Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 10-06-2006, 02:40 PM   #1
morey000
Member#: 124531
2007 Tribeca
Question Do Personally Burned CDs work?
I'm in the process of ordering my 'beca, and when going over the vehicle last night with the salesman, he mentioned that the CD player will only play original purchased CD's and not one's that you burn yourself?
I generally load the CD's I buy into my computer, and then reburn them for the ones that sit in the car ('cause they always get scratched up- I have a toddler).
Is what the salesman said correct? It says "mp3" on the player, so I've assumed that I could load up CD's with mp3 versions and carry 6 full CDs of mp3s with me in the player.
Has anyone experienced any compatibility problems with burned CDs?
morey000 is offline   Reply With Quote
Old 10-06-2006, 03:56 PM   #2
scot3818
Member#: 122994
I play self burned mp3 cd's, but you need good quality cd-r's or you'll have nothing but skipping music. When I tried brand-less cd-r's they didn't work well, when I used good expensive TDK disks they worked fine.
scot3818 is offline   Reply With Quote
Old 10-06-2006, 05:43 PM   #3
morey000
Member#: 124531
2007 Tribeca
What about burning regular CDs, rather than mp3 CD's? Are they as sensitive?
thanks for the incredibly useful tip.
Old 10-06-2006, 09:52 PM   #4
scot3818
Member#: 122994
Still shouldn't be a problem, as long as the CD is of a decent quality it'll play. I have one copied kiddie CD here that works just fine. I'm guessing that over time, in a hot summer car it may degrade the CD, but I haven't experienced that yet.
Old 10-07-2006, 12:23 AM   #5
kuoh
Member#: 127558
I just got around to testing the CD changer today and it was able to play all my cheap burned audio CDs from as old as 5 years ago. I didn't have any MP3 discs to try though.
On a somewhat related note, the rear DVD system will also play burned DVDs, both the single and double layer varieties.
KuoH
kuoh is offline   Reply With Quote
Old 10-07-2006, 09:16 AM   #6
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
All my Burned DVDs and CD-Rs (both CDA and MP3) play fine in our B9
Peaty is offline   Reply With Quote
Old 10-07-2006, 04:13 PM   #7
morey000
Member#: 124531
2007 Tribeca
Thanks for the positive info and responses.
The internet is the source of all knowledge. (certainly moreso than a car salesman)
Still trying to find one in my color choices (silver or seacrest green)
Old 10-08-2006, 09:04 AM   #8
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Bass is almost non-existent for regular CDs, burnt or not. When you convert them to MP3, you will suddently find all your missing bass tune in your music. Something funcky with the CD player.
Foxbat is offline   Reply With Quote
Old 10-08-2006, 02:37 PM   #9
SoDealer
Member#: 67960
I don't find that to be true... Mp3 CDs in the Tribeca sound like crap. The music doesn't sound as full.
Old 10-09-2006, 06:52 AM   #10
JR06B9
Member#: 106010
06 B9 Tribeca lim
white
That all depends on the software used, bit rate you have it set to and your computer performance as well. best bit rate for file size and performance is vbr with a max rate of 320.
you can put albums on the disk in folders or just loose mp3's
try a program called audiograbber..works great for ripping to mp3 and will give you data tags as well.
JR06B9 is offline   Reply With Quote
Old 10-09-2006, 03:24 PM   #11
HB_Dad
Member#: 45190
2014 Impreza Sport L
All Subaru's post 99 should play CD-R's no problem! Every Subaru I've had has been flawless in this regard. One thing though, do NOT use any of those CD stomper labels on your discs as they tend to peel off in the player and F-up the whole thing.
Make sure the session is CLOSED on the disc when you burn. If you use Easy CD Creator, burn with the "Disc At Once" feature checked.
My remommendation however is that you simply use the CD burner in Itunes. Simply create a playlist and dump all of the tracks you want to burn into that list. Insert a blank CD-R and click the CD Burn icon and it does all of the rest. I've never had any burning issues through Itunes and the software is free from Apple.
