Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 03-29-2007, 01:51 PM   #101
Phil Jr.
Member#: 62221
Originally Posted by SloRice View Post
^^The outlet going into the uppipe is 2", not sure about the individual runners. I guess I could measure those too.
the flange going to the uppipe on mine is 2" but the runners going up to the flange are a bit larger so you kind of have a small lip there Not a huge deal cuz it could be smoothed up pretty easy.
Phil Jr. is offline   Reply With Quote
Old 10-03-2007, 05:27 AM   #102
MSR
Member#: 20842
05 Spec C Type RA
Did we get a pipe size od and ID on the perrin headers?
MSR is offline   Reply With Quote
Old 10-03-2007, 05:59 AM   #103
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Back from the dead....
SilverSurfer04STi is offline   Reply With Quote
Old 10-03-2007, 09:24 AM   #104
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
The 4 runners coming off each exhaust port are a little smaller...I'd say 1.75" to 1.5" But I did not measure them.....just guaging with my recently calibrated eye.
SloRice is offline   Reply With Quote
Old 10-03-2007, 10:09 AM   #105
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
Lasec eh ?
IllNastyImpreza is offline   Reply With Quote
Old 10-03-2007, 04:17 PM   #106
MSR
Member#: 20842
05 Spec C Type RA
I was hoping for some measuremnts, I would say looking at pics they are 1.5" primeries and maybe 1, 5/8th seconderies, but GT spec use 1, 11/16 secondaires on there twin scroll headers.
Old 03-11-2008, 12:48 AM   #107
LittleBlueGT
Member#: 96204
2013 STI GR
Anybody else do any tests recently with EL headers?
Clark?
LittleBlueGT is offline   Reply With Quote
Old 03-11-2008, 01:01 AM   #108
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I did one on an FP green STI. Turbo came on 600 to 800 RPM faster and as a result made 40 ft lbs of trq and 25whp under 4000 rpm. From 4500 to 6000 rpm power was exactly the same and from 6000 + it lost 8whp.
Clark
AZScoobie is offline   Reply With Quote
Old 03-11-2008, 01:53 AM   #109
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Clark,
this is compared to a stock header? if so, surprised that it lost power up top.
whats your opinion overall of the perrin header on an FP Green or similar?
Wrinkleboi is offline   Reply With Quote
Old 03-11-2008, 11:08 AM   #110
dmross
Member#: 2818
2000 2.5RS
Clark
Was this with or without tuning?
dmross is offline   Reply With Quote
Old 03-15-2008, 03:16 PM   #111
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Stock header FTW. As Full-Race had explained before EL header's don't matter It's the Pressure drop in the header so if you have a header with larger runners the pressure drop will be more unless you have a large turbo to pressurize that system. correct me if I'm wrong.
spoolinsti05 is offline   Reply With Quote
Old 03-15-2008, 04:03 PM   #112
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
strange how full race is the only company out there that says runner length is less relevant than pressure drop.
strange how when questioned about the established body of research that points to runner length being important in order to align pulses, full race avoids giving an answer.
strange how a year later everyone is still waiting for the magic numbers that have been promised from such a proprietary full race setup.
Old 03-15-2008, 06:47 PM   #113
MattPersman
Member#: 139385
where are all the super 2000 rpm spooling 600 whp full race kitted cars at? maybe they can post the graphs
MattPersman is offline   Reply With Quote
Old 03-16-2008, 04:51 AM   #114
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
This was the same with and without tuning. The difference was the fact that the equal length system choke flowed much faster then the 4 to 1 system. Its a balancing act. A setup like mine need big tube equal length headers.
C
Old 03-16-2008, 04:54 AM   #115
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Originally Posted by Wrinkleboi View Post
Clark,
THe Perrin EL header kicks ass. It makes more power over the curve up to the top end. For a street car and or a road race car the EL is the way to go. But what I am finding is that perrin needs to make a big tube version that will support the gas flow that big turbo setups need.
C
Old 03-16-2008, 08:46 AM   #116
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I think the comparison would have been closer if the stock manifolds were ported and wrapped.
2gnt2wrx is offline   Reply With Quote
Old 03-16-2008, 09:58 AM   #117
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah, that isn't right...a larger turbo will take longer to reach the same pressure...but its compressor side has the same story. The turbo has a pressure ratio and in the great majority of turbo's you always have higher exhaust pressure than intake manifold pressure. The pressure "drop" is a horrible way to put it on their behalf. What I think he's refferring to is a stepped runner. This makes for a lower pressure (higher velocity) tube right outside of the head and then is opens to a larger diameter higher pressure (lower velocity) tube. This helps to combat reversion. EQ and the tuning lenght does make an effect on the shift of the torque curve, be it a higher or lower targeted RPM.
Old 03-16-2008, 10:00 AM   #118
Homemade WRX
Member#: 33782
96 bastard child
C
it choke flowed?!!! or you started having to great of flow losses related to RPM?...big difference.
I.E. if you are flow benching heads, you will see the air flow taper and can stall out. This isn't choke but a flow problem. Choke is a pressure problem that then stops flowing beyond a certain volume of air. When you hit choke, everything falls off the face of the earth.
Also, being as a turbo is a compounding system based up when it starts to spool; I'd imagine this choking that you had to be from the small hot side trying to handle a great airflow. That and that is was probably at a decreasing efficiency on the compressor side.
Old 03-16-2008, 12:54 PM   #119
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
1,000,000% correct!!
Old 03-16-2008, 01:06 PM   #120
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
I WANT TO SEE....
a PERRIN EL VS GRUPPE-S EL header comparisson!!
the gruppe-s is just like the perrin only the runners are a larger diameter!!
All4bSpinnin is offline   Reply With Quote
Old 03-16-2008, 02:01 PM   #121
Homemade WRX
Member#: 33782
96 bastard child
really?!! they have the same stepped ID and lengths? same primarie ID and legnth too? Same degrees of bend?
They ALL effect how a manifold performs.
Old 03-16-2008, 11:29 PM   #122
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
from what i understand the stepped id is larger as well as the primary... length is equal... dont know exact specs... but from what ive learned, the runners are larger... get them together and snap a pic
Old 03-17-2008, 09:58 AM   #123
Homemade WRX
Member#: 33782
96 bastard child
sounds good.
Old 03-17-2008, 02:12 PM   #124
wrxhard
Member#: 108091
reguardless of all differences, they may just flat out perform better...
wrxhard is offline   Reply With Quote
Old 03-18-2008, 12:03 PM   #125
EMS
Member#: 14116
If the outlet into the uppipe is 2" (51 mm) it's actually bigger than the 41 mm diameter of the Perrin uppipe! (for stock mount turbo) Or does Perrin have a different uppipe for their header??? I assume the Perrin rotated uppipe has a bigger i.d.
Mark.
EMS is offline   Reply With Quote
headers vs stock ScooobaSeth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-31-2008 09:24 AM
RS header vs. WRX header... projectrally Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-18-2005 01:05 PM
aftermarket header vs stock header height rubyred Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-13-2005 02:11 AM
Exhaust sound clips...header VS. non header Dynamispeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-27-2004 09:26 PM
borla headers vs. stock garretwp Normally Aspirated Powertrain 2 08-24-2003 06:56 PM
