Old 11-05-2001, 08:33 PM   #1
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Default Valve adjustment w/ solid shimless lifters?
Does anyone have a clue how to adjust valve clearance on what appears to be a shimless solid lifter? (EJ20K) .
Do I need to remove the entire cylinder head to adjust the gaps between the lifter and the cam?
Thanks
scooby5 is offline   Reply With Quote
Old 11-06-2001, 02:15 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
ick....shims are yucky, they are a PITA. Good luck...never done them on a subaru though. So i can't be of much help.
Jeremy
Old 11-06-2001, 07:52 PM   #3
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
You may want to inquire on Subysports or some similar overseas sight. Our solid lifters have large (32mm) shims on the top of the bucket. It is common to have selective shims on the bottom side of the bucket (on top of the valve stem) but I have not seen it yet on a Subaru. If this is the case it requires removing the cams to adjust.
SubyTechMaster is offline   Reply With Quote
Old 11-07-2001, 12:50 PM   #4
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
SubyTechMaster,
Good point.
I have actually removed the camshaft now, but it looks like I have to compress the valve spring and remove a retainer to get the lifter out. There is definitely no shim between it and the cam. Dang!
Old 11-11-2001, 11:14 AM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
There is NEVER a shim under the valve spring.
yamarocket630 is offline   Reply With Quote
Old 11-11-2001, 11:25 AM   #6
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
When the 2.5L twin cam was intrduced in the US in '96 it had hydraulic lash adjusters. Have you considered this possibility? The Cam Followers look very similar except with no shim on top.
When looking at the outside of the head, observe the lines that are cast in the head. If the lines are one direction only (from crank outward) it has HLA's. If the lines form a cross-hatch it is solid lifters.
WTB: shimless lifter bucket 4.79mm scottjca Private 'Wanted' Classifieds 0 02-02-2010 01:18 PM
valve tick or valve adjust? ali dashty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-06-2008 06:15 PM
Bad valve job. Machine shop killed lifter clearances. Drink Built Motor Discussion 19 08-19-2008 09:30 PM
Endlinks. Adjustable or solid? TattooLost Brakes, Steering & Suspension 9 06-27-2007 08:07 AM
Valve clearance for STI shimless buckets?? sjl1614 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-08-2005 11:25 PM
