Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 11-05-2001, 08:47 PM   #1
po1010
Member#: 9346
2002 WRX Wagon
Unhappy remove transmission oil
Does anyone know how to remove transmission oil and rear differental oil. Last night I really could not find the transmission oil cap. Does anyone has pic.
po1010 is offline   Reply With Quote
Old 11-05-2001, 08:51 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I have an instruction for MY01 RS.
http://www.geocities.com/matsut_rpi00
Then click on "Maintenance".
tmat3 is offline   Reply With Quote
Old 11-05-2001, 11:09 PM   #3
STORER
Member#: 2253
2000 2.5 RS
Red
Since that link isn't working I'll describe how to do this.
Rear Differential
1. take a 1/2" drive rachet and remove lower plug on back of rear differential.
2. While the fluid is draining into a container wipe the swarf off of the magnetic drain plug.
3. Install drain plug.
4. Remove top plug and fill rear differential with specified fluid until it leaks out of fill hole.
5. Install fill plug.
Manual Transmission/Front/Center Differential
1. Take a 1/2" drive rachet with an extension bar and a 21mm socket and remove drain plug on the underside of gear box.
2. Wipe swarf off of magnetic drain plug.
3. Install drain plug after gear box is drained, but Do Not torque down plug to much because gear box is cast aluminum.
4. Fill gear box through dip stick hole. You will have to remove your air intake (which is simple) and use a funnel.
I used Mobile One synthetic gear lube as spec. in owners manual. The lube came in bottles that had a small tip that helps fill small ports.
Hope this helps!
Steve
STORER is offline   Reply With Quote
Old 11-06-2001, 12:19 AM   #4
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
on the wrx you don't need to remove the intake.
Just look under the intercooler on the passenger side, there's a dipstick. Get a small funnel and you can pour your new mobil1 75w-90 right down in there.
TRans is under 4quarts and it seems like the rear diff is about .5 or so. I'm sure the specs are in the manual
syntrix is offline   Reply With Quote
Old 11-06-2001, 06:46 AM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Stupid Geocities.... Basically, what I have on my site is described by STORER.
If you have a torque wrench, torque the drain bolts to 30lb/ft of torque.
Old 11-06-2001, 08:17 AM   #6
Austin
Member#: 7089
Tranny/Front diff capacity is 3.7qts, drain plug torque spec 32.5ft/lbs. Rear diff capacity is .7 qts, which doesn't matter because you can't overfill anyway, drain plug torque spec is 36.3ft/lbs.
Swarf is a cool word
Austin is offline   Reply With Quote
Old 11-06-2001, 02:01 PM   #7
Corpsie
Member#: 10502
'04 Ford Ranger 4x4
Red Metallic
What does "swarf" mean exactly?
Corpsie is offline   Reply With Quote
Old 11-06-2001, 02:09 PM   #8
STORER
Member#: 2253
2000 2.5 RS
Red
Swarf is the fine metal chips left from a grinding or microfinishing opperation. I design microfinishing machines so it's a common word for me. It dose sound cool!
Steve
Old 11-06-2001, 03:54 PM   #9
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Talking Can of worms
Syntrix,
no syncro issues with Mobil 1 75W90? I was thinking about Redline 75W90ns in my tranny, or some other quality synthetic, but it seems some folks have problems grinding gears.
I am assuming (hoping) that for my purposes - street driving, no track - that I will be OK.
Stanley is offline   Reply With Quote
Old 11-06-2001, 10:46 PM   #10
jlyttle
Member#: 2815
2004 Forester XT 5sp
I just did both of these on Sunday. I used Mobil1 75w90 in the rear, redline 75w90ns in the tranny. No grinding, shifts great. No sluggishness in the stick on cold mornings. The trans plugis directly behind the oilpan.
jlyttle is offline   Reply With Quote
Old 11-07-2001, 12:25 AM   #11
po1010
Member#: 9346
2002 WRX Wagon
when is the good time(mileage) to remove transmission oil and rear diff.
Old 11-07-2001, 01:30 AM   #12
HomerJay
Member#: 1135
2005 WRX WAGON
Since you live in the City, about every 5K j/k. You can actually wait till about 30k but it depends on your driving style and where you live. Definitely sooner if you live in the city.
-JOE
HomerJay is offline   Reply With Quote
Old 02-21-2002, 12:13 PM   #13
DownSouth
Member#: 5440
2004 WRX Wagon
Question plug sealant
My manual says that you sould put some sealant around the rear differential drain/refil plugs. It says specifically
Three Bond 1105
I have no idea what that is. Any suggestions? I know it's to seal it up, so i want to use something. What can you substitute? (Preferably something I can buy at NAPA or AutoZone or someplace.)
