Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 10-06-2006, 03:52 PM   #1
Precision Tuning
Vendor Sales Rating: (9)
Member#: 38696
Default Greddy, HKS, TiAL, Prodrive and More!!!!!
PrecisionTuning
Phone: (732)451-0200
Fax: (732)451-0110
945 Cedar Bridge Ave
Brick, NJ 08723
www.precisiontuning.com
[email protected]
NEW!!!:
SHOPCAM!!!
CHECK OUT OUR WEEKEND SPECIALS IN THE POST BELOW!!!!!!
Engine Specials!!!!!
GReddy Informeter
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
Included:
  • GReddy Informeter Unit
  • OBD Cable
  • OBD II Cable
  • Cigarette Lighter Power Cable
  • 9 Different Color Face Plate Inserts
  • Japanese Instruction Manual!!!!
Regularly $360.00, $275!!!
Available in White
Tial Sport 50 mm Blow Off Valve with Aluminium Weld On Flange
The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance. The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance. The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life.
Included:
  • Tial Blow Off Valve Assembly
  • V-Band Clamp
  • High Pressure O-Ring
  • Banjo Style Air Fitting
  • V-Band Weld On Aluminium Flange
  • Tial Sticker
  • (Not Pictured) Nifty diagram showing you where to install it!!!!
ONLY $250.00!
Choice of Silver, Blue or Purple
Exhaust Specials!!!!!
GReddy SP2 Catback Exhaust
Features a 304 stainless steel muffler canister with extra strong 430 SS end caps that feature a deep, high polish. Large, high volume mufflers provide maximum flow with a deep, pleasing tone. Polished 304 stainless steel mandrel bent piping for better resonance and vibration control and enhanced corrosion resistance and durability. New lightweight, flared and stamped stainless steel flanges are also used to provide improved sealing characteristics.
2002-2005 WRX/ 2004-2005 STi- $568.65 Regularly $669.00
2005 Legacy GT Wagon- $737.15 Regularly- $899.00
GReddy EVO2 Catback Exhaust
In addition to the GReddy straight-through technology, offset tip design and large piping diameters of the original EVO, the EVO2 is now offered in full stainless steel providing improved looks, durability and corrosion resistance while maintaining the best qualities of the original such as fitment, sound and performance.
2002-2005 WRX/ 2004-2005 STi- $589.58 Regularly $719.00
2005 Legacy GT Wagon- $893.80 Regularly- $1090.00
2005 Legacy GT Sedan- $820.00 Regularly- $1000.00
HKS Downpipe
Increases turbo spool up and exhaust flow by deleting 2 rear catalytic converters. The down pipe is constructed from 75mm mandrel bent coated SUS304 stainless steel. This downpipe is a bolt on application that will mount to the stock turbo and any cat-back exhaust system with a 3" flange. Perfect for large external wastegate applications where space is an issue.
2002-2006 WRX/ 2004-2006 STi- $169.95 Regularly $175.00
HKS Hi-Power Catback Exhaust
Inspired and designed from endurance and GT racing in Japan,. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. This is achieved by eliminating unnecessary bends for the straightest exhaust path. For turbocharged applications, the large and smooth exhaust flow allows greater exhaust velocity for better mid-range boost response and high-RPM power. Hi-Power Exhaust systems are made from SUS304 stainless steel muffler and tip assemblies. Muffler tips are 120mm in diameter, piping diameter is 75mm. Will not clear vehicle equipped with rear diff. skid plate.
2002-2006 WRX / 2004-2006 STi- $510.00 Regularly $625.00
HKS Carbon-Ti Catback Exhaust
Special Edition HKS Carbon / Titanium Hi-Power Exhaust. These exclusive versions of the Hi-Power Exhaust consist of a carbon fiber wrapped stainless muffler shell, a 120mm titanium tip, and polished stainless steel piping. Special Edition HKS Carbon Titanium Hi-Power Exhaust systems are exclusive versions of the Hi-Power Exhaust consist of a carbon fiber wrapped muffler shell, titanium tip, and polished SUS304 stainless steel piping. Will not clear vehicle equipped with rear diff. skid plate.
