Old 10-09-2006, 03:20 PM   #1
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
Question 2007 DRL disable different than 2006??
This thread seems very simple http://www.iwsti.com/forums/showthre...ht=disable+drl
But the yellow 10 pin connector does not seem to be there on my 07.
I need to confirm that the relay has moved so I don't feel like I can't follow simple directions.
Scaed is offline   Reply With Quote
Old 10-10-2006, 06:59 PM   #2
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
bump for some 07 help?
Old 10-11-2006, 12:14 AM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I can't access the thread since I'm not a member. Is it for an '06? If not, then you may want to check this thread:
http://forums.nasioc.com/forums/showthread.php?t=914064
Hank3 is offline   Reply With Quote
Old 10-11-2006, 12:41 AM   #4
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
thanks-- the iwsti thread is essentially the same that you posted, sorry about the access limitations. The yellow 10 pin that's pointed to in the nasioc thread isn't in the same place on the 07, AFAIK. Why move the thing?
The only other yellow connector is next to the airbag, so I figured I wouldn't pull it until I get some confirmation. I know that someone on the board has already bought the service manual for the 07, just wanting to confirm that it has moved and where??? Or if it changed color, etc, etc.
Old 10-11-2006, 01:15 AM   #5
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Just take a look at those modules under the dash, the correct one will clearly say "DRL" on it. Even if it is moved to a different spot for '07, you can't go wrong with looking for the letters DRL on the plug.
semaj is offline   Reply With Quote
Old 10-15-2006, 10:38 AM   #6
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
Any better guidance? Does the e-brake wire feed to the correct module?
Old 10-15-2006, 02:06 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
um, unless its changed, but doesnt the STI not have DRL? since its HID?
Shane
PARANOID56 is offline   Reply With Quote
Old 10-15-2006, 03:23 PM   #8
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
Very astute! I should rephrase my question: how do I turn off the headlights during the day?? They are HID's and are on, but they do not have the lights that were on my 02 WRX that were DRL's.
I assumed that a relay controlled them and it would be called a DRL relay.
Old 10-23-2006, 01:52 AM   #9
15secWRX
Member#: 52088
07 limited
URBAN GRAY
any updates?
15secWRX is offline   Reply With Quote
Old 10-24-2006, 09:19 AM   #10
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
yeah, I started a thread in exterior mods because it gets more views. Try here:
http://forums.nasioc.com/forums/show....php?t=1119031
Old 11-01-2006, 08:56 PM   #11
tealdub
Member#: 87598
09 spec.B
burton custom 167
Talking Finally done...
Please check this link:
http://www.iwsti.com/forums/showthread.php?t=64791
The important step is the last one on the second page. Although this person had cut the wires, I simply used a pinout tool and removed the green/yellow wire so if for some reason I wanted the DRL's back I would just plug them back in. Remove the glovebox. The diode is attached to the wires on back on the glovebox, about 8" up, and the relay is over where it was on the '06 model, next to the I/C box. The relay is the one with the black clip, NOT the blue. It is a 5 pin connector. Simply use a small screwdriver to unattach it from the relay, seperate the white inner plastic cover and use your "pinout tool" btw the connector and the black housing and it should slide right out. Reverse instructions and put it back together. Once that is done, disconnect the small black diode from its white three wire housing and remove it. Take the same tool, or something small and strong, and pry up on the white plastic strip above the green/yellow wire and again it should slide right out. Take a minute to attach the now exposed wire to the existing harness, I just used about 2" of electrical tape on both ends. Now test your lights and make sure EVERYTHING works. Reinstall the glovebox. Done. Total time for me was around 25 mins. I take no responsiblity for this mod. but by all indications this is completely safe.
tealdub is offline   Reply With Quote
Old 11-04-2006, 04:23 PM   #12
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
using a pinout tool is the ticket. It was easy on relay (black one next to the blue one near passenger right knee), but I ended up having to cut GY wire from diode.
Works as advertised.
Old 11-16-2006, 11:25 AM   #13
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
Ok all you STI guys, can you help out a wrx owner?
The wiring is diffrent for a car that doesn't have HIDs. there is no Green/Yellow wire running into that black relay.
i'm fairly certian that said relay is still the OR relay that controls the DRLs, but the all the descriptions just list the wire color, which isn't the same on the WRX.
My question? what PIN on that relay did you remove?
i have a few images we took from my friend's brand new 07 yesterday illustrating no GY wire.
http://i14.photobucket.com/albums/a3.../PICT0023s.jpg
http://i14.photobucket.com/albums/a3.../PICT0024s.jpg
The wires avaialable are:
Yellow/Red x2
Green/Red
Green Black
shane86 is offline   Reply With Quote
Old 11-17-2006, 01:35 PM   #14
shane86
Member#: 67387
04 WRX - STX
24hrs later bump.... i'd just like to know which pin the GY wire goes to on that relay!
