Old 10-30-2006, 04:04 PM   #26
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Added this to the threads of note. I should have done this earlier.
Old 03-18-2007, 06:03 PM   #27
Johnnyblueeyes
Member#: 142528
02 wrx wgn, Tein wagon coilovers. light weight 18X8.5 SSR comps [14.6 lbs] with Goodyear f1 g3's. FPgreen and axis 2.5 sb for go.
I don't autoX but love pushing track and canyon road curves. Is the WL wagon specific 23,24mm fsb and a 24-27mm rsb,along with the klc38 F. links.
Along with a new rear strut tower brace and the fender Cowl braces, ordered from you - OK.
If not the right sway bar setup let me know.
thx
Johnnyblueeyes is offline   Reply With Quote
Old 03-19-2007, 01:08 PM   #28
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You might want to re-consider your choice of sway bars.
With the larger rear bar, the car will tend to be more tail-happy than if you used the larger bar in the front and the smaller bar in the rear.
Unless something has changed recently, there is no 27/29 wagon-specific FSB, but the Whiteline model should fit the wagon. I believe it has been done before. TiC can confirm this as they will know for sure.
I don't know anything about the Tein springs, but depending on their stiffness, you may want to reduce the SB size.
Also consider the quality of roads you drive on. The stiffer the springs/SBs, the rougher the ride on a bumby road.
Samurai Jack is online now   Reply With Quote
Old 03-19-2007, 09:48 PM   #29
Johnnyblueeyes
Member#: 142528
I thought you needed a little stiffer setting in the rear than the front. I aleady have the Cusco 22mm rsb.
thx
Old 03-20-2007, 08:11 AM   #30
Samurai Jack
Member#: 21145
2002 Enemy of Aku
It all depends on what you expect to be able to do with the car and what you expect the car to be able to do.
Increasing the SB size (FSB and/or RSB) will raise the threshold of the car's cornering ability but increasing the rear bar greater than the front bar tends to bring the rear around faster than the front = tail can/will swing out around you.
How much/quickly that happens depends on the difference between the two bars.
Adjustable bars are better than fixed bars because they allow you to tailor/tune the car's handling to a certain degree. If you really want the larger bar in back, then I would set the rear bar on the smallest setting and the front bar on the highest setting and see what happens.
Old 04-12-2007, 03:34 PM   #31
tscanuck
Member#: 83296
'07 2.5i wagon
SGM
Fast driving on canyon roads would require a very predictable setup for me. Big swaybars can sometimes make for suprises when pushed really hard (sudden snap oversteer or wheelspin), so for reasonably smooth roads, I like stiffish springs with swaybars not a lot stiffer than stock, but it's nice if one or both are adjustable, to fine tune balance.
tscanuck is offline   Reply With Quote
Old 04-12-2007, 06:42 PM   #32
Johnnyblueeyes
Member#: 142528
oooop I definitely don't like surprises from the rear tires when pushing high speed corners. Hopefully my Goodyear F1’s 225/40/18” will not let the tires loose any grip. I have found 17” 45 series did let the rear end come around when pushing the car thru a twisty road. Scared the heck out of me. Michelin 17"/45, ps2’s tires tended to pop up straight under negative G’s in a turn and traded them for the Goodyear F1 40's Car is pretty solid as it is. Maybe I got carried away. I will try the bars at 22 rear and 24 front.
Thx
Old 12-27-2007, 07:32 AM   #33
EdWRX
Member#: 108068
05 WRX Enginuity'd
WRB Stg II y00!
This will be my setup for my 05wrx SADM:
22mm fixed front, 24mm rear adj (WL sways)
WL endlinks
Prodrive springs
I need some opinions, will this setup work fine?
EdWRX is offline   Reply With Quote
Old 12-27-2007, 08:01 AM   #34
Maximpaul
Member#: 88271
2002 WRX (Sold)
I might as well ask some advice, as well.
I've got an '02 with the K-Sport Kontrol Pro coilovers. 7kg front, 5kg rear, and the shocks have a wide adjustment range.
I'm defenitely going to buy Kartboy's rear endlinks, mine are shot. I do canyons and occasional trackdays, and I'm more concerned with having a fun car that I can induce controllable oversteer with, rather than sheer laptimes. I'm planning on a rear bar, looking at Cusco's 22mm adjustible at the moment. Anybody have an alternate recommendation, and should I bite the bullet and go for a front sway as well?
Maximpaul is offline   Reply With Quote
Old 01-08-2008, 11:17 AM   #35
JasonM1
Member#: 107931
2004 WRX Cobb Stg. 2
I need some advice as well.
I am going to running D-spec struts with prodrive springs. What would be your suggestion on what size of swaybars I would need?
JasonM1 is offline   Reply With Quote
Old 01-08-2008, 01:04 PM   #36
Butt Dyno
Member#: 17301
is the "dark side"
What do you use the car for?
Have you read the Swaybar FAQ yet?
Old 01-08-2008, 01:31 PM   #37
JasonM1
Member#: 107931
Yeah I have read the swaybar FAQ but I still a little confused on the subject. I use the car as a daily driver and it will be autocrossed from time to time. Thanks!
Old 01-09-2008, 09:42 PM   #38
mysuby
Member#: 166953
Default my turn
i have a 99 impreza L coupe...ej20 swap soon...for now i'm doin the suspens stuff...currently stock springs...but i wanna get a bushing kit and sway bars...mostly street use..windy moutian roads...what size and brand do peopel recommend? thanks alot for the help
mysuby is offline   Reply With Quote
Old 01-10-2008, 09:09 AM   #39
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
To what swaybar FAQ are you referring? Thanks
mmiller2002 is offline   Reply With Quote
Old 03-04-2009, 01:07 PM   #40
Scoobyphat14
Member#: 199614
09 WRX
just got whitline endlinks with 24mm adj in the front on my 09 WRX. thanks for the help!!
Scoobyphat14 is offline   Reply With Quote
Old 01-18-2010, 10:14 AM   #41
BoostinChick
Member#: 218971
2007 WRX
http://forums.nasioc.com/forums/show....php?t=1152714
BoostinChick is offline   Reply With Quote
Old 04-04-2010, 12:09 AM   #42
stoker68
Member#: 208185
2009 WRX 5-door
Dark Gray Metallic
How do you like these? Is the ride flat around corners? Is it too harsh? how is th quality of the whitline products?
stoker68 is offline   Reply With Quote
Old 06-01-2010, 03:56 AM   #43
outlwstr
Member#: 102201
Great info. Since I have cusco coils I went with 24mm in rear and 24mm in front.
outlwstr is offline   Reply With Quote
Old 12-14-2010, 10:44 AM   #44
BoostinChick
Member#: 218971
2007 WRX
...delete...
FS: NEW Whiteline Fixed Front Sway bar for 02+ WRX BNastyer Suspension/Brakes/Handling 15 09-14-2006 12:02 PM
WTB: Cusco FRONT sway bar for 02 wrx sedan (I'm in SoCal) sevendhappy Private 'Wanted' Classifieds 2 10-13-2005 04:56 PM
Pittsburgh PA: front and rear Cusco sway bars for 02+ WRX dexterous Private 'For Sale' Classifieds 7 09-08-2005 02:20 PM
WTB: Whiteline front adjustable 22mm sway bar for 02 WRX Wagon macboat Private 'Wanted' Classifieds 0 08-20-2003 04:27 PM
FS: used spt front sway bar for 02 WRX [freeman] Canada Region Forum 11 01-25-2003 11:45 PM
