Old 10-09-2006, 10:34 PM   #1
justinpool2000
Member#: 85834
Default Nozzle Location...? (TMIC)
I have read/searched but have not been able to find any quality pictures/descriptions of nozzle locations when using stock TMIC (wrx/sti) The only pic i found was tapping the TMIC hose which didnt look very strong.
any links or pictures of working setups on tmic would be great thanks
justinpool2000 is offline   Reply With Quote
Old 10-09-2006, 11:22 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Users have also tapped into the bottem of the end tank near the outlet or in the long front side of the end tank between the BOV flange and the inlet to place their spray nozzles.
The hose mounted fittings seem to work if done carefully so nothing can come loose and drop into the throttle body.
There were a couple writeups with info on nozzle mounting but it will take a bit of searching to find them.
One of the better writeups done on WI/ alky injection for the Subaru is http://www.wrxhackers.com/alchystuff
Larry
hotrod is offline   Reply With Quote
Old 10-10-2006, 11:40 AM   #3
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
i put mine right at the tb opening.
DISCOPOPE is offline   Reply With Quote
Old 10-10-2006, 11:40 AM   #4
DISCOPOPE
Member#: 43339
2oo4 STi
Old 10-10-2006, 04:28 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Mine is in the same spot. Some people like to put a second injector before the intercooler, and some people put their injector before the turbo, The one shown above seems to work well for most people though, and it's relatively easy to do while being inconspicuous.
peace
Old 10-10-2006, 05:24 PM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
The above is also pretty close to the same spot used in the Hydramist instructions...
http://www.elementtuning.com/Hydrami...ationguide.htm
offset
offset is offline   Reply With Quote
Old 10-10-2006, 06:28 PM   #7
dibblejr
Member#: 94070
73 DL Race Car
WRB/ Yellow SUby Logo
I did a writeup on the Ebay TMIC you can place in the stock OEM TMIC also. If you do a search under my UN you will find my post on the size of the hole. It threaded itself, didnt need a tap.
Jay-R
dibblejr is offline   Reply With Quote
Old 10-10-2006, 06:32 PM   #8
dibblejr
Member#: 94070
73 DL Race Car
Old 10-11-2006, 07:11 AM   #9
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
my setup
testes1010 is offline   Reply With Quote
Old 10-12-2006, 06:17 PM   #10
justinpool2000
Member#: 85834
You all rock... Thank you very much for all the picks and links to installs. Wasnt very sure but now i've got a lot of good ideas. thanks again.
How critical is tank nozzle location to the G-force? Hyper Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-06-2009 11:48 AM
Stock I/C spray nozzle location? Screwbal Factory 2.5L Turbo Powertrain 6 02-14-2009 05:06 PM
Meth kit install: I have some trouble with nozzle location... rpeirats Water/Methanol Injection, Nitrous & Intercooler Cooling 7 12-03-2008 09:28 AM
Water Injection Nozzle location WhiteKnight Water/Methanol Injection, Nitrous & Intercooler Cooling 23 11-16-2005 02:16 PM
STi intercooler spray nozzle location? Killian Maynard General Community 7 04-03-2005 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 04:09 AM.
