Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 11-06-2001, 08:50 PM   #1
Member#: 8935
2001 Impreza 2.5RS
Default Torque chip and S-AFC?
Hi all -- has anyone tried connecting a torque chip (I'm thinking of the one from JC sports, but it dosen't matter which one) and an S-AFC on the same car? If so, how did you do the MAP wiring?
Sensors -> S-AFC -> TCII -> ECU?
Sensors -> TCII -> S-AFC -> ECU?
Since the TCII modified both the MAP signals and the coolant temperature lines, would it be a bad thing to:
Connect TCII coolant IN to coolant sensor
Connect TCII coolant OUT to ECU
Connect SAFC map IN to MAP sensor
Connect SAFC map OUT to ECU
Connect TCII map IN to MAP sensor
Leave TCII map OUT floating..
Daveish is offline   Reply With Quote
Old 11-07-2001, 01:39 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I did it on my RS and had the torque chip between the ECU and S-AFC
You can leave the TCII MAP signals not connected, but the MAP sensor voltage clamp will not be in effect when you later boost the car.
ImprezaRS dot com is offline   Reply With Quote
FS: Pro ECM Torque Chip and JDM Clear Tails SSLegacyGT Legacy Forum 27 07-25-2003 03:22 AM
chip and s-afc Steve301 Normally Aspirated Powertrain 3 03-01-2002 04:54 PM
Torque Chip and Autocross... (Larry?) DanzBorin Normally Aspirated Powertrain 17 02-18-2002 06:30 PM
JCS torque chip or a S-AFC? Poppa smurf Normally Aspirated Powertrain 40 08-18-2001 02:17 AM
torque chip vs S-AFC only a suby Newbies & FAQs 8 08-02-2001 08:25 PM
