Old 10-11-2006, 10:25 AM   #1
TurboSteve
Member#: 26631
2003 WRX
WRB Pearl
Default High-Mileage Questions
Hey all,
I was wondering how many WRXs there are with over 100,000 miles?
Also, has anything failed or needed to be replaced yet on your rides?
I believe the recommended interval for timing belt changes is 120,000. Anyone bother to change it before that?
I've got a 2003 WRX with 102,000 miles on it. Fifth gear got really bad around 58,000 miles and was fixed under warranty. First was starting to go bad at the same time but since the dealer couldn't "recreate" the problem, they didn't bother to fix that so it still grinds every now and then when you go to put it into first.
I replaced the tires and front brakes at 60,000 and the rear's at around 80K. The alternator checked out at around 95K and i think i have a bad rear wheel bearing that is intermittenly grinding so its hard to track it down.
My wife and i recently started autocrossing it and have quite a bit of fun. i'm thinking i may plan for the timing belt a little sooner than scheduled because of this.
Steve
TurboSteve is offline   Reply With Quote
Old 10-11-2006, 10:32 AM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
i think there are quite a few running around with over 100k.
HonduHunter is offline   Reply With Quote
Old 10-11-2006, 10:54 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
wrx timing belt is 105 IIRC. you may want that done asap as I believe it is an interference engine. (if the belt breaks, goodbye valves and piston)
Old 10-11-2006, 11:22 AM   #4
bWRX
Member#: 6672
I have 136k on mine. I developed some leaks and had to take it to a mechanic to get those fixed which was about $2500. Timing and AC belt tensioners replaced, cam covers, numerous hoses and clamps. The head gasket may be showing signs of squirting at this point, but hasn't gone yet. Have never done any exhause or engine mods and I'm pretty sure I wouldn't want to on this engine.
The clutch needs to be replaced, but that could have gone much sooner if I'd driven her harder. Tranny is quite strong.
I replaced the struts at 128k miles but I doubt they have any problems. One of the AGXs I installed has recently died on me. Quite a PITA.
The steering rack bushings got all kinds of rotten and spongy at about 110k miles, and it took me awhile to get around to fixing those. Installed Prodrives, awesome so far.
Car has acquired a patina of sratches, nicks, and microdents over the five and a half years I've driven it. I've gone through one windsheld, and I might need another before inspection time next year.
I've had ECU/sensor/electrical issues since the second year I owned it: plenty of engine misfire codes, had the ECU reflahed, and even replaced under waranty, Clutch stutter too.
Overall, not terrible, but I thnk I am more inclined to get a new STI next year than do anything like an engine swap on this one. It served me very well, but it is old and tired and needs a rest, or to be sold for a bargain price to someone who will turn it into a racecar.
bWRX is offline   Reply With Quote
Old 10-12-2006, 03:42 PM   #5
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Ouch!
I had 78k on mine and it still looked and drove brand new. If you maintain your cars well they will last. if not... As to the first gear grinding, a dealer repair has a warranty. Go back.
bofh is offline   Reply With Quote
Old 10-12-2006, 03:47 PM   #6
bWRX
Member#: 6672
Originally Posted by bofh View Post
Ouch!
Now the fine point I have to make is...maintaining your car well comes at a certain cost, Maintaining my car just cost me $2500 to replace a bunch of seals and hoses. The cost depends on the quality of materials used in the parts, and the quality of the engineering of the car. My experience tells me that Subaru uses materials which are not as high quality as Honda, though their engineering is quite brilliant.
Old 10-12-2006, 04:18 PM   #7
grzydj
Member#: 84984
2006 Impreza 2.5i 5D
'04 Toyota Tacoma TRD
Subaru has to cut costs in places where Honda doesn't have to, mostly because they don't have the buying power that Honda does for parts, and Honda has more efficient and quicker build times.
If you can make a car quicker, then there's less labor involved in the final price of the car, which equates to higher profit margins. Subaru is already in works with Toyota to streamline their production. I'm sure they'll get some buying power from Toyota as well.
grzydj is offline   Reply With Quote
Old 10-13-2006, 11:20 AM   #8
TurboSteve
Member#: 26631
2003 WRX
WRB Pearl
I too replaced a windshield already. I guess i forgot about that, but it seemed as though it cracked on its own with help from cold weather. My wife drove the wheels off it while we lived in New Jersey, but i've done well to maintain it and even with over 100K on it, it still rides and drives like new. Interior is excellent as well and i really doubted weather or not the hair-magnet cloth interior would hold up.
I didn't know about the reapir warranty thing. I look into that. Problem is its still intermitten.
Old 10-13-2006, 11:48 AM   #9
dvang
Member#: 84188
05 legacy
caravan full of kids now
0 problems except for the paint sucks and it dings/scratches easily
dvang is offline   Reply With Quote
Old 10-13-2006, 11:56 AM   #10
Type1
Member#: 19412
2002 Rex
Bling Bling silver
Just shy of 90k and I rally it all the time.
Other than the expected blown shocks and such no real problems at all.
Im pretty sure My turbo may be failing as I am mysteriously loosing coolant with no leak signs but my motor is NOT stock so overall its a good car that holds mods pretty well.
I left out all the other wear and tear items such as breaks, etc...cause thats expected. Oh and im still on the stock clutch and gears are fine and dandy even with all those lauches and shoving it into lower gears on the fast passes!!!
