Old 10-12-2006, 12:38 AM   #1
weggy
Member#: 114897
2006 WRX
Default Knocks at idle.(06 WRX)
Hi everyone,
I bought my 06 wrx two weeks ago.
I've felt the occasional knock at idle. I put 93 gas on her.
Is this normal?
thanks
weggy is offline   Reply With Quote
Old 10-12-2006, 12:50 AM   #2
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
Could be the uneven headers...unless it sounds like metal popcorn then its not normal!! But a lil rumble here and there is no fuss
Wannascooby is offline   Reply With Quote
Old 10-12-2006, 09:23 AM   #3
DaKP00r
Member#: 113636
2007 Stg2 STI #277
06 YZ450F
Stand next to any other 06, same noise
DaKP00r is offline   Reply With Quote
Old 10-12-2006, 11:01 AM   #4
78damien
Member#: 128806
really? I just got a 06 WRX myself and have noticed the same thing. whats going on with the Subie to make it do that? I was scheduled to take mine into the dealership today and I guess I'll be cancelling that appointment. Thanks
78damien is offline   Reply With Quote
Old 10-12-2006, 11:06 AM   #5
russd32
Member#: 63961
It's a subie and they make funny noises even when they are running fine. Don't sweat it.
russd32 is offline   Reply With Quote
Old 10-12-2006, 12:30 PM   #6
njskatchmo
Member#: 94618
2002 Bugeye
the CEL would go off if it was knocking. Car feels mad shakey and should. now get the car moving, wrx's shouldn't be idled.
njskatchmo is offline   Reply With Quote
Old 10-12-2006, 12:45 PM   #7
Hayes
Member#: 11808
Subarus' don't make funny noises, just a different kind of noise. WRXs' shouldn't be idled?? I never heard that WRXs or any car short of a full race car should not be idled.
Hayes is offline   Reply With Quote
Old 10-12-2006, 12:46 PM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
How new are you to cars? Every vehicle I have ever driven has a slight shake at idle occasionally. Combustion isn't perfect, the ECU is constantly adjusting to keep the engine at the same rpms.
Old 10-12-2006, 12:47 PM   #9
Master2192
Member#: 83254
98 2.5 RS
04 WRX
He is just saying they are meant to be driven.
Old 10-12-2006, 12:47 PM   #10
njskatchmo
Member#: 94618
2002 Bugeye
i was joking, not technical, as in wrx's should be driven not idled. just a joke. but car sounds fine.
Old 10-12-2006, 12:49 PM   #11
Hazmat
Member#: 94803
I have my moments when I got my subie too, its all good mang
Hazmat is offline   Reply With Quote
Old 10-12-2006, 12:49 PM   #12
step down
Member#: 117433
2003 SVT Focus
this is always embarassing
step down is offline   Reply With Quote
Old 10-12-2006, 03:57 PM   #13
CynicX
Member#: 48199
06 WRX
Drive a high end car and you'll change your outlook...I used to work next to a BMW dealer and I would consitantly hear someone trying to start a car thats already running (that grinding sound) because they couldnt tell the motor was running...
You wont have knock at idle even on the worst gas, well within reason. Generally you cant feel knock considering it usually happens at high rpm and high speed. Audible detention sounds to me like a BB in a coffee can, its MUCH easier to hear then feel. And even then you can be experiencing knock without hearing it. Plus the car can see knock before you can and will warn you with a CEL, it will also try to pull timing so you'll have severely reduced power....
What your experiencing is referred too as the "Subaru Shake". Let me guess it will feel smooth and every 5-20 seconds you feel a wobble that shakes the car?
Although I'm not completely sure what the imbalance is, its perfectly normal in our cars. 2.0 and 2.5....
If you read the litature on the Impreza subaru will make it sound like this boxer design is absolutely perfect and balanced and you could never tell its running. When in reality its noisey and not very smooth. Nothing to worry about though, you'll have 150k miles on it and it will still be doing the same thing...
CynicX is offline   Reply With Quote
Old 10-12-2006, 04:02 PM   #14
78damien
Member#: 128806
Thanks for the insight CynicX. I feel better knowing that I'm not alone in this and that it doesn't have anything to do with the performance or reliability of the engine. Has Subaru said anything to address this before?
Old 10-12-2006, 04:28 PM   #15
CynicX
Member#: 48199
06 WRX
From what I know people that have mentioned something to the dealer were told its normal...
When I got mine I noticed the shake and noise and although I read on here time and time again that its normal I still had to goto the dealer and check. Except when I went I didnt show them my car I wanted to check another new car they had on the lot. And sure enough it sounded EXACTLY the same....
Go try it out, the salesperson will probably be glad to put your mind to rest...
Also always run 93 octane.....
Old 10-12-2006, 04:56 PM   #16
neutronium
Member#: 90406
2005 WRX wagon
$100 Stage 2 WRB
I only feel it when the A/C is on.
neutronium is offline   Reply With Quote
Old 10-12-2006, 05:22 PM   #17
Master2192
Member#: 83254
98 2.5 RS
04 WRX
No it won't, because not hearing the motor is different than feeling slight variations in combustion. The subaru's most likely are easier to feel because of different motor mounts and the block is so small there isn't much metal to absorb the vibration.
I will admit that vibration in the Subys is more noticable. I can feel the individual igntions through my shifter if I am paying attention. I kind of like it that way though.
Old 10-12-2006, 08:37 PM   #18
Hayes
Member#: 11808
Whooo. My 2000 Forester IS SMOOTH. I often times must look at the tachometer to see if its running. I've found it is the smoothest after a hightway run of several miles.
Old 10-12-2006, 10:31 PM   #19
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
i guess it depends how much its knocking...
i never saw a CEL when my engine would knock when it was stock, but it was knocking because i was using MOBIL gas! when i switched gas, to CHEVRON, 76, and SHELL, it never happened again...
WolfInSheepsCLothing is offline   Reply With Quote
Old 10-12-2006, 10:35 PM   #20
hondaeater69
Member#: 60324
man my wrx is quiet compared to my 98 2.5GT Legacy...
Old 10-12-2006, 11:05 PM   #21
HemiKLR
Member#: 80625
VIII Evolution
hahaha metal popcorn... I like that
HemiKLR is offline   Reply With Quote
Old 10-12-2006, 11:07 PM   #22
shemoves
Member#: 80663
2005 STi
most likely normal...go to yur dealership and have them start one up so u can compare.
shemoves is offline   Reply With Quote
Knock at idle? windozer Open Source Reflashes 15 09-29-2009 01:41 AM
Knock at Idle broben05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-18-2007 03:33 PM
Occassional knock at idle? 69_Lex AccessPort 3 10-29-2006 08:46 PM
knock at idle only? crashtke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-12-2006 12:24 AM
