10-10-2006, 10:08 PM | #1 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
Hydra- Fuel pump wont turn off when hydra is powered up...whats the cause?
Anyone know?
thanks alex PS it only started doing this once I downloaded my map to it
10-11-2006, 05:09 PM | #2 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Sounds like you downloaded the wrong map or the template.s20 file. If this is an Element Tuning Hydra you can email me with your serial number and I can send you the original file for your unit which will restore the correct settings.
Thanks, Phil www.elementtuning.com |
10-11-2006, 08:12 PM | #3 |
Member#: 39936
It isnt the element tuning version...
10-11-2006, 09:50 PM | #4 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
you likely just have your outputs incorrect, you need to go through your settings, its likely you have your fuel pump hooked up to injector or something, you can send me your map and maybe I can figure it out, or if Phil will help obviously his help is way better
Ben |
10-11-2006, 11:26 PM | #5 |
Member#: 39936
phil...love me
im a broke-ass college student i work at a car wash come on here |
10-11-2006, 11:41 PM | #6 |
Member#: 54918
Sorry I have to reserve my limited time to our customers but you could contact your dealer and hopefully they have the original map so you can restore the correct settings. It's likely you have downloaded the template.s20 file and the entire map is now garbage. If not they may be able to provide you with a new map and your pass code so you can restore the settings but this process is a bit complex. I store all my customers orginal base maps just in case something like this happens then all I need from them is the serial number so I can email them the map that is encrypted specifically for their unit. You'll be fine you just need to get the original map.
10-12-2006, 12:09 AM | #7 |
Member#: 39936
my Dealer?
I had Andrew flash it a few months ago, but besides that, its like a 3rd hand-me-down unit (im the 3rd person to own it) |
10-12-2006, 01:15 PM | #8 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
A broke-ass college student... with a 35R'd and Hydra'd RS.
I'm playing the world's smallest violin for you |
10-12-2006, 03:09 PM | #9 |
Member#: 39936
Lol
10-17-2006, 09:06 PM | #10 |
Member#: 93776
Vehicle:2002 Impreza WRX Silver |
My fuel pump did this to me a few times.. It was a corrupted map, my outputs got all messed up... Don't you have a back up saved that you can download?
car turns off when maf is connected? | Jons_uurx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 05-02-2009 06:07 PM |
HIDs wont turn off unless handbreak is engaged | seps_wrx | Electrical & Lighting | 16 | 08-26-2008 02:25 PM |
JDM headlights will not turn off when car is on | druxboyz | Electrical & Lighting | 4 | 01-13-2006 08:39 PM |
fuel pump wont turn on after motor install. | oldbluwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 07-15-2005 11:01 AM |
Deck not turning off when car is off | Sparticus | Car Audio, Video & Security | 18 | 02-15-2002 01:53 AM |
