Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 10-05-2006, 09:55 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default FP GREEN 8CM Combo! EJ25 Turbo Engines, Greddy EVO 2 (STI), Gruppe-S Headers!
Hey guys,
The FP Green 8CM is back!!
FP GREEN 8CM, Helix 860cc Injectors, Cobb AP super Combo!
-FP Green with larger 8CM housing
-Helix 860cc Injectors
-Walbro Fuel Pump
-Cobb AP 2004 STI only
$2499 Shipped!!
Add $50 for other cars
Add $100 for all other Drive-by-wire cars (2005+ STI, 2006 WRX)
Oil / Water lines additional $75
Hey guys we just got in a large shipment of JDM EJ25 engines today! We have:
EJ25 Legacy Turbo Engine
-Virtually identical to USDM STI 2.5 Engine
-Less than 10,000km on engine
-Includes intake manifold, cam gears, sensors, water/oil pump, semi complete engine
-Leak down tested, At least 88% compression across all cylinders (factory is 80%+)
-Awesome for WRX engine swaps
$3499 + shipping
EJ25 Legacy Turbo Long Block Only
-Long Block Only
-EXCELLENT Compression, 93+% compression across all cylinders! (factory is 80%+)
-Crank position sensor holder is damaged, will require fabrication or will work with aftermarket crank position sensor (such as Motec, Tec III, and other stand alone ECUs)
$2599 + shipping
2006+ Plastic Coolant Reservoir
-Lighter plastic construction
-Used
$60 shipped
GREDDY EVO 2 Exhaust for STI
-High Flow Design
-50 State Legal
-Best balance between power and excessive noise!
$569 Shipped!!
Gruppe-S V2 Header
- 4-1 Investment Cast Collector
- NO low-end loss on 2.5 cars
- Gains of over 20 ft/lbs seen on modified STI's!
$399 Shipped!! (4 pcs left)
Please give me a call if you have any questions or would like to order. Thanks!!
Randy
randy@gruppe-s.com
510-783-5300
Gruppe-S is offline   Reply With Quote
Old 10-05-2006, 11:13 PM   #2
v8killer2pt5
Member Sales Rating: (8)
Member#: 62275
2004 Sti
Will the 06 reservoir work on a 04 Sti if so i will take it!
v8killer2pt5 is offline   Reply With Quote
Old 10-06-2006, 03:48 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Will fit an 04 STI, give us a call and place the order.
510.783.5300
Old 10-06-2006, 04:33 PM   #4
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
Is that a custom map for the green turbo with the ap?
Old 10-06-2006, 04:39 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry, it's not a custom tuned map for the green. Honestly at these modification (upgraded injectors / turbo) levels you'd really want to your setup custom tuned. A good FMIC would help also
Thanks,
Gary
Gruppe-S
FS (CT): FP Green 8CM 2.4, Oil Line & Turbo Inlet sodo Engine/Power/Exhaust 27 08-09-2009 04:22 PM
WTB VF39 Turbo and Greddy Evo 2 exhaust awakethroughmotion Private 'Wanted' Classifieds 6 03-17-2009 09:00 AM
FP Green 8cm, Tial 44mm, GTspec EL Header StoryBookSin Engine/Power/Exhaust 8 02-12-2009 10:32 AM
COBBAP & Helix 860cc ($999)*GREEN 8CM Combo! EJ25 LongBlocks*Greddy EVO 2*4-1 Headers Gruppe-S Engine/Power/Exhaust 20 10-13-2006 09:46 PM
FP GREEN 8CM Combo! EJ25 Turbo Engines Gruppe-S Engine/Power/Exhaust 0 10-05-2006 06:17 PM
