Old 10-07-2006, 09:26 PM   #1
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Default Alky hookup?
I have two 05 STi's and I just bought coolingmists varicooler kits. My question is where is a good 12volt switched wire that can handle 15amp load.... Otherwise I am going to add a relay and just trigger the relay with the cigarette lighter (because it is a switched lead). Thanks.
Sinister redlines is offline   Reply With Quote
Old 10-07-2006, 10:01 PM   #2
dibblejr
Member#: 94070
05 LGT
Why dont you just buy a switch instead of splicing to your cigarette lighter?
Coolingmist offers a switch, or you can buy one for a couple dollars at autozone ect.
Jay-R
dibblejr is offline   Reply With Quote
Old 10-07-2006, 10:19 PM   #3
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Because If I forget to turn it on and since I will be tuned with a fpgreen and alky I will smoke the block.
Old 10-07-2006, 10:20 PM   #4
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Basicly I need the system to come on with the ignition switch, but it has to be on a system that can handle 15amps (system only needs 10amps but I want a saftey margin)
Old 10-07-2006, 10:38 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Would it hurt anything to use a relay?
peace
Old 10-07-2006, 10:58 PM   #6
dibblejr
Member#: 94070
05 LGT
There's the problem with a switch... " If I forget to turn it on". If you connect it as stated in the directions it will come on when you turn the key on without failure.
Depending on what cotroller you got you may have an LED(s) to indicate power.
SUGGESTION: When you get everything wired and connected, before connecting your fluid line to the injector, first rout it to the windshield and test drive the car to ensure fluid is flowing.
You also need to get tuned for it.
If you are the type that races every rice car you see for system / engine safety hook it uo as in the directions. If you are the type of person that knows there is a time and place for power then you should be able to connect a switch.
Jay-R
Old 10-08-2006, 12:34 AM   #7
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Jay-R
This thinking is fine if you are using a utec with map switch BUT I am using cobb ap so when I get tuned and have it setup and the alky isnt running BOOM. And NO I race at the track not the streets, this way my kids know I will make it home OK. In other words I am in my 30's and not a kid trying to prove that my car is faster than yours.
I want this setup to run all the time with the engine on so by the looks of it the relay is the way to go.
Old 10-08-2006, 12:35 AM   #8
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I realize you are trying to help but I have run alky setups in cars before just not a STi. I am looking more for where is everyone else hooking theres to otherwize I will go with my above stated plan.
Old 10-08-2006, 06:21 AM   #9
hippy
Member#: 36528
2002 Impreza Wrx
It would probably be wise to use a relay, get the power from the battery, and switch it on with an ignition source just cause it couldn't hurt anything. I don't run a coolingmist kit, but my kit is wired this way. Coolingmist has said in other threads that this is not necessary.
peace
Old 10-08-2006, 08:44 AM   #10
dibblejr
Member#: 94070
05 LGT
I also use the AP, at least as a map manager. At stage 4+ I rely on my tuner. I have been runny my setup for a long time without failure.
I am 40 so I also have nothing to prove to the kids.(lol)
If you use the boost to control the alky then the alky only runs during your set boost, it is not always pumping alky. However the power is always on.
Good luck
Jay-R
Old 10-11-2006, 02:42 PM   #11
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
I do know what you are talking about. I am tuned for the ALKY so we go full throttle and the ALKY does not spay, we will have a very large bucket of spare parts on our hand. I feel your pain
JMK508 is offline   Reply With Quote
If anyone is looking for GOOD vinyl stickers and etc... hookup bigbird Mid Atlantic Impreza Club -- MAIC 2 06-01-2001 11:40 AM
Anyone have a hookup for Oakleys? ColinL Mid West Subaru Owners Club Forum -- MWSOC 13 05-25-2001 04:08 PM
Profec-B Hookup on T25 HELP- - - - GhostRide Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-30-2001 07:03 PM
anyone have hookup for mounting tires to rims??? Aspen Mid West Subaru Owners Club Forum -- MWSOC 15 12-19-2000 09:22 AM
Amp hookup question Leg93 Legacy Forum 1 09-20-2000 07:54 PM