Type1 is offline   Reply With Quote
Old 10-13-2006, 01:35 PM   #11
jomotopia
Member#: 116303
2004 STi
No, Subarus do not have interference engines: http://www.mr2.com/TEXT/TimingChain.txt
and according to that list the recommended interval is 60k
jomotopia is offline   Reply With Quote
Old 10-13-2006, 01:50 PM   #12
2$SPIFF
Member#: 78437
2002 WRXWag 16.5 PSI
Rally Blue
approaching 75k miles ... everything seems to be running fine
2$SPIFF is offline   Reply With Quote
Old 10-13-2006, 02:06 PM   #13
Aborted Cat Fetus
Member#: 128180
2004 wrx
96k here on mine...i have what seems to be an air leak on my bottom end. everytime i hit boost i hear a weird noise... also there was some carbon build up on the botom
Aborted Cat Fetus is offline   Reply With Quote
Old 10-13-2006, 02:25 PM   #14
rkramer
Member#: 118209
2015 WRX Limitec
correct, for 1994... (actually svx's from before that were interference also, so it isn't correct for that)
from a quick search here, modern suby engines ARE interference engines... timing belt breaking = great time for a shortblock... makes sense if you read the directions for changing the belt, it specifies a particular way to turn the cam gears to prevent the valves from hitting.
http://forums.nasioc.com/forums/show...t+interference
Old 10-13-2006, 02:35 PM   #15
jomotopia
Member#: 116303
2004 STi
damn.. i stand corrected... good to know
Old 10-13-2006, 05:16 PM   #16
quickgtp
Member#: 14891
2002 WRX wagon
286 AWHP craptastic CA 91
My car is just at 100K. I haven't had anything go bad except some squeeking belts I have however replaced most parts before it was needed i.e. timing belt at 56,000, both front wheel bearings when I did new breaks, tranny at 94,000 still had original clutch, battery. I couldn't be happier with the car and how it has lasted. I did a leak down at 86,000 miles car was modified since 8,000 miles Vishnu stage zero then one. Engine was between 6%-9% hot and cold pretty freakin impressive I thought. Car has had synthetics since 6,000 miles tranny and engine.
quickgtp is offline   Reply With Quote
Old 10-13-2006, 05:19 PM   #17
mtm584
Member#: 90765
90K on my02 the only problems i have had were transmission related. The engine looks brand new and the car drives like new.
mtm584 is offline   Reply With Quote
Old 10-13-2006, 05:36 PM   #18
UA_WRX
Member#: 88986
My '02 is at 127k no major issues other than the 6 month time span my mom drove it and went through 2 clutches. Basic maintenance is all its needed except for the cyl 4 misfire code I'm getting right now. Did the timing belt at 119k just before I could have any issues. Still on original struts but they are definately ready to be replaced. Great car and even with the HKS exhaust its still good on road trips.
UA_WRX is offline   Reply With Quote
Old 10-13-2006, 05:50 PM   #19
quickgtp
Member#: 14891
2002 WRX wagon
Yeah second windsheild for me too
Old 10-13-2006, 06:15 PM   #20
Ryan314
Member#: 82989
Hybrid EJ257
Wow, 102k miles on an '03... that's a lot of driving!!
Anyways, I've got 77k on my '02.... no problems!
Ryan314 is offline   Reply With Quote
Old 10-13-2006, 06:33 PM   #21
MrViggy
Member#: 54412
2002 Impreza WRX
WRC Blue
Wow. I've only got 45K on mine, and I already had to replace all four sets of brake pads (3 track days, countless autocrosses will do that!).
Viggy
PS. Yes, 45K. I bought the car, then took a job where I was working from home for a couple years. I think I averaged 1-2K per year the first couple of years I had the car.
MrViggy is offline   Reply With Quote
Old 10-14-2006, 03:31 PM   #22
Bandit1
Member#: 99464
87,000 on mine. Had a wheel bearing go out at 60,000 miles, replaced under the extended warranty. Just had to get the air conditioner fixed last week - some "expansion valve" or something like that. $640 for the fix/recharge/test. Other than that, no problems and only routine maintenance.
Bandit1 is offline   Reply With Quote
Old 10-15-2006, 04:34 PM   #23
pnoy_sti
Member#: 62748
04 STi HB tuned by
Jon 322/347 silverbullet
04 sti...99k....
pnoy_sti is offline   Reply With Quote
Old 10-15-2006, 08:42 PM   #24
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
My '02 had 134K miles on it when it was totalled. During that time it ate 2 windshields, 2 sets of struts, the steering rack (though I think, but couldn't prove, that it died when I hit a deer in Oct 2005), several sets of brake pads, 1 set of rotors, and tires. Lots of tires. I changed the timing belt at 110K miles.
The steering rack and timing belt change were the big money repairs as I did most all the rest by myself.
Captain Ned is offline   Reply With Quote
Old 10-15-2006, 08:47 PM   #25
CRL1084
Member#: 90351
2003 WRX
MBP
03 wrx, 82k miles, still running strong. Stock, only problem was the regular maintenance and at 59k miles i had one of my cylinders not working. dont know the word for it, but they added it with the 60k tune up.
CRL1084 is offline   Reply With Quote
High Mileage STI Question redzfit Newbies & FAQs 27 06-02-2009 01:38 AM
High mileage rebuild ej20 question mattswrxnc Built Motor Discussion 5 07-28-2008 09:53 PM
High mileage wrx question. xfactor58 Impreza Forum 3 06-24-2008 06:14 PM
Wrx High Mileage Question GRIP_SPEED Southern California Impreza Club Forum -- SCIC 25 04-13-2008 06:41 PM
PCV trends on high mileage engine question thng Service & Maintenance 0 08-12-2002 11:47 AM
