Old 10-04-2006, 06:08 PM   #1
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Default Non-AVCS Cams in STI Heads
What's involved in putting non-AVCS cams into the STI heads? The heads I'm working with had Jun 272 cams in them, but I am probably going to put Corworth cams in that allow me to have AVCS again. But I'm not sure what they had to do to install non-AVCS cams in the heads and I don't have a stock set of heads to compare against.
Thanks,
Tim
SloRice is offline   Reply With Quote
Old 10-05-2006, 12:12 AM   #2
brokenarrow
Member#: 119767
2006 wrx
I dont think anything has to be done.. The cam's them self's are the things that stop the AVCS from working...
I was talking to a shop, that I ordered my camshafts from. I ordered NON-AVCS cams first. Thay didnt have it listed as NON-avcs. it just said 06 sti.
So I ordered them. Then I just happened to think about it b4 I got them, and I called and ASKED . Thay told me thay were a DIRECT DROP in cam that delete's AVCs.
And I wouldn not have to do anything. SO, as haveing AVCS is a must for me, I sent back and ordered the right ones.
BUT since you have been running NON-AVCS, you might have to BE tuned again FOR The avcs to work right..
brokenarrow is offline   Reply With Quote
Old 10-05-2006, 07:36 PM   #3
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Tim, what ya doing with the Jun's??? hint hint? I thought you got rid of the Sti
Hope all is well.
Jose
Pacobeagle is offline   Reply With Quote
Old 10-07-2006, 03:18 PM   #4
callum
Member#: 33657
02 STi
Blue/Black Mica
I tried this on a build - Non AVCS JUN's in AVCS heads - and could not get rid of oil leaks from the oil flow control valve covers. Leak was small but annoying. Tried several times to refit the covers with everything well cleaned up, degreased, different sealants, incl 3 Bond, to no avail. Have now pulled the cams to try the AVCS ones. This could still be due to something I was doing wrong and I only have one example to go on!
callum is offline   Reply With Quote
Will JDM STI AVCS cams in USDM STI AVCS heads? dexterous Built Motor Discussion 102 09-11-2014 12:32 PM
NON AVCS cams and EJ257 heads ADJ cam sprockets saintluciascooby Built Motor Discussion 12 01-23-2012 09:12 PM
WRX cams in STi heads Ssleeping Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-22-2008 11:41 AM
WRX Cams in STi Heads spoolinsuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-28-2006 04:36 PM
WRX Cams in STi Heads spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-09-2005 12:33 AM
