Old 10-12-2006, 01:29 AM   #1
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Default Snow's NitroBooster
Has anyone tried this yet?
http://www.snowperformance.net/prodd...p?prod=Auto120
Have you ever had a big race and wanted just 50 more HP? Now you can with NitroBooster – “ chemical supercharging”. NitroBooster is designed to safely increase the horsepower of your Boost Cooler by 30-50HP. It contains just the right amount of nitro methane to increase HP while not creating a lean condition. Benefits include:
1. Safely gives you an instant 30-50 HP.
2. Boosts octane characteristics.
3. Lowers engine combustion temps.
NitroBooster FAQ
1. Why nitro methane? Nitro methane donates oxygen as it is combusted – think of it as “ chemical supercharging”. It has excellent burn characteristics in that it acts as an octane enhancer with most fuels.
2. Why not just add to the fuel tank? Nitro methane is corrosive and needs system parts made from stainless steel, viton etc. adding to a fuel system made out of steel, rubber etc will corrode these parts.
3. Will it mix with water? Methanol? NitroBooster is made to mix well and stay in suspension with water and methanol.
4. What power increase can I expect? A 30-50 HP increase has been consistently demonstrated when used as directed.
5. Is it safe for my engine? NitroBooster is safe when used as directed. Of course, if the amount is increased by putting more than 8 oz per 2-qt reservoir, a lean condition will result. NitroBooster increases the octane of fuel and will reduce the chance of detonation but will cause a lean condition if you use more than directed.
R0DENT is offline   Reply With Quote
Old 10-12-2006, 01:34 PM   #2
Ultimate Collision Center
Member#: 69072
I have sold it but I have never used it...I will see if I can ge a customer to chime in...
Ultimate Collision Center is offline   Reply With Quote
Old 10-12-2006, 04:23 PM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Would you need to retune the whole setup to run this and to actually get 30-50 more hp?
djerickd is offline   Reply With Quote
Old 10-12-2006, 06:58 PM   #4
Member#: 69072
Of course you would need a retune...
Old 10-12-2006, 07:04 PM   #5
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
I was under the impression a tune would not be required. When you run out, you would have to get re-tuned again which doesn't make sense unless you have map switching ability.
Old 10-12-2006, 07:46 PM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
So...only 8oz per 2 qt of water/meth?..thats some potent stuff.
if you had a AP that would be sweet to have a "NITRO" map.
What kinda octane does this equate to?
Old 10-13-2006, 12:32 PM   #7
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Not sure on the octane.
I called Snow and Greg said no tune is required. As long as you're tuned for 50/50 methanol mix, the NitroBooster is totally safe. I might try it on the dyno this Saturday and I will post my results here.
Old 10-13-2006, 01:52 PM   #8
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
isn't that the same stuff i put in my RC car, nitomethane. $26/gal, i have like 5 gal's at home. Hell, im gona add some to my mixture tonight.
jk.
c'dalerider is offline   Reply With Quote
Old 10-13-2006, 02:01 PM   #9
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
That would be cool, thanks!
Old 10-15-2006, 08:01 PM   #10
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
I unerstand it's safe, but are you going to get good power out of it without tuning? Water is SAFE without tuning but won't make much power (if not loosing some)
Zornorph is offline   Reply With Quote
Old 10-15-2006, 08:05 PM   #11
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
So approx 13% is 8 oz nitro to 60 oz 50/50 , the max recommended. 2l reservior = 68 oz, put 8 oz nitro in, fill remainder with 50/50)
13.5 % is 2.5 cups per gallon of 50/50, but that's lightly above snow's recommendation
2 cups per gallon 50/50 is 11.1% - sounds like a winner.
Old 10-15-2006, 08:41 PM   #12
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
I'm going to the dyno Tuesday and I might try this.
Old 10-16-2006, 12:36 PM   #13
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Its designed to work with a methanol tune. No tune is required as long as you're already tuned for methanol. I wasn't able to try it out on the dyno since I didn't have enough time to stop by Snow Performance Sat. morning before my dyno.
Old 10-16-2006, 06:00 PM   #14
remowgn
Member#: 41149
09 FXT
SSM
jk.
