old 10-04-2006, 02:48 PM   #8
gharari
Member#: 66695
2006 STI
hmmm. Thanks! How much?
Old 10-10-2006, 12:54 AM   #9
gharari
Member#: 66695
2006 STI
Thanks all. We installed new axles ($80 each from checker). Piece of cake. Subies and NASIOC rules!
Old 10-10-2006, 03:38 AM   #10
boosted20
Member#: 79576
wow $80 is super cheap.
boosted20 is offline   Reply With Quote
Old 10-10-2006, 04:25 AM   #11
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Default Don't lie!
You know your scared!
John2.5RS is offline   Reply With Quote
Old 10-11-2006, 03:45 AM   #12
gharari
Member#: 66695
2006 STI
yep...
http://www.partsamerica.com/ProductL...Shaft+%2f+Axle
Old 10-12-2006, 03:13 AM   #13
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
What do you think?
1) If you're competent enough with working on a car to remove the axle from the car, you're competent enough to "rebuild" the axles yourself with the new boots. If I remember correct, and I'm assuming WRX axles are the same as other subaru axles, all there is holding them together is a retaining ring on the part that mates with the transmission, remove it, spray some cleaner on the bearings and put the new boots on, squirt the grease packet in and replace.
2) I got a "rebuilt" axle for my '04 WRX from BAP and its doing good. I get them at wholesale, but I think I paid $50 or so.
pudnana is offline   Reply With Quote
Old 10-12-2006, 07:54 PM   #14
gharari
Member#: 66695
2006 STI
1) I agree. The CV joints were questionable though.
2) That's cheap. Maybe you could hook me up with those prices next time
Old 10-12-2006, 07:55 PM   #15
gharari
Member#: 66695
2006 STI
Old 10-13-2006, 12:42 AM   #16
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
They have "split boots" taht you can regrease and throw on real quick, not positive if they have one's that fit a subaru.
bobturismo is offline   Reply With Quote
Old 10-13-2006, 11:09 AM   #17
racingfish
Member#: 60976
1969 LGT
FATURBO
I think the job is complete.
Calling all inner cv boot experts!!! Need help! Bsudrummer Brakes, Steering & Suspension 10 11-30-2013 04:59 AM
Torn inner CV boot. UPDATE! New axle installed. Woo hoo! mav1c Mid Atlantic Impreza Club -- MAIC 20 03-26-2010 10:51 AM
2005 Front Inner CV Boot... Hard to find? wppjeff Service & Maintenance 4 05-25-2009 01:18 AM
Smoking turbo turned out to be a torn inner CV boot (long post) Paulie Transmission (AT/MT) & Driveline 8 05-12-2006 05:52 PM
Pass side inner cv boot 1994 AWD impreza 83Rabbit Transmission (AT/MT) & Driveline 3 07-11-2005 11:04 PM
