Old 10-05-2006, 08:56 PM   #1
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Default Going to get Protuned Should I Get FMIC
Ok i have stage 2 right now Iam going to be getting a protune in about 2 month should I or Should I not get a FMIC Kit...What are the Pros and Cons also what kind of power will i get to the wheels
Heres my mods thanks
Megan Downpipe/Heat Wrap
Borla Header/Heat wrap
Gp moto MAF Hose
CObbs SF intake
Stromung Cat-back 3inch.....
Iam just undicided on what to do ahould i or no FMIC..for Protune thanks...
subaru222 is offline   Reply With Quote
Old 10-05-2006, 09:38 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
I say no FMIC on stock turbo, but I run a TMIC on a 20G as well....& am very happy w/ it.
testes1010 is offline   Reply With Quote
Old 10-05-2006, 09:39 PM   #3
dibblejr
Member#: 94070
05 LGT
+1 Great answer
dibblejr is offline   Reply With Quote
Old 10-06-2006, 12:49 PM   #4
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
OK i guess not well the only reason i was going to get it because my friend has a Blitz fmic and he said he will sell it to me for only $300....so i will not get no gain from it in a protune also the guy with the 20g witch tmic do you have thanks Guys
Old 10-06-2006, 12:55 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
I didn't say you would see gains, but you're going to loose out some lowend because of the small stock turbo. I run a Hyperflow TMIC on a TD05H-20G on my 2.0L WRX.
Old 10-11-2006, 10:03 AM   #6
DashboardCon
Member#: 109878
2001 Aprilia RSVR
A FMIC is more about keeping your intake temperature stable. You may not see huge gains, but heat soak is also a PITA. The extra lag isnt as bad as everybody says on the STi. Especially since you will practically eliminate heat soak.
DashboardCon is offline   Reply With Quote
Old 10-16-2006, 10:02 PM   #7
scoobie1
Member#: 41559
2007 Brocoma
You won't notice the difference with a properly tuned Stg2 Sti with a FMIC. I put one on my car for the heat soak issue during daily driving & especially at autox's. After I had it tuned the car drove so much smoother than when tuned for the TMIC. Just my .02
scoobie1 is offline   Reply With Quote
Old 10-17-2006, 04:27 PM   #8
E-Wrex
Member#: 94533
2006 FXT Limited
Aspen white /w MT
FMIC is going to be far more beneficial on a bigger turbo, as everyone has said. It won't really be negative, as I ran a FMIC on a VF39 on my WRX, and I did get some gains over running the stock IC. There was a quite a bit of lag, as I was running an enormous Perrin front mount, but it wasn't as bad as everyone told me it would be. I would get a bigger turbo, then think about a front mount.
E-Wrex is offline   Reply With Quote
Old 10-24-2006, 05:18 PM   #9
305wrxPIMP
Member#: 109098
2006 WRX STI
white
Default The King Of The South
You'll be allright, i got it in mine 06 STi with the perrin FMIC and it runs pretty, a little lag but its ok and yeap you would be see different numbers with the FMIC especially on the MID range and Harder on Top end and if you go for a bigger turbo its the best option.
305wrxPIMP is offline   Reply With Quote
Going on a Cruise, should I get the insurance? Dirty B Off-Topic 5 02-18-2004 10:11 PM
Co-worker going to Japan, what should I have him bring me back? The Enemy Off-Topic 28 07-16-2003 02:01 PM
want to get something sweet to eat. what should i get STEALTH-WRX Off-Topic 18 06-22-2003 11:48 PM
Parents going to europe. what should I get Hondaslayer General Community 12 08-03-2002 10:27 AM