Thanks, BOB
DownSouth is offline   Reply With Quote
Old 02-21-2002, 12:24 PM   #14
DownSouth
Member#: 5440
2004 WRX Wagon
Question transmission plug gasket
One more thing.....
The manual says that there is an aluminum gasket for the transmission drain plug (MT) that must be replaced. Do you really need to replace it?
I haven't seen this mentioned in the searches I've done (and I've done alot!) I hate asking repetitive queastions! Thanks, BOB
Old 02-21-2002, 12:33 PM   #15
alfaguy
Member#: 14238
2002 WRX Wagon - PSM
Alfas: 89 Milano | 72 GTV
Here's a general suggestion that has saved my a$$ a few times when draining transmissions, diffs, or transaxles:
Before you remove the drain plug, make sure you can get the filler plug loose. Imprezas are new enough that they probably won't be siezed on, but it could happen.
alfaguy is offline   Reply With Quote
Old 02-27-2002, 06:44 AM   #16
Frederf
Member#: 15622
2002 WRX SW
Good idea, make sure you can finish the job before starting it.
Frederf is offline   Reply With Quote
Old 02-27-2002, 09:07 AM   #17
donjuan
Member#: 2248
DownSouth--There is an aluminum ring on the tranny drain plug. I had planned to replace it, but when I removed the plug, I noticed that it's just that a ring, not an actual crush gasket like on the engine oil drainplug. I decided NOT to change it, and I have no leaks, but it couldn't hurt anything, I'm sure it's cheap.
donjuan is offline   Reply With Quote
Old 02-27-2002, 10:10 PM   #18
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
I didn't replace mine, but I also forgot to put it back on I think I'll be attempting that this weekend.
The torque specs are 32.5 lb-ft for the transmission drain bolt and 36 lb-ft for the rear differential drain and fill bolts. All though if this is your first time taking them off, they'll be torqued down much more than that...
jhonas is offline   Reply With Quote
Old 02-28-2002, 10:32 AM   #19
DownSouth
Member#: 5440
2004 WRX Wagon
Thanks for all the info everybody! This site is a huge resource for me.
I had a machinst make me a square drive to fit the rear differential drain plug. I'm going to try it this weekend, if it works I will post pics and dimensions. It was treally easy to make.
Old 03-01-2002, 01:02 AM   #20
Austin
Member#: 7089
Why did you have a 1/2" drive machined when you can get a 1/2" drive ratchet for $2 at an el-cheapo autoparts store?
Old 03-01-2002, 11:45 AM   #21
DownSouth
Member#: 5440
2004 WRX Wagon
Well, the hole is not a 1/2" square hole. I wanted something that was the proper fit, not just good enough. The place I work has a machine shop, and it only took a couple of minutes to finish, so I figured why not?
I bought a 1/2" to 3/4" drive adaptor and had the 3/4" milled down to a 0.525" square. (1/2" drives are actually not 0.500")
The new drive fits the hole perfectly and I'm going to use it for the first time this weekend.
Besides, I'm an engineer and I do nerdy things. BOB
Old 03-04-2002, 07:28 PM   #22
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
Default Differential plug sealant
Since the plug looks for all the world like a 3/4 inch pipe plug, it even screws into a 3/4 fitting, I would sugggest using teflon tape pipe dope on it. This has the advantage of not hardening or "glueing" the plug in. It will be a lot easier to get out next time.
fredj is offline   Reply With Quote
Old 03-09-2002, 05:13 PM   #23
WRXVII
Member#: 15854
VF34'd...
Stock transmission oil is green? is that right?
WRXVII is offline   Reply With Quote
Removing Transmission, CAN'T remove front drive axles. Hotrodguru Transmission (AT/MT) & Driveline 14 08-08-2007 03:58 PM
Oil change and Transmission oil change help in Ann Arbor Scuter83 Mid West Subaru Owners Club Forum -- MWSOC 12 09-11-2006 10:53 PM
transmission oil and engine oil change guynexdoor Newbies & FAQs 5 07-03-2006 12:39 AM
Front differential oil = transmission oil? WRXVII Service & Maintenance 8 03-19-2002 11:46 PM
Is it bad to change the engine oil and automatic transmission oil at 2-3000km?? V6 Normally Aspirated Powertrain 1 10-27-2000 09:08 AM