2002-2006 WRX/ 2004-2006 STi- $650.00. Regularly $895.00
Perrin Up-pipe
The factory up-pipe hinders engine performance because the design includes a restrictive catalytic converter and a corrugated expansion joint. Replacing the factory up-pipe with a Perrin Performance up-pipe will increase exhaust flow rates and spool the turbo faster providing more horsepower at a lower RPM. Failures of the factory up-pipe are common on heavily modified Subaru's. Damage from pieces of the catalytic converter and the e.g.t. sensor probe being ingested into the turbo can occur. The Perrin Performance up-pipe is fully constructed of mandrel bent 321 stainless steel. . The up-pipe is one of the hottest components of the exhaust system and 321 stainless will ensure the extra longevity of your up-pipe, as well as decreasing chances of weld failure and warping. The Perrin 1/2" flange design prevents warping at high temperatures and insures a leak free seal. The proper inside diameter of 1.62 inches is critical. Pre-turbo exhaust velocity is critical to boost response. Improperly oversized header and up-pipe systems lower exhaust velocities slowing spool up for larger turbo's decreasing power and increasing boost lag.
2002-2006 WRX $349.95 INCLUDING INSTALLATION! Regularly $454.00 Including installation
Perrin Rotated Up-pipe/Down-pipe Kit
The Perrin rotated mount up pipe/down pipe kit includes a stainless steel up pipe and down pipe flanged for both a Garrett turbo (not included), and a Tial 44mm wastegate (not included). Using v-band flanges to mount a 44mm Tial wastegate the Perrin kit recirculates the spent wastegate gases back into the exhaust eliminating fire hazards, excess noise and under hood exhaust smell. The Perrin rotated mount down pipe will bolt to the stock or any aftermarket 3" exhaust system!
2002-2006 WRX/ 2004-2006 STi- Pm for ridiculous pricing!
As always we will do our best to match prices!!!
All in stock and ready to go. Email, PM, IM, or give us a call!!!
If you would like something not in this post, for orders or information feel free to give us a call, e-mail, pm, or im!
Thank You!
Kyle
Precision Tuning
Brick, NJ 08723
http://www.precisiontuning.com
[email protected]
AIM: Precisiontuning1
Fax: (732)451-0110
Precision Tuning is offline
Old 10-06-2006, 03:58 PM   #2
Precision Tuning
Member#: 38696
Prodrive’s 3 Port Boost Solenoid is designed to allow any aftermarket engine management system to more effectively control boost at higher pressures. It is a vast improvement over the factory Subaru solenoid, which becomes progressively more difficult to control at higher boost pressures. No cutting or soldering nessacary, included harness provides for an easy plug & play installation!!!
Included:
  • Boost Solenoid
  • Wiring Harness
  • Mounting Bracket
Regularly $99.00,
ONLY: $90.00!!!!
GReddy Informeter
Included:
  • OBD Cable
  • OBD II Cable
Regularly $360.00, ONLY $275!!!
Choice of White or Black
Included:
  • V-Band Clamp
  • Tial Sticker
Regularly $250.00, ONLY $225!!!
CobbAccessPORT
Ability to use AccessECU maps without removing ECU
10 Instantly Switchable Maps
Read and Clear Check Engine Lights
Download new maps via the Internet
Revert back to Stock programming
2 In Stock
  • 2006 Legacy GT Auto
  • 2006 Legacy GT Manual
Included:
  • AccessPORT
  • OBDII Cable
  • Serial Cable
  • AccessPORT Software
  • A/C Cable
  • User Guide
Regularly $645.00,
ONLY: $620 SHIPPED!!!
Worx TuningCatless Turboback Exhaust
The Worx Tuning Turbo-Back upgrade will provide a deeper, throatier performance sound without excessive uncomfortable resonation associated with many performance systems on the market. Throttle and boost response, and overall performance is noticeably improved due to our free flowing design. Available cat-less, or with an ultra high flow Metallic Substrate Catalyst. With a low to mid 30 lb. weight, it will shave 20+ pounds off of your vehicle weight, and the fully polished stainless system looks great too.
Features:
  • 3" aircraft grade 304 Stainless Steel Construction
  • Flanged and slip fit joint construction
  • Includes all necessary clamps, hardware, and gasketing
  • 1 piece design Downpipe for cleaner exhaust flow path
  • A/C Cable
  • Made in the USA with a LIFETIME MANUFACTURER'S WARRANTY
Sold!!!!
Subaru Factor TGV Delete Set
PM for Pricing!!!
Thank You!