Yes, it is the same stuff. The only problem is the two-stroke oil that is blended in with the methanol/nitromethane. If there was an easy way to separate it out, you'd be in business!
remowgn is offline   Reply With Quote
Old 10-17-2006, 09:04 AM   #15
c'dalerider
Member#: 92388
04 WRX, 06 STI
Alittle two-stroke oil cant hurt can it
Old 10-17-2006, 03:08 PM   #16
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Why would it give you more power if you DONT tune for it? Like running race gas on a race gas tune......yeah it can provide a level of protection....but that's specifically because you haven't tuned to go after the advantage the race gas offers. no?
I don't really mean to be arguing.....just doesn't make sense to me.
BadTrip is offline   Reply With Quote
Old 10-17-2006, 03:52 PM   #17
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
I can't explain why, so why don't you call Snow and ask them? I was told by Snow Performance that NO TUNING is needed and I'll take their word for it.
Old 10-17-2006, 04:23 PM   #18
E-Wrex
Member#: 94533
2006 FXT Limited
Aspen white /w MT
30-50hp in a wrx/sti without a tune? LOL, I don't believe it.
E-Wrex is offline   Reply With Quote
Old 10-18-2006, 02:14 AM   #19
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Bets anyone???
Old 10-30-2006, 06:40 PM   #20
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Okay, excuse the crappy dyno plot because my car started to pull timing with or without this stuff. I think I got some bad gas at a small station. It really sucked because I know the numbers would of been better.
Blue line is with Snows NitroBooster 5 minutes apart. My A/F looks horrible too but I'm not sure if thats from bad gas or tune. When I left the tuner, my dyno plot looked nothing like this one.
Anyway, I did gain 19lbs of torque at the wheels. It also shows spool is quicker. It didn't seam to affect my A/F either.
Can someone else grab of bottle of this and dyno their setup?
Old 11-01-2006, 09:40 PM   #21
wagonpilot
Member#: 86011
2002 Wagon
The added power potential from Nitro comes from the "chemical" addition of oxygen. Much like NOS.
I run it in the model RC stuff too. They sell premixed bottles of several nitro blend percentages with Meth... Even on the RC stuff, the more Nitro, the more power, but you have to richen the needle. It also makes the tune on the RC stuff more delicate to set.
Edit: I ain't putting it in my scoob!
wagonpilot is offline   Reply With Quote
Old 11-02-2006, 02:38 AM   #22
SubieRX
Member#: 16611
05' STi w/ meth inj
Tuned By Harman Motive
How much is this stuff? I'm heading out to harman motive next friday... if its not too much I'd be willing to throw some in and see some dyno results. I'm sure Dan wouldn't mind doing an extra pull if theres no tuning involved either. I'll be running 100% meth though... I read somewhere in the thread thats it meant to be run with 50/50. Think this will make a significant difference?
Edit: N/m... just clicked on the link and got the price... haha. Ultimate CC, you have pm. I'll post up before/after dyno's after nov 10th.
SubieRX is offline   Reply With Quote
Old 11-02-2006, 10:43 AM   #23
Member#: 69072
PM returned...
Old 11-02-2006, 11:04 AM   #24
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
This is safe to add with your methanol setup and doesn't make it run lean when you use as directed.
Just look at my A/F ratio for proof!
I'm curious if you can add this with 100% methanol though. I used mine with Snows brand of Methanol which is close to 50/50.
Old 11-02-2006, 11:48 AM   #25
Swordfish II
Member#: 95554
2007 The Surly Squad
It is just like the turbonator....
Swordfish II is offline   Reply With Quote
w00t Snow's Comming!!! Anyone Tried SkiBiking??? Rallycarperson Off-Topic 11 11-09-2004 09:02 PM
Installed my snow's, now it's 40 degrees Family Truckster Mid West Subaru Owners Club Forum -- MWSOC 8 12-23-2003 02:54 AM
Snow's comin'! MattDell Mid Atlantic Impreza Club -- MAIC 6 03-06-2003 04:06 PM
L.I. Meet Tomorrow - IF IT SNOW'S N'CTRL Tri-State Area Forum 20 11-27-2002 04:46 PM
Who's switched to their snow's? BluSuby Tri-State Area Forum 44 10-30-2002 09:57 PM
