Old 10-06-2006, 03:34 PM   #1
hilfiger4you
Member#: 93015
02 wrx
black
Default Are power slot rotors and hawk hpplus pads suppose to squeak
Hi,
I just changed new powerslot rotors and hp plus pads for my sti. It brakes great. However, when coming to a slow stop, the rears sqeak very loud that it hurts my ears if the windows were down. However, at high speeds stopping it is very quiet. My installer said it is normal for the loud sqeak and when he sees me he may be able to do something to lessen the sqeak. I was wondering if this is normal with these rotors and pads? I mean I do not want to look like an idiot every time I come to a stop because it is pretty annoying. Please advise
thanks
hilfiger4you is offline   Reply With Quote
Old 10-06-2006, 04:36 PM   #2
toosteeley
Member#: 90570
HP + pads squeal. It's normal.
toosteeley is offline   Reply With Quote
Old 10-06-2006, 04:42 PM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Fact of life with aggressive pads
Old 10-06-2006, 04:52 PM   #4
Jasper
Member#: 80136
2006 Ford F-150
mine squealed for ~ 5000-6000 miles. they almost never make a peep now though.
Jasper is offline   Reply With Quote
Old 10-06-2006, 11:52 PM   #5
hilfiger4you
Member#: 93015
02 wrx
black
thanks for the replies, but my squeak is so loud that people look at me and I feel like a dumbass driving a STI.
Old 10-07-2006, 01:24 AM   #6
Butt Dyno
Member#: 17301
is the "dark side"
Why did you buy HP+ pads?
Old 10-07-2006, 11:31 AM   #7
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Originally Posted by ButtDyno View Post
Why did you buy HP+ pads and then complain about noise/dust/rotor wear?
Fixed it for you -
I pretty much say it all the time..
There is no free lunch in brakes - Brembo's are noisy - shims/goo/CRC are band-aids that can help - but are unlikely to eliminate the problem. And HP+ pads are about as much as you can ask for in a streetable pad - you will miss the braking response if you go back to a pure street pad. If you don't then you shouldn't have bought them.
In my FHI 4 pots the HP+ are not that noisy - just an occasional squeak at slow speeds - light pedal. I do not know why people make so much issue of the noise unless I am just lucky to have quietish brakes.
Have you bedded them in? Did you re-use the factory shims (I didn't but...)
-Ken
KNS Brakes is offline   Reply With Quote
Old 10-07-2006, 11:48 AM   #8
racekar
Member#: 107988
they squeak a lot but i use them for track so it doesnt bother me
racekar is offline   Reply With Quote
Old 10-09-2006, 07:06 PM   #9
hilfiger4you
Member#: 93015
02 wrx
black
my tech recommended it and he is really good. He says hp+ are great pads even for street use and they brake so well but the noise is unbearable. He said he wants me to bring in the car and try to do something to the shims and calipers to reduce it a bit but it might not got away/
Old 10-09-2006, 09:45 PM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Do a track day and they will be fine. They tend to make a crap load of noise until they get really hot a few times.
Old 10-09-2006, 11:00 PM   #11
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
They do stop squeaking if you get them into their temperature range, but after a couple of weeks of tooling around town, they start squeaking again. HP+ is a great pad, but not if noise and dust really bug you.
After a while you may get used to the noise and actually think it's cool.
PJC1909 is offline   Reply With Quote
Old 10-09-2006, 11:16 PM   #12
SoutFL_9-2x
Member#: 105424
'13 Forester 2.5X
I've gone through a set over the past 7 months. They were really loud at first- lots of noise. Now that they've been heat cycled to oblivion, they're nice and quiet Time for a new set.
SoutFL_9-2x is offline   Reply With Quote
Old 11-18-2006, 06:08 PM   #13
hilfiger4you
Member#: 93015
02 wrx
black
My tech, sorta fixed the noise. HE put some type of stuff in between the shims like a lube of some sort and they are quiet. He also put a sheet of aluminum padding in between each pad. HE said the hp plus pads are great at braking but the scarafice is noise. I get loud squeak high pitched only when the car is slowing to a stop with light pedal braking. If I brake hard on the highway or road no noise.
I guess these pads are just aggressive.
Old 11-18-2006, 09:27 PM   #14
SoutFL_9-2x
Member#: 105424
'13 Forester 2.5X
The silicone brake grease he put in there will burn off. You will have loud pads again. HP+ are loud. No way around it.
Stock front calipers Power Slot rear rotors and Hawk HPS pads for 2002 WRX MTL_SLVR_WRX Suspension/Brakes/Handling 1 06-22-2010 11:17 AM
04 WRX STI front Brembos with slotted rotors and hawk pads anjion24 NWIC Private Classifieds 2 06-09-2009 12:31 AM
BNIB: Slotted Rotors and Hawk Pads jconaty07 Tri-State Area Private Classifieds 1 04-21-2009 01:21 PM
DBA 4000 series slotted rotors and Hawk Hps Plus pads 02subyrube Brakes, Steering & Suspension 16 04-18-2009 05:20 PM