Old 12-01-2006, 06:59 PM   #15
garretts77
Member#: 131498
2007 WRX Sedan
Satin White Pearl
Shane, any luck with this? I have been reading this thread for a couple of weeks... Any new news?
garretts77 is offline   Reply With Quote
Old 12-14-2006, 04:53 PM   #16
Cautiontext
Member#: 74848
07 BMW 335Xi
I thought there was a stickyed how to do this for the 07 sti. Does anyone have a link?
Cautiontext is offline   Reply With Quote
Old 12-14-2006, 05:01 PM   #17
tillithz@
Member#: 84382
2006 STI
Crystal Gray Metallic
that looks like a common relay shane, without testing I would guess the wire he indicated by color in earlier posts.
tillithz@ is offline   Reply With Quote
Old 01-05-2007, 03:17 PM   #18
Shibbs
Member#: 131725
2007 Impreza WRX
Obsidian Black Pearl
STILL no progress on the 07 WRX that DOESN'T have HID? Wow. I must be the only one that cares about my DRLs....
Shibbs is offline   Reply With Quote
Old 01-06-2007, 12:24 AM   #19
garretts77
Member#: 131498
2007 WRX Sedan
Satin White Pearl
Absolutely not. But I personally don't know how to do it either, and am also waiting for someone to give it up...
Old 01-07-2007, 02:13 AM   #20
june.rs
Member#: 136412
Chapter/Region: HIIC
07 WRX
PEARL WHITE
Default drl gone
bye bye drl. i took my drl is gone
june.rs is offline   Reply With Quote
Old 01-07-2007, 12:55 PM   #21
ETacv
Member#: 134010
2007 WRX bren-t00ned
UGM
Nice... would you like to share how?
ETacv is offline   Reply With Quote
Old 01-08-2007, 03:21 PM   #22
june.rs
Member#: 136412
07 WRX
PEARL WHITE
I Ground The E Brake Wire And Took The E Brake Light Out Of The Cluster. It Took Me About 10min. No Cutting Involved. I Shoved Eyes In The E Brake Wire Than Connect With A Small Wire And Bolt It On Some Nut That Was In There.
Old 01-13-2007, 02:04 AM   #23
SilvrWRX
Member#: 8582
2007 Impreza WRX
Satin White Pearl
I did a little research and found this thread http://www.iwsti.com/forums/showthread.php?t=73434.
It's directions for the STI, but what's interesting to me is the Diode B95 description in the bulkhead wiring harness table. For the STI, it's listed as a 3 pole connector. The STI DRLs were disabled by pulling the green-red (GR) wire. The problem is I don't have the wiring system diagram for the WRX, but the WRX (listed as "except for STI model" on the table) equivalent of the same diode B95 has only 2 pins. So, I figure we have a 50% chance of achieving the same result. I think the worst that can happen is that the lights would stop working if the wrong choice was made. At which point, we would know that it is the other wire. Has anyone tried this yet? Or better yet, does anyone have the wiring system diagram for 2007 non-hid impreza models (should work for both RS and WRX models)?
We'll still have to disconnect a wire from B280 to remove the City Lights DRL. It should be the same as the STI. The table says it's a blue connector, but the iwSTI thread confuses me because it looks like it shows a wire removed from a black connector instead. Here's the diagram to help locate the connectors in the dash.
What does everyone think?
SilvrWRX is offline   Reply With Quote
Old 01-13-2007, 06:18 PM   #24
ETacv
Member#: 134010
UGM
Hm. I think that there's a good chance of that working. If I had some more time it'd try to fiddle with it but school just started again so yea... If you wanted to try it out you could try to use a pinout tool to take out one of the wires and see if it works. Maybe the one where the GY colored one for the STi should be but i'm not too sure.
You can get the service manuals from techinfo.subaru.com or you could go to your dealer and ask them to print out what you're looking for.
Old 01-15-2007, 08:12 PM   #25
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
What happens if one simply unplugs B102?
Captain Ned is offline   Reply With Quote
2007 DRL disable different than 2006? Scaed Interior & Exterior Modification 161 02-04-2015 10:38 AM
2007 2.5i DRL disable? cowboysuby Electrical & Lighting 23 03-22-2008 12:51 AM
2007 WRX DRL Disable JoeSUBARU Electrical & Lighting 5 11-18-2007 04:42 PM
2007 DRL disable munkis Legacy Forum 0 03-31-2007 07:37 PM
2007 DRL Disable john_tran Interior & Exterior Modification 2 02-03-2007 10:13 PM
