Old 10-09-2006, 09:56 AM   #1
oldhat
Member#: 113036
Default Post pics of your setup!
Let's see where you placed the tank, pumps and nozzles. Curious to see how everyone's doing this.
oldhat is offline   Reply With Quote
Old 10-09-2006, 12:45 PM   #2
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
I'll bite, but only because I'm bored and just finished the install this weekend...
Edit, and the nozzle is attached to the undeside of my TMIC, like most people do
eqlized_aero is offline   Reply With Quote
Old 10-09-2006, 12:46 PM   #3
oldhat
Member#: 113036
Looks cool, is that the Cooling Mist kit? Where did you mount the nozzle?
Old 10-10-2006, 01:01 AM   #4
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Default My setup...
xbcaraudio is offline   Reply With Quote
Old 10-10-2006, 01:55 AM   #5
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
^ Nice stealth FTW
nosmo is offline   Reply With Quote
Old 10-10-2006, 10:51 AM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Originally Posted by xbcaraudio View Post
Any concerns with too much heat building up around the pump and shortening it's life in that spot? Any other possible downsides in that location?
offset
offset is offline   Reply With Quote
Old 10-10-2006, 11:16 AM   #7
KJR
Member#: 16879
Here's mine when I first installed the kit. I now have a 90 degree nipple off the tank for added floor clearance and an outside thread injector nozzle.
FYI to all Spec-C tank users: I am using the factory float level indicator with the Coolingmist float switch and the in-tank indicator is now sticking after 3 months of exposure to Methanol. I am now going to have to install the Coolingmist provided switch to see if it holds up....lol
KJR is offline   Reply With Quote
Old 10-10-2006, 12:18 PM   #8
tasq
Member#: 62362
2005 wrx
CGM
Dumbest controller location ever? I know my leg would hit those knobs alot...
tasq is offline   Reply With Quote
Old 10-10-2006, 12:23 PM   #9
KJR
Member#: 16879
Your only dumb if you place it there, and leave it there if your leg hits it! Hellooo?? Works perfectly fine for me.
Additionally, if you know anything about the Coolingmist controller, then you'll know that you can disable all of the knobs via the software
Old 10-10-2006, 12:26 PM   #10
tasq
Member#: 62362
2005 wrx
CGM
I didn't know they added the ability to disable the knobs... cool beans
Old 10-14-2006, 07:12 PM   #11
kn0bby8
Member#: 97644
2006 WRX
You might want to turn the tankaround. When yuo mash the gas the liquid int he tank will rush away formt he pump. If you had the tank the ther way the pump would only starve if you jammed on the brakes.
EDIT: Nw that I look at it better you should just turn the tank so the black cap is towards the front of the car.
kn0bby8 is offline   Reply With Quote
Old 10-16-2006, 11:13 AM   #12
Ultimate Collision Center
Member#: 69072
I like...
Ultimate Collision Center is offline   Reply With Quote
Old 10-16-2006, 12:06 PM   #13
CMTech
Member#: 121945
It draws water/meth from the bottom of the tank. As long as the low fluid light is not lit up, you will not have that problem regardless of what direction the tank faces.
CMTech is offline   Reply With Quote
Old 10-18-2006, 06:43 PM   #14
kn0bby8
Member#: 97644
2006 WRX
Good to know
Old 10-20-2006, 08:48 AM   #15
dibblejr
Member#: 94070
05 LGT
Tank and Pump under my SPT Intake, still have full access to remove the cap to add fluid. Tank is attatched to my SPT heat shield. Temp stays around 100 deg F.
Pic of where I mounted my injector nozzle
Pic of how I mounted my alky temp guage, contoller and IPAQ system monitor
Jay-R
dibblejr is offline   Reply With Quote
Old 10-22-2006, 12:29 AM   #16
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
Originally Posted by ULTIMATE CC View Post
I like...
Thats pretty F'n sneaky pete right there
THE-95-STi is offline   Reply With Quote
Old 10-22-2006, 12:31 AM   #17
Member#: 69072
That it is...
Old 10-22-2006, 12:33 AM   #18
Member#: 69072
Here are a few pics of the kit installed on my EVO
Using OEM windshiled washer tank
Controllers mounted on passanger side floor
Tank and pump installed
Power led and warning led
Old 10-22-2006, 10:51 AM   #19
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Here is my install of the Aquamist System 2d & DDS2 (Feb 05'):
The pump within the Spec-C tank is now used for a priming pump. This allows liquid to always be in-line so the Aquamist pump at the front of the car does not run dry and seize.
Here you will see the pump, accumulator and all the related electronics which were fitted behind the fog light cover on the passengers side. You can see the Aquamist water jet (.9mm) located on the cold side charge pipe of my FMIC (which has now been changed to an APS DR725):
Another view:
The black box shown under the DIN pocket is the control unit for the Aquamist System. It holds the DDS2 junction box, priming pump circuit, FIA, fuse for system and momentary switch to run the priming pump manually (which is also controlled by the System 2d automatically).:
We also took the DDS2 (flow sensor) apart and made remote mount LED's within the gauge cluster surround. For those that don't know the function of the DDS2, the green LED shows the system is armed and working, the other seven red LED's show the rate of flow. The LED's are also hooked up to my lights so they are fully dimmable.:
That's all for now....
Rick
ami2fst4u is offline   Reply With Quote
Old 10-22-2006, 03:07 PM   #20
nater
Member#: 105543
1965 Factory Five
Cobra, carbon fiber black
That is the best pic I have of it at the moment... The bracket was made by a friend of mine real quick, and bolts on like a dream.
nater is offline   Reply With Quote
Old 10-22-2006, 03:14 PM   #21
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
i'd like to see what the wagon guys are doin please...
Bishop is offline   Reply With Quote
Old 10-22-2006, 04:54 PM   #22
dibblejr
Member#: 94070
05 LGT
Check out my post #15, all alky monitoring and controls in the glove box which still closes to hide the system.
Tank under the intake.
Jay-R
Old 10-22-2006, 05:01 PM   #23
Bishop
Member#: 59993
Ass, grass or cash
thx! didn't realize you had a wagon. which tank are you using? any way you can take a few more pics of the tank area?
Old 10-22-2006, 06:20 PM   #24
dibblejr
Member#: 94070
05 LGT
You got them;
Full engine view
Pic of tank and pump
Pump mounted upside down
Another shot of pump
Pic of 2 qt tank, shows accessability
showing how I bolted tank to heat shield
Better shot of tank mount
Note in order to fit the 2 qt tank in this manner I had to cut off the left side tabs and make it as flush as possible.
I monitor the alky temperature with my greddy water temp gauge, temp stays at 100 deg f, well below the flash point of 50/50 water alky.
If you need more info just ask.
Jay-R
Old 10-22-2006, 06:30 PM   #25
Bishop
Member#: 59993
Ass, grass or cash
thx bro! ton of help. i'll pm you if i have any further questions.
Post pics of your gauges setup vapore0n Interior & Exterior Modification 3445 05-20-2016 09:45 AM
setting up a third monitor? post pics of your setup (PC) stArs Inked Off-Topic 26 01-21-2009 01:45 PM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post Pics of your Turbo timer setup TanXP Interior & Exterior Modification 23 03-19-2003 05:56 PM
