Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 11-05-2001, 03:53 PM   #1
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Default Bad Wheel Bearings on '98 Forester s?
Has anyone had the wheel bearings on their Forester serviced? What were the circumstances and outcome?
Thanks,
Wilkey
Ginseng is offline   Reply With Quote
Old 11-05-2001, 08:12 PM   #2
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
Do a search in the Forester Forum. There was a thread about this about 4-6 months ago regarding the bearings. It is sort of common. Takes alot of bitching to the SOA and your local service people to get it taken care of. I think the consensus was to ddemand the Outback bearings, since they are more H/D and are a perfect retrofit.
ForesterPerformance is offline   Reply With Quote
Old 11-06-2001, 01:27 PM   #3
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Thanx.
Old 11-06-2001, 01:57 PM   #4
Ken S
Member#: 1895
05 Leg GT Ltd. W
Post
A friend of mine had his bearings replaced under warranty several times. All it took was a trip to the dealer and telling them about the noise.
Apparently, the bearings are very sensitive to proper installation. A lot of dealers were installing them wrong causing more failures. I think SOA has fixed that with a tech bulliten by now.
Ken
Ken S is offline   Reply With Quote
Old 11-07-2001, 09:00 AM   #5
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Yep. That's been confirmed in my research as well. I'll be ready for Pilgrim Subaru tomorrow.
Wilkey
Old 11-07-2001, 10:42 AM   #6
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
Ask them to double-check the torque specs. If they overtighten it, it will just happen again.
-juice
juice is offline   Reply With Quote
Old 11-08-2001, 09:02 AM   #7
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
My wife's Forester has a funny burning smell coming from the passenger side wheel lately. I replaced the brake pads. Could it ba a bearing problem?
AWMIII is offline   Reply With Quote
Old 11-08-2001, 11:34 AM   #8
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Well, got the word back from the dealer. He doesn't think it's the wheel bearing. He put the stethoscope to it and heard nothing evil. Also, confirmed that there is little to no play in the bearing. I know it's not my imagination, there is a very distinct gear noise that tracks with speed. What could it be? The only thing I did was change pads all around about a month and a half ago.
AWMIII, did you get any anti-squeal grease on the rotor side of the pad? Did you bleed the system? Did you spray the moving parts (calipers, springs etc.) with brake system cleaner and not a petro based lube?
Wilkey
Old 11-08-2001, 01:56 PM   #9
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
I did not bleed the brakeswhen I changed the pads. I changed the pads because of the smell so I sure it was nothing that I did. I will check for play in the bearings.
Old 11-08-2001, 04:02 PM   #10
Ken S
Member#: 1895
05 Leg GT Ltd. W
Can you describe the noise a little more? You mentioned a "gear" noise -- I wonder if you're refering to transmission whine?
Did the dealer hear what you were talking about or just zoom right into checking out the wheel bearing? If they're good, they should be checking out all possibilities of the noise.
Ken
Bad wheel bearing - how long can I drive on it Outback Jack Brakes, Steering & Suspension 14 05-24-2009 12:23 AM
unbalanced wheels or bad wheel bearings mxpunk Tire & Wheel 16 12-16-2008 02:04 PM
More damage to drive on a bad wheel bearing? mstein Service & Maintenance 8 07-15-2008 11:12 AM
Clicking noise from front right wheel- Bad wheel bearing? DrBoy01 Service & Maintenance 7 08-22-2003 12:30 AM
Noise: Bad wheel bearing or bad aligment? Flashboy Brakes, Steering & Suspension 6 03-05-2001 07:18 PM
