Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 11-06-2001, 02:02 PM   #1
BluJay
Member#: 5506
WR Blue
Default CEL code: 0340 / Camshaft position sensor
I did a search and found that some have gotten this code before.
I got one recently and was wondering what the conventional wisdom is on possible causes. The CEL went on during an engine overrev situation that resulted from a 5 to 4 downshift that mistekenly ended up in 2nd at about 90-100 mph. Ouch.
But there doesn't seem to be any permanent damage, and others have gotten the same code from just regular everyday driving.
Is this code something that might be thrown just because of extremely high revs? Is it caused by something else entirely?
Any help would be appreciated.
Jay
BluJay is offline   Reply With Quote
Old 11-06-2001, 02:04 PM   #2
trakker
Member#: 4527
2002 TurboXS Stage2
G- Tech - 13.12 @ 106.6
That's one of the ones I had and it would go and go off at various intervals. Subaru Canada took the car for a few hours and ended up replacing the whole ECU.
I've never had the light since.
Rick..
trakker is offline   Reply With Quote
Old 11-06-2001, 02:13 PM   #3
BluJay
Member#: 5506
WR Blue
So they had no idea what was causing it basically?
I guess I'll wait and see if I ever get another one before worrying about it.
What I'd really like to know is the answer to this question:
Would extreme overreving, such as in the 8k-9k rpm range, cause this CEL?
J
Old 11-06-2001, 02:15 PM   #4
trakker
Member#: 4527
2002 TurboXS Stage2
I don't know, but my light never came on while I was driving hard. It was at stupid times like sitting at a light, or driving slowly in my underground parking. Once, it came on while cruising on the highway.
Rick..
Old 11-06-2001, 02:28 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Jon [in CT] is offline   Reply With Quote
Old 11-06-2001, 04:30 PM   #6
BluJay
Member#: 5506
WR Blue
Thanks for that link, Jon.
Funny thing is, when we pulled the 0340, we also got a 1443.
I recall that the CEL has gone on and off about 5 times already, and I assumed that I had the one 0340 from the overrev, and that the other incidents were 1443s.
Mulder helped me get the codes with his autoxray code scanner, and we coudn't get any additional information, such as number of codes, snapshot info for the 0340, so it's really anyone's guess what code came from where.
I realize from reading your post that I could be totally wrong about my assumptions.
In any event, I think we should take this discussion to that other post, as linked above, and again here:
http://www.i-club.com/forums/showthr...hreadid=110622
It has a lot more information on the topic.
JYH
Old 11-06-2001, 04:55 PM   #7
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
i always get that code when i go over 6500 rpms running full boost.my fiends at subaru tell me that the cam sensor cannot
keep up with the speed of the camshaft?if i keep under that rpm the check engine light does not come on
dave
mspt
PerformanceAutoSolutions is offline   Reply With Quote
Old 11-06-2001, 05:07 PM   #8
GGB
Member#: 8792
Question possible reason?
I guess it is certainly possible that the CAM sensor can not keep up with the CAM shaft. I do know that many sensor do have a limit in sampling rate, so if the cam is rotating above the upper limit, then it might produce a voltage/code that the ECU can not understand. It also could be possible that the ECU is programed in a way that will give out CEL when a over-rev situation was picked up too.
GGB is offline   Reply With Quote
Camshaft Position Sensor Issue (Car won't start) Hola Service & Maintenance 2 02-06-2005 12:12 AM
Camshaft position sensor shaneswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2004 04:39 AM
Camshaft position sensor dead AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 05:30 AM
Camshaft Position Sensor ehabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2003 03:06 PM
Camshaft Position Sensor zsurfrin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2002 10:00 PM
