Old 10-07-2006, 04:48 AM   #1
scoooby03
Member#: 110654
Default fuel pressure regulater
I got 67k on my 03 Wrx. When do you usually replace the fuel pressure regulater? How can you test it to see if it is working properly?
scoooby03 is offline   Reply With Quote
Old 10-07-2006, 08:52 AM   #2
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
The FPRs are usually pretty durable. I believe the run at 35psi @ idle with vacuum line disconnected.
It one fails, it fails on the side of TOO MUCH pressure. It can spike up to 65-70 lbs and cause the car to run so rich that the ECU can't compensate. You'll usually get a CEL at that point however (system too rich).
If you find that you need one I have a brand new one just sitting in my house for an 03 WRX. I believe Subaru charges $104.00 for one.
PM me if you need one and I could sell you mine for less $$$.
Good Luck!
skimobile is offline   Reply With Quote
fuel presure regulater intallation.. emsti2004 Water/Methanol Injection, Nitrous & Intercooler Cooling 4 07-16-2008 10:48 AM
fuel preasure regulater dohced Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-10-2005 06:43 PM
Fuel Pressure or Oil Pressure? krave Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-01-2002 11:59 AM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
Fuel Pressure Regulater Sam Kaufman General Forum Archive 2 12-10-2000 10:08 PM
