Old 12-13-2010, 06:10 PM   #1
mprog
Member#: 249167
2009 WRX
SS
Default ALK Install 3G WRX: 1Ton Arbor press sufficient?
Hi All
I was wondering if anyone has used something like a 1 Ton arbor press to press out the old bushings in the LCA, and also to push IN an Anti-Lift kit?
This is in an 09 WRX.
Thanks!
mprog is offline   Reply With Quote
Old 12-13-2010, 07:13 PM   #2
rexassian
Member#: 183717
1999 2.5RS
BRP
NO, I used a 12-ton press like this:
http://www.harborfreight.com/12-ton-...ess-33497.html
and it was not pleasant. A 20-ton would make it easier. Plus the socket to press out the old one was huge and spendy, can't remember the exact size.
rexassian is offline   Reply With Quote
Old 12-13-2010, 07:13 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
no, you will need something around 10ton -30 depending on how stubborn it is
PARANOID56 is offline   Reply With Quote
Old 12-13-2010, 08:09 PM   #4
mprog
Member#: 249167
2009 WRX
SS
Thanks a lot, guys!
That press costs less than the quote I've been given for installation. I'm pretty confident I could do the job, I just need to fashion some support and press-out pieces to use in the press...
Old 12-14-2010, 01:03 AM   #5
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
Damn, the ALK install is that much harder on the 08+...crap.
ralliharri is offline   Reply With Quote
Old 12-14-2010, 07:44 AM   #6
rexassian
Member#: 183717
1999 2.5RS
BRP
Yes, completely different than on 02-07. BUT, I wouldn't bother on 2011+ as they already have an upgraded mount in that location, unless you absolutely must have caster adjustment.
Old 12-14-2010, 09:16 AM   #7
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
yeah, unfortunately. but you can definitely concentrate on the rear bushings. lots to do back there too.
Arnie is offline   Reply With Quote
Old 12-14-2010, 11:06 AM   #8
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Where did you find info that the "front-rear" LCA bushing is upgraded on the 2011 WRX? I assume it is the same as the 08-10 WRX (and STI as well). We know the STI got the fancy rubber mounted pillow-ball but the WRX wasn't upgraded AFAIK.
FYI for the OP, I own the special service tools to press out the LCA bushings. Those and a 20-ton press makes it a 10-min job to press out the bushings in both arms. We could probably work something out if you want to use them.
Power6 is offline   Reply With Quote
2008 WRX: ALK Install Guide Terrible Juan Brakes, Steering & Suspension 4 09-01-2009 05:59 PM
Part Installation Help near Ann Arbor buccilli15 Mid West Subaru Owners Club Forum -- MWSOC 6 10-02-2006 09:26 AM
quick alk install question-what direction should the big washer be installed? garie Brakes, Steering & Suspension 5 07-07-2005 04:48 AM
Whiteline ALK install question. Cosworth Brakes, Steering & Suspension 7 01-22-2002 03:56 PM
Whiteline ALK install??? RugDoc2003 Brakes, Steering & Suspension 13 03-23-2001 12:38 AM
