Old 11-05-2001, 09:34 PM   #1
plurbe
Member#: 8592
95 Impreza L Sedan
Default Synthetic Oils
My friend tells me that synthetic oils are not good for engines that aren't made for it, he thinks my 95 impreza isn't made for synthetics, so all its doing is clogging things up eventually. Are impreza's engines made to support synthetic or not?
plurbe is offline   Reply With Quote
Old 11-05-2001, 10:52 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Ask your friend what engines are "designed" for synthetics.
It'll be fine, most of the stigma associated with synthetic oils arise from using it in old beat up engines...your 95 engine will be fine. Check it regularly though, if you're losing oil abnormally or there's a leak, then yea, you're having problems with synthetic oil seeping through, other than that it'll be ok.
Keiho is offline   Reply With Quote
non synthetic to synthetic oil? dontgiva Service & Maintenance 6 10-12-2007 02:58 PM
Switching Between Synthetic and Non-Synthetic Oil Slowsoul General Community 16 07-25-2007 09:21 PM
Synthetic vs Non-Synthetic Oil For Turbo Installation Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-01-2007 12:31 AM
Can you mix synthetic oil with non synthetic? SubaruImpreza_power Newbies & FAQs 6 10-31-2003 09:56 PM
synthetic oil = synthetic oil filter? kid22 Technical Forum Archive 4 09-16-2000 09:04 PM
