Old 10-08-2006, 03:35 PM   #1
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
Default 245/45/17 on stock sti rim
i've been doing some searching and i couldn't find a direct answer to this question....i wanna get some Kumho v710s (245/45/17)...but i want to put them on my stock rims....am i gonna have alot of problems like rubbing or sidewall flex?
Alpha_32 is offline   Reply With Quote
Old 10-08-2006, 10:27 PM   #2
MartinD
Member#: 57231
You will be fine. That is a good size to run...
MartinD is offline   Reply With Quote
Old 10-08-2006, 10:36 PM   #3
Alpha_32
Member#: 35876
Grey
aight thx
Old 10-08-2006, 11:00 PM   #4
Chiketkd
Member#: 71634
In hibernation...
You should go to 275's. That's the tire to run on '05+ STIs with the 17x8" rim...
Chiketkd is offline   Reply With Quote
Old 10-09-2006, 10:32 AM   #5
Alpha_32
Member#: 35876
Grey
that is pretty damn wide...
Old 10-09-2006, 12:39 PM   #6
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
245/40/17.. little closer to stock sidewall
Rexxyou is offline   Reply With Quote
Old 10-09-2006, 01:57 PM   #7
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
+1 there.
salaki is offline   Reply With Quote
Old 10-09-2006, 01:59 PM   #8
qingshan
Member#: 81322
12/6 Sti/Fo
swp/CGM
Diameter is acually a bit smaller - tire is wider but shorter (about 10 whole rev's more per mile)
qingshan is offline   Reply With Quote
Old 10-09-2006, 03:22 PM   #9
Chiketkd
Member#: 71634
In hibernation...
If you're running 245 V710's on a stock rim then I assume you're in A Stock?
With the STI gear ratios on the '04-'06 STi, you typically have to shift between 1st, 2nd and 3rd on a high speed autoX circuit. Going to 275/45/17 r-comps, will make your second gear good to ~60-61mph. These tires will give you more mechanical grip than 245 r-comps, and cut down on the amount of shifting you will need to do during an autoX (fast shifts take ~0.3-0.4 seconds).
The STi/WRX are nose heavy and camber challenged, and need as much rubber on the ground as possible.
Btw, the '05 STi driven Jonathan Roberts that won the A-stock Pro Finale and finished 4th in Solo Nationals was on 275 r-comps.
Old 10-09-2006, 07:44 PM   #10
Alpha_32
Member#: 35876
Grey
i'm acctually in E Street Prepared
Old 10-09-2006, 07:49 PM   #11
WillisW555
Member#: 102625
2006 WRX STI
WR Blue
Uhm, do you have to roll the fenders to cram a 275 in there?
WillisW555 is offline   Reply With Quote
Old 10-09-2006, 08:13 PM   #12
Chiketkd
Member#: 71634
In hibernation...
Nope. They fit under there just fine. If you do a search in the Motorsports section you can find the exact size the top A-Stock drivers are using. I'm 90% sure it's 275/45/17, but it might be 275/40/17...
Old 10-09-2006, 08:14 PM   #13
Chiketkd
Member#: 71634
In hibernation...
All STi's are in BSP as of 2006 (allowed unlimited boost on stock turbo). The '02-'06 WRX is in ESP.
Old 10-09-2006, 10:18 PM   #14
Alpha_32
Member#: 35876
Grey
oh? when i was checking my classing recently it said ESP....
oh nm i guess myautoevents had a old link or somthing......it is BSP........i was definatly running in the wrong class last weekend >_>
Old 10-09-2006, 10:39 PM   #15
Chiketkd
Member#: 71634
In hibernation...
Confirmed the tire size A-Stock STi drivers ('05+) are using on a 17x8" stock wheel - 275/40/17 V710's.
Old 10-10-2006, 01:05 AM   #16
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
275 FTW! I only wish they'd fit on my ESP wrx. Go to the motorsports section and check out the wide tire thread.
eyeballs is offline   Reply With Quote
Old 10-10-2006, 01:18 AM   #17
Ewok
Member#: 128671
What negative camber are guys with 275's able to run?
Ewok is offline   Reply With Quote
Old 10-10-2006, 11:50 AM   #18
Chiketkd
Member#: 71634
In hibernation...
They max out the factory camber bolts at roughly -1.5 degrees up front. In the back you want to run about -1 degrees or less (to make the tail end come around more easily).
Old 10-16-2006, 12:13 PM   #19
Slow_Boy
Member#: 104034
05 BPU STi
[email protected]
So this size(245/45/17) will fit the sti rims without any problams?
Slow_Boy is offline   Reply With Quote
Old 10-16-2006, 12:35 PM   #20
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
It just boggles my mind when people talk about running 275's and not rubbing. I ran 245/45-17's and rubbed in the rear with -1.6 camber. Given, I was on a lowered suspension, but it was not "slammed". And I've seen 275's on an 8" wide wheel and the sidewalls are so bent over that the outter 1/2" of tread doesn't even touch the ground. Not criticizing, just observing and surprised.
Old 10-16-2006, 02:05 PM   #21
gslben
Member#: 106753
2005 STi OBP
Use this.
http://www.miata.net/garage/tirecalc.html
gslben is offline   Reply With Quote
Old 10-16-2006, 03:20 PM   #22
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
The 245/45-17 will fit just fine with zero problems. If you are running AS with this car then you can go up to the 275/40-17 with 3mm spacers front and back and it will fit fine. That is what the 2006 AS ProSolo National Champ ran and it sure worked well for him. =)
<edit>
Since you are running BSP and an 8" rim the same applies to you. Although you can now run front camber plates and larger front spacers if you wish.
-Paul
AtomicRacer is offline   Reply With Quote
Old 10-16-2006, 03:24 PM   #23
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
If you were rubbing with that size tire you did something wrong with your setup. There is enough room to run 275's without rubbing in an AS ruleset. If they can do it so can you.
-Paul
Old 10-16-2006, 03:27 PM   #24
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
Correct.
-Paul
Old 10-16-2006, 05:58 PM   #25
mav1c
Hoodbridge!
Member#: 560
-Paul
Well, I did nothing wrong. I've changed suspensions at least 30 times, so I'm no newbie. I think part of it was due to the large, bulging sidewalls on the Nitto NT-01, and part was due to the too soft springs. Anyway...I really doubt 275/40-17's on a car with a lowered suspension, and run at the track, would not rub. Only way would to be to run SUPER stiff springs. This past weekend I saw an STI at the track with 255/40-17 RA-1's on 17x9.5 +44 wheels and he had to REALLY roll his fenders to keep from rubbing. I guess that was all the extra wide wheel.
Anyone in the TXIC, running 245/45/17 on stock suspension? _sti_05 Texas Impreza Club Forum -- TXIC 10 02-06-2007 11:56 AM
245/45/17 on stock 2004 sti ? rapidus Tire & Wheel 16 03-30-2006 12:10 PM
Advice: 235/45/17 or 245/45/17 on '05 STi palpullero Tire & Wheel 22 03-08-2006 02:05 PM
245/45/17 on an STi? AugustusMaximus Tire & Wheel 4 11-28-2005 01:50 AM
245-45-17 on 17x8.5 do they fit an STI with TEIN FLEX coilovers? FLEMON Tire & Wheel 2 08-05-2004 11:00 PM