Kyle
B]
Last edited by Precision Tuning; 12-14-2006 at 02:13 PM. Reason: Sharpened the purple crayon.
Old 10-18-2006, 08:54 PM   #3
Precision Tuning
Member#: 38696
MORE SPECIALS!!!!!!!
Old 10-19-2006, 07:02 PM   #4
Precision Tuning
Member#: 38696
Still in stock!!!
Old 10-20-2006, 10:09 AM   #5
Precision Tuning
Member#: 38696
No more RED TiAL Blow Off Valves. Still have a couple blue, silver and purples though!!!
Old 11-14-2006, 02:50 PM   #6
kessler89
Member Sales Rating: (12)
Member#: 74279
98 OBS
red and rust
pm sent......
kessler89 is offline
Old 11-15-2006, 03:47 PM   #7
Precision Tuning
Member#: 38696
Originally Posted by kessler89 View Post
pm sent......
Pm returned.
Thanks!
Rich
Old 11-17-2006, 09:54 PM   #8
senson
Member Sales Rating: (1)
Member#: 98572
2006 06 Evo
Christmas
All those prices are included shipping?
Thanks
senson is offline
Old 11-18-2006, 02:12 PM   #9
Ray_STi
Member#: 97683
2005 WRX STi
CGM/Gold - Element GT52
does the prodrive boost solenoid require a re-tune ?
Ray_STi is offline
Old 11-20-2006, 05:35 PM   #10
Precision Tuning
Member#: 38696
Thanks
You have a PM!
Rich
Old 11-20-2006, 05:39 PM   #11
jml1221
Member Sales Rating: (2)
Member#: 127109
06 White STy
It's too windy......
shipped price for HKS Carbon Ti to 60139? thank you.
jml1221 is offline
Old 11-21-2006, 09:59 PM   #12
Precision Tuning
Member#: 38696
You have a pm!
Rich
Old 11-24-2006, 10:54 PM   #13
Precision Tuning
Member#: 38696
Subaru Factory TGV Delete Set Added
Old 11-25-2006, 10:12 PM   #14
Precision Tuning
Member#: 38696
Weekend Bump!
Old 11-27-2006, 03:53 PM   #15
Precision Tuning
Member#: 38696
Bump!!!!!
Old 11-29-2006, 09:10 PM   #16
Precision Tuning
Member#: 38696
Old 12-09-2006, 03:21 PM   #17
Precision Tuning
Member#: 38696
Have 1 more set of factory TGV deletes.
Old 12-10-2006, 11:10 PM   #18
Precision Tuning
Member#: 38696
Old 12-19-2006, 09:30 PM   #19
Precision Tuning
Member#: 38696
Old 12-23-2006, 05:35 PM   #20
Precision Tuning
Member#: 38696
Old 12-26-2006, 08:29 PM   #21
Precision Tuning
Member#: 38696
Old 12-29-2006, 02:03 PM   #22
Precision Tuning
Member#: 38696
Ttt
Old 01-05-2007, 07:35 PM   #23
Precision Tuning
Member#: 38696
Bump because we "closed" a 1/2 hour ago but we're still here working on cars
Old 01-06-2007, 01:46 AM   #24
LeeC
Member Sales Rating: (229)
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
PMed
LeeC is offline
Old 01-11-2007, 10:21 AM   #25
Precision Tuning
Member#: 38696
Closed Thread
Great pricing on act,apr,hks,cobb,cusco,jic,greddy,seibon,zerosport s and more! Touge Motoring SCIC Vendor Classifieds 4 09-23-2009 06:22 PM
FS: PE, UR, AVO, Vishnu, TXS, Greddy, Kartboy, Cobb, HKS, Samco, Blitz and more! JayGold Engine/Power/Exhaust 41 10-20-2008 03:10 PM
August Specials. Turbosmart, Tial, HKS, JE, Manley and more! Precision Tuning Engine/Power/Exhaust 18 09-06-2007 09:52 AM
TXS/Invidia/RSR/HKS/Greddy/Tanabe/Koyo/Magnaflow and more, the NASIOC blowout! CVR Motorsports Engine/Power/Exhaust 69 08-12-2005 11:23 AM
Tein Basics $920! Goodridge+Motul combo, Greddy, HKS, ACT, Prodrive, Cobb Access Port Aerosim Research Ltd Vendor 'For Sale' Classifieds 45 03-15-2004 02:34 PM
