Old 11-06-2001, 10:35 PM   #1
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
Default headers?
can i put headers on a turbo charged rs? am pretty sure iu cant but iono...
scoobyimpreza is offline   Reply With Quote
Old 11-06-2001, 11:03 PM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Yes, but your options are limited to Borla, right now. Given the low quality of the Borla product, I guess that is the same as not having any header choices
Ben
bsquare is offline   Reply With Quote
Old 11-06-2001, 11:42 PM   #3
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
thnx is there anything special u have to do to make it fit with turbo ? cause my friend is saying there turbo exhaust manifd is thsi true>?
Old 11-07-2001, 12:17 AM   #4
bsquare
Member#: 1911
2000 Impreza 2.5RS
Again, but in english?
Old 11-07-2001, 12:20 AM   #5
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
lol... ok do i have to buy an adapter of some sort or does it just fit? what part of the headers go and where does the turbo go? cause on a honda u cant put both... soooo my friend sayd it wasnt a header but it was a turbo exhaust manifold or something better?
Old 11-07-2001, 12:58 AM   #6
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Welllll it all depends on how you're planning to turbo your car. If you've got a specific up pipe and downpipe in mind (for example, the ones off a legacy turbo) then you'll need legacy turbo headers and crossmember. If you're going with a kit for the 2.5RS or getting a custom piece made, then you can work with anything that will bolt up to the stock exhaust system. Oh, and headers and exhaust manifold both refer to the same set of pipes hanging off the bottom of your engine block.
Darshu is offline   Reply With Quote
Old 11-07-2001, 01:14 AM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Before you go any further, I really suggest reading the numerous posts on putting turbos on the RS. You are not nearly well enough informed on the subject and it is not a trivial task. There is a lot of information on this on the i-club, if people bother to look.
For this specific question, the way most turbo kits work leaves the headers untouched and attaches an up-pipe between the headers and the turbo. Some people define headers in a specific way that is only applicable to normally aspirated motors. If you just call it an exhaust manifold, it applies to normally aspirated or forced induction and your Honda friend might stop arguing. The part is completely unchanged either way.
Ben
Old 11-07-2001, 01:54 AM   #8
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
thnx i do search but sometimes i cant find anything, its probaby i dont type the right key words... but thnx for ur help...
Old 11-07-2001, 02:03 AM   #9
bsquare
Member#: 1911
2000 Impreza 2.5RS
Well, you did post in a forum dedicated to putting turbos on cars that don't have them from the factory. By and large, that means turbos on RSes. Just looking at the current list of threads in the forum, there is a lot of interesting reading, if you can be bothered to do it.
Ben
Old 11-07-2001, 03:13 AM   #10
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Question the pipe that goes right out the engine?
Okay, so it seems like if you are doing a legacy turbo, you'll get the legacy header, the up-pipe, the turbine, the downpipe, the center pipe and the exhaust and then the X-MEMBER for clearance.
So what about the Japanese stock GC8 STI header? It will fit the engine block, correct? I haven't read much about the header (exhaust manifold) from the Japanese STI, someone said it won't fit... Any suggestions?
thanks
dknc is offline   Reply With Quote
Old 11-07-2001, 03:20 AM   #11
bsquare
Member#: 1911
2000 Impreza 2.5RS
There was a _lengthy_ thread about this. The up-pipe will not clear the SOHC heads. If you swap in DOHC heads, you have enough clearance, but you still need the new crossmember, etc.
Ben
Old 11-07-2001, 03:41 AM   #12
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
ok i was planning to get a turbo as soon my pocket can afford the founds..... how much can teh stock motor stand? how bing is thevishnu turbo going to be? and i was looking forward to well just say 280 or so to the wheels.... i know that the air force tech turbo is a t3???? and running 5psi u can get 65 hp wich is wrx area... sooo if i some engine mods... and a lil more boost i can get to 250 leaning towards 280? ... well i dont know anything... how much can a 2.5 take? ppl tell me that all i need a engine managment liek a tec II and the motor should be fine... but am not sure... i kno i alwasy ask the same quwation over an dover again but i need to kno... or can u at least point me the right direction with search words... once some gives me a word i search and i want to search more but i dont know wat to search for.... so i just keep asking the same question until i get want i wanna know
Old 11-07-2001, 03:48 AM   #13
bsquare
Member#: 1911
2000 Impreza 2.5RS
The pain, the pain.
Here is a _current_ thread on the subject, no searching required. This thread, also current, is all about somebody going about turboing their car the wrong way and what can happen. Look at this thread (I had to bump the threads listed to the last 2 days to find it), all about putting WRX headers on an RS.
It took all of 2 minutes to locate these _without_ using search, imagine what you could've done if you had bothered to even look for an answer in the hours since you first posted this question.
So please, instead of posting the same question over and over and refusing to try AT ALL on your own, GO READ!
Ben
PS - I'm done posting helpful posts on this thread.
FS : NY: Coated GTSpec UEL Headers/UP [Tial EWG]. Stromung Dual Tip CBE, Invidia DP, MORE! Get p00ted Engine/Power/Exhaust 19 07-30-2010 08:55 PM
FS : Ssi Uel Headers fr0st_wrx Engine/Power/Exhaust 19 06-06-2010 06:31 AM
AP Header, 850cc injectors, stock injectors, parts, etc nXgnSTi TXIC Private Classifieds 54 05-30-2010 04:48 PM
MadDad(TM) Velocity Headers, GT Spec Gen. II Header, and XX Tuning Header Jard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-21-2005 09:45 AM
Headers, Headers and more Headers? Mr.Hanky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 03-25-2004 07:25 PM