HB_Dad is offline   Reply With Quote
Old 10-09-2006, 03:27 PM   #12
HB_Dad
Member#: 45190
I'm gonna call BS on this one. MP3's in general do have a little bit of a lower quality sound than CD, but not much. The average consumer will never hear the difference and the Tribeca does not worsen this in any regard.
Old 10-09-2006, 09:31 PM   #13
JR06B9
Member#: 106010
06 B9 Tribeca lim
white
what I was triying to get at was that depending on the software used to rip your cd It will make a differance on how your mp3's sound regardless of the player used to play them.
Itunes is fine if you have an ipod {Puke x2}
ipods have got to be one of the best marketing gimmicks of all time! hell I wont even install quicktime on my pc again.
Old 10-10-2006, 12:57 AM   #14
SoDealer
Member#: 67960
I can definitely tell the difference between playing mp3's and WAVs on the Tribeca. Granted none of my mp3s were a 320 bit trate.
Old 10-10-2006, 11:03 AM   #15
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
As said many times above, it is about how you converted them. I copied couple of MP3 tracks off a few of my Dual Discs and DVD-Audio discs that was professionally created by the publisher. They sounds better (richer bass)than the CD version of the same disc on Tribeca. Also ripped (using nothing but Windows Media Player 10) a few CDs of mine and played just fine. I did have to use a different PC to rip my CDs as my laptop generates too much static when ripping the tracks off the CDs.
But, overall, I'd rate Tribeca's sound system below average. SOA should really put the McIntosh system (offered in OB VDC) back into Tribeca.
Old 10-10-2006, 11:24 PM   #16
SoDealer
Member#: 67960
SRS WOW in the Legacy and Outback makes a WORLD of difference. That would be a big improvement on the Tribeca's system.
Old 10-11-2006, 08:31 AM   #17
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
I'd rather see a real system like DVD-Audio surround system similar to those offered by Acura. After all, you already have full surround speaker systems in the car, why not drive them with a true surround sound system like DVD-Audio instead of fake surround called SRS WOW. I'd willing to pay for such an upgrade in a heart beat.
Old 10-11-2006, 04:26 PM   #18
tombo_m6
Member#: 119338
Yeah, but who uses DVD-Audio? Most people don't even know what that is. This is the first time I've heard of a car company using it. I'm surprised their market research didn't tell them it was a waste of money.
tombo_m6 is offline   Reply With Quote
Old 10-11-2006, 09:11 PM   #19
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
A lot of CDs now released in DualDisc format. A lot of DualDiscs(except ones from Sony/BMG) use DVD-Audio codec/format on DVD side.
Old 10-12-2006, 07:59 PM   #20
HB_Dad
Member#: 45190
I have a lot of DualDiscs and from what I've seen, the DVD side is usually used for DVD Video content, not DVD-Audio.
By the way, it is really sucky that Subaru car stereos (Tribeca included) are NOT compatible with Dualdisc considering pretty much EVERY other CD player is! Instead of fixing the problem, they give you a warning in the owner's manual. That is just LAME!
Old 10-13-2006, 05:39 PM   #21
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Check the labels for your DualDiscs. I'd bet most of them are from Sony/BMG. Sony will never release any disc using DVD-Audio. Period.
DVD side of the DD standard is very vague. It can be DVD-Video, Dolby Digital, DTS or high-res DVD-Audio or combination of the all above if space allows. One thing is clear, Sony's own SACD format is not allowed on the DVD side.
Does the factory 05 STi stereo play burned cds? neonglh Car Audio, Video & Security 8 04-30-2007 11:11 PM
Why PCs no read mac burned CDs? DrBuzzad Off-Topic 11 07-19-2005 12:39 PM
need help burning cds NRTmotorsports Off-Topic 13 04-24-2005 02:17 PM
Burning CDs in WinXP using WMP 9; any issues? Kaiser Off-Topic 20 05-14-2003 04:44 PM
Problem Playing Burned CDs TJH Car Audio, Video & Security 13 12-13-2002 08:00 AM
