Old 03-05-2007, 04:41 PM   #26
F4tune
Member#: 126800
1990 Subaru Legacy
Here's a link to the car. I will post more pics when I return home.
http://public.fotki.com/Pic-Knits/
F4tune is offline   Reply With Quote
Old 03-11-2007, 02:45 PM   #27
F4tune
Member#: 126800
1990 Subaru Legacy
Default Driving.
I've managed to get this weekend and do some driving tests. The first thing I've notice is the engine does does bog down when pulling off. The old 2.2L just didn't have enough grunt to do any good lauches. My normal lauch on stage was just drive off the start line. Even though the engine has done only 26 miles and a few hours engine running it's early days. Now this conversion is no STI turbo job so expect any neck breaking jerks between shifts. The power is there and the engine pulls strong. There seems to be lots of torque which is good for rallying. Today my friend with a turbo Legacy is coming over for a test drive so it will be interesting to see his reactions. Oh yeah the equal length header might not be everyone's Subie sound but with one straight through muffler it's damn loud and sounds like a WRC Peugeot 206/Ford Focus which I can live with.
I took my daughter out in it yesterday and she thinks it's way "cool"
Photo's to follow as I forgot to bring my camera home. Duh!
Old 03-12-2007, 02:26 PM   #28
F4tune
Member#: 126800
1990 Subaru Legacy
So my friend tested the car. He has a WRX and a Legacy turbo. He thought there was a lot of low down torque and seemed impressed with the power. The difference was around 3000rpm where his WRX gains some grunt and more power. Other than that he thought it was a good set up for the price. The testing continues.
Old 08-30-2007, 12:06 AM   #29
SiouxBe1
Member#: 157247
1991 Legacy L+AWD BJ
Wow, Excellent Job F4!!!
I like what you've done.
I'm considering a similar build with my 2.2l N/A. Putin' the 2.5l block underneath my 2.2l N/A heads (I've already got the Delta Cams &
E.L. Cobb Headers). By any chance did you calculate the C.R. using
the Phase 1 dished pistons with the 2.5l short block and STi head-gasket? Or, did I just miss that part?
SiouxBe1 is offline   Reply With Quote
Old 08-30-2007, 01:50 AM   #30
tedstriker
Member#: 156039
this is what i'm adding to my ej257. any idea on the power it will hold? I cant decide between the 30r or 35r. comments?
Wiseco Forged pistons 100mm (20 over)
-Supertec Springs (revs to 8300)
-Balanced Crank
tedstriker is offline   Reply With Quote
Old 09-20-2007, 03:34 AM   #31
mellow65
Member#: 83350
Too Many
i am looking to do this same thing in pretty much the same car, but i was wondering if you knew what the compression was if you left the phase II pistons in and just ran stock 2.2 heads.
There is one post that contradicts it's self a little bit on CR
In N/A form this set up bumps up the comp ratio to about 10:8:1 with the Phase II pistons(valve cut outs) the ratio is in the high 11's.I wanted to be safe so went for the dished Phase I pistons.
or are you saying with the phase I pistons in the phase II block gets you a CR of 10.8:1 and the phase II one would be in the high 11s.
So did you have to do any work to the pistons so the valves wouldn't hit them?
What rods did you use? Or are they both the same?
what is a delta grind?
Sorry about all the questions, but it's good to find some one that did the same thing that I am trying to do.
thanks
mellow65 is offline   Reply With Quote
2003 WRX 2.5L/2.0L heads hybrid build w/ GT52 on dyno today Mr.Anderson Proven Power Bragging 11 05-11-2010 06:24 PM
Hybrid 2.5L short block build Q's Kenji815 Built Motor Discussion 25 08-10-2007 11:42 AM
Borla 2.5L/2.2L Headers: So CAL 555subaru Engine/Power/Exhaust 2 05-14-2007 01:01 PM
2.5L/2.2L running problem F4tune Built Motor Discussion 3 02-14-2007 03:50 AM
99RS 2.5L stock motor build up questions. chrismindless Normally Aspirated Powertrain 3 04-21-2005 03:27 PM
