Old 11-05-2001, 09:29 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Thumbs up Subaru boost gauge...nice!
Obviously, a gauge is simply a measuring instrument, but in terms of sensitivity, feel, look and (important) placement, it's a really nice piece. I'm quite impressed, and with its location right by the tach, it's in easy view, as opposed to the gauge pack, which requires that you focus on two places at once, so to speak.
Oh...I know...other gauges are cheaper, yada, yada. Sorry, I support the home team whenever possible. I love this thing!
Oh...anyone know what pressures the numbers correspond to?
Kevin
gtguy is offline   Reply With Quote
Old 11-05-2001, 09:46 PM   #2
cnstman
Member Sales Rating: (4)
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Default some help
.1 Mpa = 14.7 psi i think. from there you can do some math to figure out the rest
i have the factory gauge pack, and i love it. i have a big audio system so the volt meter is a plus to me.
cnstman
cnstman is offline   Reply With Quote
Old 04-14-2002, 02:17 AM   #3
PaulRex
Member Sales Rating: (3)
Member#: 12454
10 Toyota Taco
K8 SV650SF
I have factory guage pod too, and i like it and all but..
ITs too expensive i think..
The lamco guages are way too SMALL!
the boost guage is the worst lit of all mine and i've seen a few other pods and its the same on all of them. Anyway, i'm going to have to buy some other guages
PaulRex is offline   Reply With Quote
Old 04-14-2002, 04:11 PM   #4
SoLiDbReAkZ
Member#: 13736
Conversion Factor:
MPa x 145.04 = PSI
WARNING:
punching keys on calculator at high speeds may cause severe damage to vehicle and occupants.
SoLiDbReAkZ is offline   Reply With Quote
Old 04-14-2002, 08:36 PM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
.1MPA on factory guage converts to 14.504psi
.11MPA = 15.95psi
.12MPA = 17.4psi
.2MPA = 29psi! you get the idea
Old 04-15-2002, 01:06 AM   #6
WRXWES
Member#: 5756
2004 Jeep Rubicon
I took the little green condom off of the light bulb because it was too dim at night. Now it's a lot easier to see at night.
-Wes
WRXWES is offline   Reply With Quote
Old 04-23-2002, 04:08 PM   #7
Bauhaus
Wiped Out By KGB (For Good)
Member#: 9515
WR Blue
I have heard that the gauge PACK turbo is poorly lit, but what aboot the steering colum gauge? Is that bright enough? I just ordered mine today.
Bauhaus is offline   Reply With Quote
Old 04-23-2002, 11:27 PM   #8
peczenij
Member#: 16791
2004 WRX STi
WRBlue
Default Free convert software.
Get it here...
http://download.com.com/3000-2056-44...ml?tag=lst-0-1
Converts anything you need including megapascal, MPA to PSI or BAR.
Download.com, convert 4.1
Description
Convert is an easy-to-use unit-conversion program that converts many commonly-used units. Units it supports include distance, temperature, volume, time, speed, mass, power, density, pressure, energy, and many others. Other features include the ability to create custom conversions.
peczenij is offline   Reply With Quote
Old 04-30-2002, 11:48 AM   #9
MackDaddy
Member Sales Rating: (2)
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Thumbs up
Mine seems plenty bright. No bulb "condom" on it from what I can tell.
MackDaddy is offline   Reply With Quote
Old 04-30-2002, 01:59 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
My guage pack is only poorly lighted in the turbo guage, why? because the other guages only need to be lighted in the top half of the guage, while the turbo boost guage needs to be lighted all the way around the the same small bulb as the others, so it has a more dificult time. If the guage was a bit bigger i might be able to read it accuratly at night, but i can hardly make it out sometimes if i give a quick glance. Maybe my bulbs have a green "condom" on them too as previously suggested by wrxwes?
Old 05-02-2002, 09:48 AM   #11
WRXWES
Member#: 5756
2004 Jeep Rubicon
I was talking about the column mounted single gauge.
-Wes
Old 05-02-2002, 11:57 PM   #12
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
i think they are basically the same thing, made by Lamco right? I havn't had a chance to check my guage yet to see if that covering is on it.
Old 05-10-2005, 03:45 PM   #13
Tricky
Tu ne cede malis sed contra audentior ito
Member#: 28960
2002 Stock WRX Wagon
MBP with door dings
I recently aquired a OEM coloumn mounted boost gauge.
So they are supposed to be poorly lit on the lower half as per the other OEM optional gauges?
Tricky is offline   Reply With Quote
Old 05-12-2005, 06:35 AM   #14
SpaldingSpeed
Member#: 83640
2005 Impreza WRX STi
World Rally Blue Pearl
my OEM boost gauge is lit perfectly...............
SpaldingSpeed is offline   Reply With Quote
Old 07-26-2005, 04:46 AM   #15
STi-JDM
Top Scoob 023
Member Sales Rating: (183)
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
mine is okay... I kinda like it
STi-JDM is offline   Reply With Quote
Old 08-09-2005, 11:04 AM   #16
shasta1
Member#: 23503
2003 WRX
Sedona Red
Post True Boost
Hey guys, I am developing an overlay for the stock boost gauge which converts it into PSI accurately. I am at the R&D stage of the final prototype now. Would this be a product you would be interested in?
shasta1
shasta1 is offline   Reply With Quote
Old 10-03-2005, 08:57 AM   #17
innova
Member Sales Rating: (1)
Member#: 97472
2005 PDX STi
Aspen White [email protected] woot
My stock oil temp gague stopped working and I had it replaced... found out that the filiment bulbs that light them create too much heat. I replaced them with LED's and they are now cool to the touch and look great.
innova is offline   Reply With Quote
Factory Subaru boost gauge? rallytuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-20-2002 04:27 PM
Subaru Boost Gauge Pics? Bauhaus Interior & Exterior Modification 6 04-18-2002 10:30 PM
Subaru Boost Gauge ? Conversion SGOSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-07-2001 06:52 PM
Does the Subaru boost gauge interfere with steeing wheel tilt travel? gtguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-21-2001 09:05 PM
buzzing from Subaru Boost gauge on boost? Cosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-29-2001 11:47 AM
