Old 10-09-2006, 02:20 PM   #1
STiGuy46554
Member#: 120132
Default Will 02-03 Struts Fit My 04 STi
Like it says.
I'm trying to find a way to put some KYB AGX's on my 04 STi. I was told there is a "washer" method, but I have yet to find out the specs I need. Any help would be great.
Thanks,
Cody
STiGuy46554 is offline   Reply With Quote
Old 10-09-2006, 04:59 PM   #2
subywrx
Member#: 81858
You will need 2-3 washes to space the top hats up (rears only). Do not get the thin washes, get heavy duty ones (around 1/4" spacer is need).
subywrx is offline   Reply With Quote
Old 10-09-2006, 09:43 PM   #3
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2.75 mm washer thickness is the correct amount.
mw
RaceComp Engineering is offline   Reply With Quote
Old 10-10-2006, 10:22 AM   #4
STiGuy46554
Member#: 120132
Okay. Thanks.
But my next question is:
Since I can put 02-03 sturts on, can I use 02-03 springs? Or do I need new tophats?
Thanks,
Cody
Old 10-10-2006, 10:56 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
You would need 02/03 rear tophats to use 02/03 springs (fronts are identical) and you would NOT need the washers as it would all be kosher 02/03
UkNuck is offline   Reply With Quote
Old 10-10-2006, 11:24 AM   #6
STiGuy46554
Member#: 120132
So what you are saying is:
Front:
02-03 Springs
02-03 Struts
04-05 Tophats (can I use 02-03?)
Rear:
02-03 Springs
02-03 Struts (spacers not needed)
02-03 Tophats
Is that right?
Thanks,
Cody
Old 10-10-2006, 11:41 AM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
See below
Front:
02-03 Springs YES
02-03 Struts YES
04-05 Tophats (can I use 02-03?) YES & YES
Rear:
02-03 Springs YES
02-03 Struts (spacers not needed) YES
02-03 Tophats YES. The only gotcha is that the 02/03 style hats use a separate rubber ring (I suppose technically it's an upper perch) which IIRC is not supplied with the tophat - see Arnie's pic here - you may need to buy that separately.
Is that right?
Thanks,
Cody
Old 10-10-2006, 01:50 PM   #8
STiGuy46554
Member#: 120132
But I'm not sure what to look at or what part to get.
Old 10-10-2006, 01:59 PM   #9
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The castellated rubber bit...
Old 10-10-2006, 02:10 PM   #10
STiGuy46554
Member#: 120132
So that's the only part that's not with a kit, that I need to buy?
Thanks,
Cody
will a stock 02 WRX Dowpipe fit my 04 STi ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-30-2009 07:03 AM
Will 03 WRX takeoff struts fit an 04 STi? MarcsRX Brakes, Steering & Suspension 14 08-05-2005 12:43 PM
Will 02-03 brakes fit a 04 WRX Blue_dragon Brakes, Steering & Suspension 5 02-21-2005 01:21 PM
Will 02-03 koni's fit a 04? already searched- neuspeed Brakes, Steering & Suspension 6 11-22-2004 07:02 PM
URGENT URGENT: Will 02 Wagon Struts fit 04 Sedan? caterpill Brakes, Steering & Suspension 10 09-17-2004 02:32 AM
